Question about Car Audio & Video
Head Unit Setting
What does the level setting in the PPS for my Low indicate
  • Josh Collins
    Josh Collins Jun 26, 2009
    No its something to do with My Sub Levels I am just not sure what the Frequency needs to be set at.
  • 578 Answers
Perset station that you want
Posted on Jun 26, 2009
Electric blanket blinking,not heating
Live in North ,gone through a few of these puppies,Some of them flash to indicate they are on but not heating,usually a timer override safety issues. In the cases just push setting but to desired level.If however you only have a high/low setting or off on switch with not level settings and light is blinking,hate to say it,but it's gone to a better place.Sounds of taps playing in distance.
Dec 29, 2016 | Home
Fix my fuel gauge on my 2006 Ford F 350 diesel
Are you ready to pull a fuel tank ? Inside the fuel tank is the fuel sending unit.The instrument cluster is hardwired to the fuel sending unit, which is a variable resistor controlled by the action of a float arm. When the fuel level is low, resistance in the unit is low. When the fuel level is high, the resistance is high. The instrument cluster uses the input from the fuel sender and commands the fuel gauge indication according to the fuel level data. Do you know anything about automotive electrical systems ? Do you own a volt meter and do you know about code setting capability potential in new vehicles ? It is possibly for a problem in the fuel sending unit circuit to set codes in the smart junction box.
Fuel Gauge Tech How To Properly Diagnose Faulty Fuel Pump Sending Unit
Jan 15, 2015 | Ford Cars & Trucks
How do you know if it is on?
Assuming that the unit is plugged in to an outlet that has power, press the ON button and a green light should come ON. That will indicate the unit is getting power and is ready to function. If however, you have the humidity level set to high and it's equal to or higher than the humidity level in your home, the unit's compressor and fan will not turn ON and run. Keep in mind, the humidity level, whether it's and LCD readout screen or just a minimum and high setting, that's not the amount of humidity that the unit will remove. It's what it will maintain. So, setting it as low as possible, should cause the unit to start functioning.
If it doesn't start, check the water collection bucket, to be sure that it's installed properly and is making contact with the safety trigger switch. If it's not making contact, the unit will not turn ON.
Hope this info helped you. Please let me know. Thanks.
May 13, 2011 | Amana D545M Dehumidifier
Nokia 5530 call soud is very low
Open setting , open tones and set the volume up to the high level
make a test and redo if required, choose a caller ring tone that is good to recognize.set the tone pad levels.
the volume level of the caller in the speaker can be increased when the call comes using the up and down keys of the menu scroll which show s an indication on the screen. If low check the earpiece for dirt or weakness of the unit.
Sep 29, 2010 | Nokia 5530 XpressMusic Smartphone
Don't know how to turn off the alarm. Bought this used (made in 1995) so there were no books with it. It comes on every day at 2. The system is on 'standby' all the time. I just don't seem to find the...
Setting the ON time (Example: AM 10:15).
1. Press the TIMER button on the Unit for more than
two seconds.
The Timer indicator lights up and the hour digit of the
current ON time blinks on the display.
• When the clock is not set, “CLOCK” and “ADJUST”
appear alternately on the display. Set the clock first.
Press the ¢ or 4 button on the Unit to set the
hour you want the Unit to come on.
Pressing the ¢ button moves the time forwards and
pressing the 4 button moves it backwards. Hold
down the button to move the time rapidly.
2. Press the TIMER button.
The minute digits of the ON time blink on the display.
Set the minute you want the Unit to come on, using
the ¢ or 4 button.
2 Setting the OFF time (Example: PM 1:30).
1. Press the TIMER button.
The hour digit of the OFF time blinks on the display.
(The same time as the ON time will be automatically
set.)
Set the hour you want the Unit to be turned off, using
the ¢ or 4 button.
The minute digits of the OFF time blink on the display
Set the minute you want the Unit to be turned off, using
the ¢ and 4 buttons.
3 Selecting the music source.
The “TUNER” or “CD” blinks on the display.
2. Press the ¢ or 4 button to select the music
source you want to listen to.
The display changes as shown below.
TUNERôCDô(back to the beginning)
4 Setting the volume level.
The current volume setting blinks on the display.
2. Press the ¢ or 4 button to select the volume level.
-- :The current volume level will be used.
0 to 50 :When the timer is turned on, the Volume
will be automatically set to the selected
level.
5 Press the TIMER button.
The timer setting is completed and the display returns to
the display before you set the Timer. The Timer indicator
remains lit.
6 Before turning off the System, prepare
the music source selected in step 3.
TUNER: Tune in to the desired station.
CD: Insert a CD. (Playback will start from the first
track at Timer on.)
7 Press the % button to turn off the System.
In standby mode, you can see the Timer indicator ( )
on the display.
• When the timer turns on, the Timer indicator starts
blinking and the prepared source in step 6 will be
played.
To cancel the timer, press the TIMER button. The
Timer indicator ( ) goes out on the display.
To re-activate the cancelled timer, press the TIMER
button to light the Timer indicator ( ).
At this time, you can see the current timer settings. Each
setting appears on the display for two seconds in the order
of ON time, OFF time, music source and volume.
To change the timer setting, repeat the setting procedure
from the beginning.
Oct 31, 2009 | JVC KD-G210 CD Player
What is the check gauges light
CHECK GAGES light (1) indicates a potential engine failure(low oil pressure, low coolant, coolant overheating) has occurred.
· Check gages and shut down engine. Gages should read as follows: Oil pressure 5 to 10 psi (34 to 69 kPa) at idle; Water Temp gage below 230 degrees (110 C).
· Check engine oil level (Para 2-11) if OIL PRESS gage indicates low reading. Check coolant level (Para 2-11) if Water Temp gage indicates high reading. Notify Unit Maintenance if levels are low.
If CHECK ENGINE light (2) is on, check engine oil pressure gage (3) and water temperature gage (4). If both indicate normal, proceed with mission and then notify Unit Maintenance. If either one does not indicate normal, stop engine immediately and notify Unit Maintenance
Oct 16, 2009 | 1999 GMC Jimmy
Salt level indicator not showing
of corse no:
there a sensor of salt independent of water hardness
so you can change the salt sensor if the problem persist
thank you
Jul 10, 2009 | Dishwashers
No power
Factory Default Setting:
When the unit is first connected to a power supply, the
electronic circuit board will automatically default to the
following factory settings;
Mode: Dehumidifier
Humidity Set Air Value:60% RH
Fan Speed: = Low
NOTE: In the event of a power failure or the unit is
switched ‘Off’, the most recent settings are retained and
restored once the power is switched “On”/resumed.
IMPORTANT NOTE: Depending on the ambient humidity
conditions, when power is restored or switched ‘On’ the
dehumidifier may not start automatically under the factory
or custom (see page 7) default setting. This is an indication
that the ambient RH% level of the surrounding environment
is lower than the current default setting and it
may be necessary to select a lower set RH% value.
Feb 16, 2009 | Danby DDR586R Dehumidifier
Can not play PPS file game.
Issue of OS incompatibility with program. See if Vista has a compatibility setting, if not your are SOL.
Sep 19, 2017 | Computers & Internet
Water temperature
if it is electric remove the metal plate that is about 1/3 from the top usually colored blue or whitethere is pull dome of the insulation out fof the way you will see red and blue wires going into the element and a plastic cover underneath the cover is a setting with an indicator it is usually adjustable with a thin flat head crew driver the indicator has high medium and low temp setting
Just turn indicator to temp desired
good luck
Jan 08, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
