Putting a name on a label
How do i print my information on 30 laser labels with the code of 5260
  • 37 Answers
You can download the template for code 5260 here:
It could be opened using Microsoft word
Posted on Nov 20, 2007
How can i avoid label sheets getting stuck in phaser 8560
1. Make sure you are feeding the labels from the bypass tray, not from the cassette.-
2. Make sure the labels are for Laser printers, not Inkjet printers.
3. Do not try and re-use a label sheet that only was half printed on.
4. When you put the labels in the bypass tray, set the paper type to labels...this slows down the print process so they won't get jammed.
Jun 02, 2014 | Xerox Phaser 8550DP Printer
Label is printed fine but each printed label print blank line before label print
To isolate problem run a test label from printer.Does the same thing happen? If so it is a printer problem.If not the problem is in the document itself.
Apr 24, 2014 | Zebra LP 2844 Thermal Printer
When I print labels the sheet is smudged using Dell 3110cn.
Due to the thickness of label stock it can take more heat to fuse the toner than when you use normal paper.
1 You MUST use labels that are suitable for laser printers.
2 When printing on labels, you'll probably put them (face down) in the MPF 'tray' in the door, and make sure you choose Label as your paper type under Printing Preferences, Paper Tray, MPF Settings
Mar 05, 2010 | Dell 3110cn Laser Printer
Hot to print albels and envelopes on Brother DCP-7030
labels only sheet laser printer labels, use word to configure label layout or use "label unlimited" software, available on office stores in 30 sheets labels pack as free software.
I use these software, and very easy to configure.
envelopes is easy use Microsoft Word on "tools" menu.
Jan 29, 2010 | Brother DCP-7030 Digital All-in-One Laser...
How to print adhisive labels using mfc 7340
Buy laser-specific adhesive labels. Those that say "Laser printer compatible". If you have an inkjet printer, print the labels with it, with the laser is more risky because of the temperature the paper needs to get in the printing process. If one label gets out of the support paper or the paper gets sticky inside the printer, it will cause a real mess.
Try inkjet first, or buy high-quality labels and print one full sheet at a time, not label by label.
Oct 28, 2009 | Brother MFC-7340 All-In-One Laser Printer
I often print individual labels, but not all at one time. As I continue to use the label sheet for additional entries the labels get grey looking. Is there a better way to do labels on the WorkCentre 7328?
It is not advisable to run labels in laser equipment without all of the labels on the sheet. The grey looking labels are due to a small amount of backround or build up put on all documents that run through a laser printing machine. Run it through once and you shouldn't be able to notice it, but run the same sheet through multiple times, and eventually you will be able to see the buildup, especially on thick paper such as label paper. What I would suggest is to pickup a cheap inkjet from walmart, and use it for only labels. They are more expensive to run, but with your low volume of useage you probably won't notice it. This will allow you to use labels 1 at a time, and if a label comes off in the printing process, it is much easier to find and remove then it is in a larger laser unit.
Aug 07, 2009 | Office Equipment & Supplies
Xerox 6280 - need to print labels on a sheet of 30 labels
Shouldn't be a problem, provided you use labels that are intended for a laser printer. Inkjet labels can wreck your laser printer (inkjet labels can't cope with the heat of the fuser in a laser printer).
Use the right template in your Wordprocessor package for the labels you are using (or create a custom label layout in your Word processor).
Use the Multi Purpose Feeder input tray (fold down from the front door), put the labesl face down, print (making sure that you tell the printer to use Labels and the MPF. It's important to tell the printer that you are using labels, as these are thicker, and need more heat from the fuser (especially if you are printing several sheets of labels, as this cools the fuser a little)
Jun 14, 2009 | Laser Phaser 6280v_n 25ppm 256mb - XEROX &...
Photosmart C4280 all-in-one. Problem is only with label paper. It prints 3/8" too high throwing everything out. If I change the original, it is fine for three or four sheets but then changes again. It...
You've probably tried this, but I did have success today with Avery 8160 labels. I had been using 5260 labels. There is a difference at the top of the page in the way the backing lines up with the labels.
Nov 30, 2008 | Office Equipment & Supplies
How to make labels from EXCEL list?
Im not really familiar how to make label on Excel but you can try this steps that works on words:
Please follow the steps below to print Business Cards or Labels in Microsoft Word.
1) Click on TOOLS.
3) Click on the LABELS tab.
4) Click on OPTIONS.
6) Under product number select the label type that you are using. If you are using Avery labels, select the number that coincides with the number on the Avery package.
7) Click on OK.
8) Click on NEW DOCUMENT.
9) This will give you the layout of the document format on your screen.
10) Type in all the information you need on one label.
11) Once the label is completed, highlight that whole label.
12) Click on EDIT, COPY.
13) Click on the next label.
14) Click on EDIT, PASTE.
15) Paste the information on all labels until page is completed.
16) Print your labels.
With this procedure, you do not need to modify the page setup or printer driver properties.
Hope this help, pls rate as fixya if this helps. Thanks!
Jun 26, 2008 | Computers & Internet
How to create mailing labels in Microsoft Works
With a Microsoft Works Word document open, select: Tools>Labels>(the list of available label types will pop up, select the label sheet you're using) then select: Tools>Mail Merge>Open Data Source...
Don't know how it could be simpler.
Dec 18, 2007 | Microsoft Works 8.0 for PC
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
