Question about Xerox 6180MFP/N Printer
Xerox phaser 6180 mfp error code 133-290
Nothing works,fax or copier system lock
    Habit-Forming:
  • 96 Answers
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Posted on Oct 10, 2017
2 Suggested Answers
brett207
  • 231 Answers
SOURCE: Xerox 6180 code 133-290 nothing works,fax or
This looks like a Fax Controller error.
Could be caused by a fault on the Circuit Board (PWBA)
Try turning the device off, wait about 10 seconds, then on again.
Check the "Country" setting in the Menu
<Admin Menu> <Fax Setting> <Country> is set to the country you are in.
If still faulty, you maty need to get the PCB replaced...
Good Luck!
Posted on Dec 08, 2009
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
Xerox phaser 6180 has error code LPR and blue horizontal marks in background show up.
Background is usually a cleaner unit fault, need to check out more on this point. Best to start from this point and try this to see if you can make changes.
Good luck.
Oct 06, 2014 | Xerox Office Equipment & Supplies
Connect 6180 MFP scanner to Toshiba laptop
Press the document to be scanned on the Platen glass. Press the Scan button, an Utility will appear. Select required size and resolution. Upon scanning document, save it in compatible format and attach it to email.
Jan 08, 2014 | Xerox Phaser 6180 MFP/N Letter-Size Color...
Scanner locked brother MFC-7420 please help! nothing works. have sound and beeping and messege scanner locked
The scanner needs to be reset. Turn off the device and then turn it on again.
Please note that when you turn off the MFC's power switch its memory will be cleared. To check whether the MFC has faxes in its memory, click here.
Nov 25, 2013 | Brother MFC-8840D All-In-One Laser Printer
Copy machine is stuck in the copy mode
Sounds like the machine does not have a fax board on it. Have you been able to fax in the past?
If nothing else, try rebooting the machine, then have your servicing dealer come out to check the fax board module if rebooting doesnt help.
Skelton Business Equipment Houston Copiers
Nov 18, 2013 | Sharp Mx-m260 26ppm Copier
ERROR 093-951
http://www.refillbros.com/en/manuals/p1643-xerox-phaser-6280-service-manual?page=199
see this page for detail and how to repair
i hope this helpfull, if you think this helpfull please rate very helpfull
thanks for using fixya
Jan 23, 2011 | Xerox Phaser 6180N Laser Printer
Xerox phaser 6180 MFP displays errorr message and code BLK CRUM ERROR 093 925 restart printer problem occurred when a fax was being received
This error message points to either
1 A corrupted chip on the toner cartridge.
2 The wrong chip on the toner cartridge. There are several printers that take the same basic cartridge, the difference being the chip.
If you have just bought the cartridge, return it for replacement.
Oct 06, 2010 | Office Equipment & Supplies
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
I have a Xerox Phaser 6180MFP and when I print #10 standard envelopes and #9 renturn envelopes the envelopes come out with badly pressed wrinkles on the end of the envelope that comes out last. I have...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
May 21, 2010 | Xerox Phaser 6180N Laser Printer
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox 6180MFP/N Printer Logo
963 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
