Question about Kenmore 57029 Side by Side Refrigerator
Side by side refrigerator- water dispenser clogged and now leakin
Side by side refrigerator. Water dispenser is clogged and now is leaking water into the inside door shelves onto the floor.
    Sergeant:
  • 340 Answers
I'd shut off the water take apart and clean change water filter.
Posted on Jun 20, 2009
Fix water leak in water dispenser
Water leaking inside it
  1. Check the lines to your dispenser
If the lines to your dispenser are broken or damaged you will need to replace them.
  1. Damaged drain pan
If your drain pan has holes or cracks it will also need to be replaced.
  1. Clogged drain
If you experience any clogged drains, they must also be unclogged or replace. If you experience this at the ceiling of your unit it can be attributed to a clog in the freezer section. Remove the divider and let the insulation thaw out and dry.
Sep 08, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
What is causing the water dispenser to drip? Ice is making fine
most likely a leaky water inlet valve or clogged dispenser defrost pipe or water tank leaking or water filter leaking.
Aug 06, 2014 | Samsung RS2630SH Side by Side Refrigerator
My GE Profile refrigerator leaks water from the freezer. I find a puddle under it 2x/week.
Defrost drain tube clogged, drain pan cracked, water tubing near compressor gets brittle and leaks, critters chew on water tubing also.
Oct 29, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge psw23psrss water pooling in refrigerator
If its the fridge side, maybe a leak in the water tank. Remove 2 lower crispers, and have some dispense water through door. If its on freezer side, maybe a clogged defrost drain.
Aug 18, 2012 | GE PSW23PSRSS Side by Side Refrigerator
MY SIDE BY SIDE Whirlpool dispenser water is slow
A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced.Thanks.
Feb 04, 2011 | Whirlpool ED2FHGX Side by Side...
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer side of a side by side water in the bottom
the drain is clogged.take a hair dryer and un thaw the drain
Dec 18, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Jul 04, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Kenmore 57029 Side by Side Refrigerator Logo
297 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
