Question about Canon CanoScan 9950F Flatbed Scanner
Lamp turns off during warm up cycle!
Scanner works fine in normal mode but when in transparency mode the lamp turns of after about 7% through tha warm up cycle and then stops. I have reinstalled everything and even changed my computer but it is still the same. It worked previously and this problem just appeared out of thin air one day. Any fix out there?
SOURCE: scanner
Hello, i have changed 2 registry keys. Now my scanner works without warm up, but i don't know, if they are resettet automatically after a period. I have tested this only a few hours and it worked. Please test it.
HKEY_CURRENT_USER\Software\Canon\ScanGear\8.6\Devices\CNQ4200
Key Energy save changed to 1
Key Lamp Off Time changed to 0
Greets
Holger
Posted on Jan 14, 2008
  • 3 Answers
SOURCE: I have a canon dr-1210c scanner. The menu display
The lamp is getting too hot. Turn off your scanner when not in use.
Posted on Aug 28, 2009
SOURCE: Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
Posted on Oct 15, 2009
  • 3 Answers
SOURCE: My Canon 8400F worked yesterday and today it is
First, make certain that the flatbed scanner lid is securely shut.
Second, unplug the power and USB cables from the rear of the scanner.
Third, deposit the Canon 8400F scanner in the nearest garbage receptacle where it belongs.
Hope this helps.
Posted on Oct 21, 2009
  • 1705 Answers
SOURCE: canoscan lide 70
Looks like things have got a bit mixed up with the canon software. Try this:-
1) Un-install the camera.
2) Un-install the scanner.
3) Re-start the PC.
4) Re-install the scanner.
Posted on Mar 29, 2010
My left turn signal started to only work about 50% of the time, it wont work hardly at all now. the right turn signal is fine. When I try to use the left turn signal, there is no dash indicator lights
Hey Bob how's it going ? I have been looking at Chevy service info for your vehicle and this a little on the complex side or that is the way it sounds from the turn signal description !
Turn Signal Lamps
The smart flasher (GMSF) is an automotive flasher designed to accept turn, hazard, and brake inputs. The GMSF will provide corresponding outputs to the exterior lamps and instrument panel turn signal indicator lamps. This lighting system has dedicated lamps for the turn/hazard functions and dedicated lamps for the brake function. The system incorporates the use of flash rates for diagnostics. The flash rate is a calculation of the number of flashes that occur within a 60 second period. This system uses a percentage of on-time to off-time called duty cycle. For the bulb outage condition, the indicator of the vehicle side on which the outage occurs shall assume bulb outage flash rate mode. The opposite side indicator will assume the normal flash rate mode for an input from the non bulb outage side of the vehicle. Hazard warning lamp outage will maintain a normal flash rate as long as 2 or more exterior signaling lamps are functional. During all modes of operation, the IPC will receive the same flash rates and duty cycles that the exterior lamps receive. The IPC will then control the indicators in the cluster. The vehicle operator will be provided with an audible and visual indication of the flasher operation. Below is a table with flash rates and duty cycles:
Are all your bulbs good ?
Operating Condition
Flash Rate
Duty Cycle
Normal
75 to 105 flashes per minute
45% to 55%
Turn Signal Lamp Outage
2 or 3 times faster than normal flash rate
35% to 55%
Feb 02, 2015 | 2005 Chevrolet TrailBlazer
Canon 8600f scanner- notice says "lamp warming up - cannot continue" when scanning transparencies
have you try to uninstall & install again the canon driver on your PC..?
just try to this to correct the problem..
let me know here again
micro
Jul 01, 2008 | Canon Office Equipment & Supplies
Lamp shuts down during warm up cycle!
My belief is that it would be inside the scanner itself. In transparency mode the lamp may require more power and shutting off is a safety device if something is failing. Sadly, repairing a scanner costs almost as much as buying a new one.
Apr 24, 2014 | Canon CanoScan 9950F Flatbed Scanner
Canon 9950f scanner troubleshooting
I would go onto the Canon support site. The page for this model is
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_9950f#ServiceAndSupport
Apr 24, 2014 | Office Equipment & Supplies
How to canon np 4050 scanner lamp continuously on
It would be in service mode, why would you want to turn it On continuously??? Does the lamp turn ON with warm up? If so, the lamp and fuse is good. When you make a copy, will the lamp turn OFF and ON when it is scanning the original? If it dose, you will need to replace the scanner power cable. This copier is very, very, old.... I was trained on it over 20 years ago... Parts may be hard to find.... Good Luck
Dec 08, 2012 | Canon Copier Toner Cartridge Npg 4 For Np...
I have a Xerox 7356 Scanner which continually says: Not Ready on the display. Any suggestions on how to troubleshoot this problem or where to go on-line to research troubleshooting?
it is likely the lamp.
Easy fix.
Buy a new lamp at a good lamp supply store. Type F32T8 SPX41
Make sure the back plate is white and re-normalize the cameras.
If you get the "NOT READY" message only after you insert an original
then the problem is likely the motion sensor.
Oct 14, 2010 | Xerox 8830 Copier
4990 scanner
Nothing is wrong if your scan turns out good
Jan 22, 2008 | Epson Perfection 4990 Flatbed Scanner
Scanner
Greets
Holger
Nov 16, 2007 | Canon CanoScan 4200F Flatbed Scanner
How to change lamp in AGFA Arcus 2 flatbed scanner?
http://www.uktsupport.co.uk/scanner/agfa/arcus.htm#a2lamp
  • Turn off the scanner power switch and disconnect the power plug. Wait at least 15 minutes to allow the unit to cool down.
  • Unscrew the two screws at the back of the base.
  • Pull the SCSI board out enough to disconnect the ribbon cable that threads through the opening in the base (on the right).
  • Remove the two screws from the upper portion of the back of the base.
  • Remove the Transparency Option (TPO) from the base.
  • Remove the two screws from the top back of the base. These screws will be visible when the Transparency option is removed.
  • Remove the two screws from the top front of the base and lift the plastic housing off the scanner.
  • Move the carriage optical assembly backward until you can reach the lamp.
  • Remove the two screws from the top of the optical assembly that covers the bulb and remove the black cover.
  • Lift the lamp from the socket, working one end, then the other.
  • Replace the lamp with a replacement lamp. One replacement lamp is provided with the scanner and others are available through Agfa Parts Order.
  • Return the lamp cover the original position and replace the two screws.
  • Replace the plastic housing and replace the four screws holding the housing.
  • Thread the ribbon cable of the Transparency Option through the base and plug back into the SCSI board.
  • Return the board to the base and tighten the two screws. This insures a slack cable that won't be punctured when screws are put in to attach the transparency module to the base unit.
  • Replace the two screws in the back of the base to secure the Transparency Option to the base.
  • Nov 16, 2007 | Agfa Arcus II Flatbed Scanner
    Canon CanoScan 9950F Flatbed Scanner Logo
    old marine
    old marine
    mukhtar21 shaikh
    mukhtar21 shaikh
