Question about HP Office Equipment & Supplies
How do I edit a document using hp scanjet3400C
I scanned an orginal document but want to make some changes (edit), I have no manual what do I do?
  • 255 Answers
1. install photoshop
2. you can edit in photoshop
regards
ehsanullah
md_ehsan_1@yahoo.co.in
Posted on Jun 22, 2009
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
I have a hp 1310 AIO Printer how do you scan documents to computer using such programmes as ms word
MS Word cannot open scanned documents to edit. You need to run a scanned document through an OCR program (optical character recognition program) which converts the scanned document into a text document. Then you open Ms Word and import or open this text document to edit or change the text.
Nov 25, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Scanning document and editing in word
Hai,
HP Solution center software installed for your printer model has OCR feature to edit the scanned text image, but its not guaranteed.
Optical Character Recognition (OCR) programs cannot reproduce a document with 100% accuracy every time. Some manual correction of the page is necessary.The following information might help increase the accuracy of the OCR.
1.You must click Scan Document from the HP Solution Center to begin the scan for the OCR to work.
2.On the Scan Document Button window, select a compatible program in the Scan to drop-down. The perform OCR setting then appears to the right.
3.On the Scan Document button Window, select the Scan Document Settings button.
4.Make sure at least 300 ppi is selected.
5.Remove the setting from Flowed Text in the Scan Settings window. If it is not already selected, select it now.This option will work correctly only in word processing programs capable of accepting this type of output. Microsoft WordPad, for example, will not accept this type of output.
6.Repeat Step 5 with the Retain page formatting setting.
Note: If the above solution didnt work, then you have to buy third party OCR software.
Thanks & Regards
Rizwan
Jan 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
UNABLE TO MAKE CORRECTIONS TO DOCUMENT
Scanners put a graphic image on your computer that is a "picture" as far as the computer is concerned and therefore, you cannot edit text because it is seen as pixels and not characters. In order to make a scanned document editable, you'll need to use the OCR function in your software (Optical Character Recognition). This is assuming your printer came with OCR software, if not, you'll need to purchase an OCR software package in order to convert images into editable documents. You should be able to find such packages for less than $50.00. Check your documentation (and help files) and look for OCR in the index or search the help files for OCR to see if such software came with your printer software package.
Jan 30, 2010 | HP Photosmart C4240 All-In-One InkJet...
HP All-in-One Can't scan without printing
There is an OCR reader in the programs included with the install disk. This OCR will break down your entire document for editing. If you don't have the disk, it very simple to get all the software from the site.
Sep 08, 2009 | HP DeskJet F380 All-In-One Printer
Cannot edit scanned document
its like this, the OCR or the SOftware installed in your computer is limited. If you're trying to scan a document which has a picture or with text that uses different fonts like monotype, or those that are not usually being use for normal documents, usually it wouldnt detect and it become distorted. Anyways, here are the steps that i want you to follow.
1. Open solution center. (click start, go to all programs, go to HP, then click on SOLUTION CENTER). or you can see SOlution Center on your Desktop.
2. Click on Scan Documents, then the Scan documents setting will open. Change the settings to these.
* SCAN TO: Microsoft Word.
3. Then, hit scan.
4. After scanning, the folder My Scans will open automatically, just go ahead and open the scanned document.
5. From there, you can start editing the text.
..remember, the scan a document is limited, it will not read all types of fonts. if the document is using a "times new roman" or "arial" the scanned document appears to be almost the same with the original. But, if the scanned document contains pictures or stylish fonts, that would make the document distorted.
Please let me know if you still have clarifications.
Thank you.
adonscott
May 01, 2008 | HP Officejet 5610 All-In-One InkJet...
Scanning
Did you tried with any OCR software to convert the Scanned imaged (jpeg) to Word Documen?.Always if you scan anything to an image, it will scan in JPEG format that will consume lot of memory.Scan with OCR(Optical Character Recognition) Software and that will Convert JPEG to word Document which will fix the problem.
The OCR software that i Recommend is ABBY Fine Reader.
Thanks
Riz
Apr 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
I press scan it it wont scan my picture.
1. To load a picture, lift the lid and place the original face down on the left front corner of the glass, with the sides of the picture touching the left and bottom edges.
2. Close the lid
Scanning a text document
  1. Load the original.
  2. From the HP Director , click Scan Document .
  3. From the HP Scanning dialog box, select the desired options and Scan to destination.
  4. A preview of the image will appear in the HP Scan window. Make any edits from the HP Scan window and click Accept .
  5. Click Scan . The document will open in the selected Scan to destination.
Scanning a picture
  2. From the HP Director , click Scan Picture . A preview of the image will appear in the HP Scan window.
  3. Make any edits from the HP Scan window and click Accept . The HP PSC sends the scan to the HP Photo & Imaging Gallery , which automatically opens and displays the image. The HP Photo & Imaging Gallery has many tools to edit the scanned image. For more information about using the HP Photo & Imaging Gallery , see the onscreen help that came with the software.
Stopping a scan To stop scanning, press Cancel on the front panel. Hope this helps. Good Luck.
Apr 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanning
Dear Tony
My problem is i have used a printer "Hp psc 1210 all in one" in my old computer under windows XP, the scanner was ok!
Recently I changed a new computer "HP a1730n" it uses Windows Vista and vista suggest use Photo Gallery to scan but can't edit the the scanned text document.
Please give me some help!
bhca1704
Dec 04, 2007 | HP PSC 1210 All-In-One InkJet Printer
Editing a scanned document
Hi, You can try use an OCR program. Sometimes it is included/bundled in the software/drivers/application CD that came with your scanner. You can also google for freeware versions. OCR (Optical Character Recognition) will recognize the text from the scanned document, you can copy/paste and thereafter edit. Hope this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | HP PSC 2355 All-In-One InkJet Printer
mukhtar21 shaikh
mukhtar21 shaikh
