SOURCE: Changing time on my Mitel Superset 4025
The only way to change the time on your individual phone is to change the time on the entire phone system.
That just means there is a call me back message. If you push messages and clear the ones you have then the light will stop blinking.
SOURCE: Plantronics headset connected to Mitel 4025 - won't work!!!!
You need to have a headset button on the set, and you need a release button if you want to transfer calls to others.
Press the Blue SuperKey and press all the buttons (one at a time) to find a spare button or find one that you do not use or need.
Press the * button to change the button (scroll thru the options to find headset).
Once you made the button in to a headset button, press button to turn on or off the headset.
Once the button is lit up, this means that the headset is active, now try pressing the call with the receiver off hook.
This should do the trick... if not write back and I will attempt to help you more.
Good Luck!
SOURCE: I was given a Mitel superset 4025, can this phone
This phones is to be used with a mitel phone system .It is a digital phones witch needs to be connected to mitel digital card on a mitel phone system.
SOURCE: how can i mute the mitel 4025 phone , i do not
http://edocs.mitel.com/UG/EN/2ICP_4025_UG_R2_EN.pdf
Click on the above for your manual and go to page 34 for mute.
Hope it helps!
