Question about Canon imageRUNNER 5000 Copier
Not able to start my machine dure to error below
error no E000004 in ir6000 how to solve it
    Sergeant:
  • 199 Answers
The SSR has a short circuit. The DC controller PCB is faulty.
0000 The SSR used to drive the fixing heater is found to have a short circuit
(hard circuit detection).
The error must be reset in service mode (COPIER>FUNCTION>
CLEAR>ERR).
Posted on Jun 21, 2009
  • 100 Answers
E004 is most likely a blown thermistor , Its a 10 dollar part part but it doesnt fail for no reason. i suspect there is a problem with the fixing assembly. Might need rebuilt.
Posted on Jun 25, 2009
Canon ir6000 error code e000012 xerox machine not running solve problem
E000012 Clock pulses fail to be generated or the PLL lock is released due to a fault in the drum motor, etc.In case the drum drive motor exists in addition to the main motor, this code refers to an error of a motor which drives mainly other units than the drum.
May 25, 2018 | Canon Office Equipment & Supplies
ERROR E000004-0401 ON CANON C4080i WHAT DOES THIS MEAN
Code
E000004
Description
Fixing temperature abnormal rise
The temperature detected by the main thermistor does not rise to the specified value during startup control.
Remedy
1.Go through the following to clear the error: CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power. 2.Check connection of the Connectors (Thermistor Connector and AC Connector). 3.Replace the Fixing Main Thermistor (Film Unit). 4.Replace the Fixing Assembly. 5.Replace the DC Controller PCB (PCB4).
Sep 28, 2016 | Canon Office Equipment & Supplies
How to solve this e000061-0001 error
Hi
The description for this error can be found here:
Error Codes Canon iR6000 Code E061 0001
and is the same for both the IR5000 and IR6000. There is a link on this page as well to download the full service manual for the model displayed, which should enable you to solve the problem.
On the right at the top of the page you can change the error code you are looking for to get a quick reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
My canon iR c5185i displays error E000004-0401 please help me he solution
This is a fuser unit error, if powering off & on the machine the error doesn't clear then you will need to have the fuser unit replaced.
Aug 25, 2014 | Canon Ir-c5185i With Feed, Fax, Finisher,...
In canon 6570 when machine is switch ON error E000004-0106 and sometimes E000004-010 appears , what is the reason?
hi this is srinivas
sir
canon 6570 when machine is switch ON error E000004-0103 and sometimes E000004-010 appears , what is the reason?pls giv me a solution.
thank u
Sep 28, 2010 | Canon IMAGERUNNER 6570 Copier
My canon photocopy machine displays an error code presenting as (E 000602 - 0003)Please help me solve this problem.
Hi these means that you have HDD trouble, and it needs to be changed and upload the system on it - CALL SERVICE.
Aug 19, 2010 | Canon Office Equipment & Supplies
E000001-0001 fault codemany ideas?? thanks
E00004-0001 is fixing unit error. Need model# for more specific repair. More than likely needs fixing unit to be replaced.
Jul 09, 2010 | Canon Office Equipment & Supplies
E000004-0004 canon
dirty sensor that the fuser unit activates needs cleaning. Remove the vertical paper feed assembly - you'll see a black sensor arm that "breaks" a photo interupter and closes 2 micro switches. Its the photo interupter thats dirty.
Mar 04, 2010 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER 5000 Copier Logo
446 people viewed this question
old marine
old marine
