Question about D-Link DI-514 / DWL-520 Kit (di-514/dwl-520-k)
DIR-615 I hooked it up the way the c.d. siad and Icould not get on the Internet and some of my games I could not play, it asked for name and key, It is not on long enough for me to do anything. How do I change it or get it off.
    Genius:
  • 1,269 Answers
Check your physical connection first. From the modem, it should be connected to the router's Internet port, then your computer must be connected to port 1 on the back of the router. Reset the router now, hold the reset button at the back of the router for 30 seconds, Then do a power cycle by turning off the router first then the modem, wait for 20 seconds. Turn on the modem first and wait for the ligts to be steady then power on the router, no need to run the setup CD. If it doesn't work, you need to manually configure the router. You may need assistance from D-Link tech support. Call their toll free number
Posted on Jun 21, 2009
How can i make my wifi unlock on my D-Link dir 615 wireless router
Login in using your browser using a LAN cable and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Dec 01, 2013 | D-Link DIR-615 Wireless Router
I just want to set up an internal network with dlink router
To setup a network just follow the step by step guide that came with the DIR-615 router. When it comes to setting up the internet on the router wizard just select Cable or DHCP and leave the other internet settings as default.
As regards to your printer we need to know the make and model number so we could further assist you. By knowing the make and model of the printer it will help us how to best setup your printer on the network. The model number is usually the name of the printer or near barcodes on the back or bottom of the printer.
Dec 17, 2012 | D-Link DIR-615 Wireless Router
I am trying to hook up a netgear universaL WIFI INTERNET ADAPTER to my tv and it says to push the WPS button on my router and i dont know what to push
The dlink dir 615 wireless router hasnt got wps. So its no good trying to connect it via that way you can only do it via wep or wapor wap2 here is a link to the manual for your router http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Mar 11, 2011 | D-Link DIR-615 Wireless Router
I am connected to a DIR 615, it says I have wireless connection but it won't connect wireless, if I connect a cable it is fine??
Hi mike63771,
All you need to do is to set it up properly. Make sure that the router is connected to the computer using an ethernet cable so that the computer will be able to communicate with the router. Then open a browser type 192.168.0.1 on the address bar. The default username is admin and the password is blank. Go to the Wireless Settings Page then check the SSID or Network Name and the Network Key or Passphrase. Now try to connect to your computer. Click on Start then click on Connect To. Select your Network Name then if it ask you to enter a password enter the Network Key. You can personalize the network key on the router settings page.
Rate me if this helps so i can help other.
Thanks for using Fixya.
Feb 02, 2011 | D-Link DIR-615 Wireless Router
I am trying to hook up a kindle. I have a D-Link Dir-615 router. When I try to connect, the kindle says that I need a password. I do not know how to open it other than changing the password which I do not...
Turn the DIR-615 router to its backside, where all the cables are connected. With the router still plugged in, use a paperclip or other small object to hold down the Reset button for 30 seconds. You can find the Reset button between the power connector and internet port.
admin is a default name there is no default password BUT BEWARE !!
Important: Resetting a router is different than restarting (rebooting) it. Resetting a router will remove all of its settings, not just the username and password. This means any wireless network settings, port forwarding options, etc. will be erased.
  1. Turn the DIR-615 router to its backside, where all the cables are connected.
  2. With the router still plugged in, use a paperclip or other small object to hold down the Reset button for 30 seconds.
  1. Wait another 30-60 seconds to let the router finish booting back up.
  2. Unplug the power cable from the back of the router and wait 10-30 seconds.
  3. Plug the power cable back in and let it power on completely (which should take less than 1 minute).
  4. You should now have access to your DIR-615 router at http://192.168.0.1/ with the Admin username and blank password.
Dec 14, 2017 | Computers & Internet
DIR-615 Wireless Router: i have a d-link wireless router dir 615 that i've ...
if youve changed the password on the router since the other computers logged onto the network, then you need to delete the network history from those computers.
Otherwise those laptops will be trying to connect to the network with the old details.
May 16, 2010 | D-Link DIR-615 Wireless Router
D-Link DIR 615 Wireless Router problem - Speed goes down freq.
Please contact the D-link to upgrade the firmware and always turn the router off when it is not in use because it takes the static charges.
May 09, 2010 | D-Link DIR-615 Wireless Router
Please help, when i try to connect dir-615 on my network pc that is running vista, instead of asking for wireless passkey key{because i set on my router to WPA security)it's asking for certificate and user...
1st have clean all settings? a reset button is behind nerby the power connector.
2nd change wireless passkey(use WPA2 it´s safer) and very important the router password.
3rd reboot computer, then vista work well. (Its a Vista Defect, dont ask me why, but it´s true)
Nov 21, 2009 | D-Link DIR-615 Wireless Router
Connected to wireless router, not connected to the internet
Try setting up a new network connection in the Network and Sharing Center. You'll need your info from your router like:
router username:
router password:
network name (ssid):
network security type:
network security key:
connection type:
Some will also ask for a serial id(I've only ever come across one)
I've never used your particular brand of router but it ought to work the same way as far as the setup.
Aug 25, 2009 | D-Link DIR-615 Wireless Router
I started to set up my DIR-615 and I lost power. When I returned to play the Cd it will not play now.So can't get hooked up to the WIFI on my I. touch. Also is the sound wave light supose to flash as mine...
Sound wave light if for wifi you can connect to the router via Firefox / or IE by going to 192.168.0.1 in the address bar the default user name and password is admin/blank if it doesn't log in there is a reset button on the back of the router hold it in for 10-15 sec and try again or click here for a vague walk through
Aug 20, 2009 | D-Link DIR-615 Wireless Router
D-Link DI-514 / DWL-520 Kit (di-514/dwl-520-k) Logo
158 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
