I am going to need a little more details of the problem
1. What did the big sound, sound like? was it a crashing noise and then silence or was there still a sound like something trying to move ?
2. Was it a small medium or large load laundry?
3. Have you tried using it after a while?
3.1 If yes please describe what happened when you started the machine again.
3.2 If no. Please try to start the machine without a load in it and describe what happens.
SOURCE: electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
SOURCE: i want a manual for an electrolux ewf1074 front
http://www.electrolux.com.my/Files/Malaysia_Singapore/Manuals/FabricCare/EWF1074.pdf
SOURCE: Hi,
First of all is the machine doing anything it should not be.That alarm code does not exist on our system,the closest is EH1 and this relates to Power supply problems or a faulty PCB.To cancel press and hold the start/pause button and the nearest option button for about 5 seconds,now turn the programme knob to position 10 then hold in the start/pause button and option buttons again till alarm disappears and E00 is showing.Then turn dial to 0 then back to position 1 then back to 0 to cancel operation.
Hope this helps.
SOURCE: electrolux EWF1074 front loader ripped rubber
i would get the rubber bellow replaced asap as water will be running onto components causing short circuits
SOURCE: Electrolux EWF1074 washing machine When I
Hi To remove this error please follows the steps given on
page#11 of this user manual for your Electrolux EWF1074. Hope this
helps...please post back for further assistance. Daniel
