My air conditioning unit does not come on outside the fan comes on inside; but the weather king unit itself does not come on.
  • 3,230 Answers
We need the model and make of your AC.
and please also tell me, How old is this AC?
Thanks
Posted on Jun 20, 2009
What is wrong when weather king air conditioning not coming on?
If you turn the unit to heat and say set the temp to 85 and the furnace fires up but the blower doesnt turn on after a minute or 3, 3 things to check. One is the fan control switch in the plenum. It says the plenum is hot and ok to turn on the blower. If the switch is ok, then check the blower and the capacitor. Set unit to AC and set temp to meat locker. Outside compressor and fan should come on immediately. If not
have a friend turn it on from inside while you listen outside. If you here a click, the contactor is good. If it is, check to see if the 230 Volts circuit breaker (inside in the panel) has not tripped. If thats good check the disconnect next to the outside unit. Then check for 240 AC or so on the far side of the contactor. If thats good, check the split capacitor with the power off. If all the above is good, and the fan doesnt come on, replace the motor in the outside fan. If the fan does come on and the compressor does not, see if there is a protection switch that needs to be reset. And if you dont understand the above, call a reputable dealer (ask your neighbors who they trust)
Apr 27, 2014 | Heating & Cooling
AC was running all this summer, then suddenly stopped working. The fan runs on auto and manual but the outside unit does not come on.
The indoor fan is running . but the compressor and outdoor fan does not come on . check fuses there should be a disconnect on the outside by the unit it may have fuses. one could be blown. if the unit has a curcuit board see if any light are falshing. let me know
Jul 23, 2011 | Weather King 10AJA6001AH Air Conditioner
Want prices on outside unit fan condenser
When I am called to replace a outdoor fan motor I charge $330.I am in las vegas and the charge varies form company to company.The fan motor itself is approx $80 my cost(230v 1 phase condenser fan motor).
Jul 21, 2009 | Weather King 10AJA3001AH Air Conditioner
Can be the unit don't have enough gas?
Yes, you could be low on refirgerant. You should have a air conditioning technician test it.
Jun 23, 2009 | Weather King 10AJA3601AH Air Conditioner
Air king problem
. You probably have too many time delays in your system and check the timer set points. sometime some thermostat has a time delay and the unit itself has a circuit board time delay.
Sep 02, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather king model 10AJA4201
Unit is over heating and setting the internal limit switch. Capacitor an/or outdoor fan could be failing.
Aug 21, 2008 | Weather King 10AJA4201AH Air Conditioner
Weather King AC
The motor of your air mover in the inside unit has failed.
It is responsible for circulating the air through the exchanger and your home.
This may be located in an attic space depending on the construction of your house.
Running the cooling with this not working could cause your outside unit to operate continuously or fail.
A more remote possibility is that the thermostat has failed and is only causing the outside unit to run.
Aug 19, 2008 | Weather King 10AJA6001AH Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Not Cooling
Yes, the compressor might not be running. Possibly a bad run capacitor or maybe burnt wires on the contactor or compressor flags.
Oct 26, 2007 | Weather King 10AJA3601AH Air Conditioner
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
