Question about Dell 922 All-In-One InkJet Printer
Power button light is permanently on but printer is not working
Power button light is permanently on. No information in display (blank). Printer dosn't work at all. Computer indicates, that printer is not connected. All cables plugged in.
Need help.
  • 1,555 Answers
Remove printer cable from pc. Remove power cord from printer. remove cartridge clean it and re-install. connect again it will work fine.
Posted on Jun 20, 2009
Hp laserjet p2055dn blank display
Similiar Blank Display solution from HP web site:
HP LaserJet P3005 Printer Series - Blank Display
ISSUE: Printer has a blank display.
SOLUTION:
Check if the printer is connected directly into a wall outlet. If not directly connected, power off the printer and connect directly to wall outlet.
Disconnect any local or network connection from any device and keep the printer connected with the power cord cable.
Power cycle the printer. If the issue persists, continue with step 4. If the printer powers up to READY, perform the following steps:
Print a configuration page and check the firmware version. If the printer does not have the latest firmware version, upgrade the printers firmware. Click here to see the latest firmware available for your printer at www.hp.com/go/support . Select Download driver and software (and firmware) and type in the product name or select the product from the product category list.
When the firmware upgrade is completed, power cycle the printer and print a configuration page again and check firmware date code, (it should change to the latest version) then power cycle the printer again.
If the printer powers up to READY, plug the local or network cable back in and print a Windows test page by printing from any application.
If the issue persists, continue with step 4 below.
Remove any additional memory DIMM installed (usually the LaserJet P3005N, DN and X come with a 32 MB memory DIMM installed), and any Internal EIO card or internal hard disk installed and then power cycle. If the issue persists, continue with the next step.
Perform a cold reset:
Turn the device off.
Turn the device on. When the memory count begins, press and hold the check button. Continue holding down the check button until all three device control-panel lights flash once and then remain on. This might take up to 10 seconds
After the message SELECT LANGUAGE appears on the display, press the arrow up or arrow down buttons until COLD RESET is highlighted.
Press the check button. The device performs a cold reset and then continues its power-on sequence.
If the issue persists, continue with the remaining steps.
If the printer powers up to READY, test the printer functionality by printing internal pages. Plug the local or network connection in and test the printer from the workstation.
If the issue persists without any internal device installed, the printer will require service.
Contact HP support.
Click here for information on contacting HP support at welcome.hp.com/country/us/en/wwcontact_us.html.
HP LaserJet P3005 Printer Series Blank Display
Apr 09, 2016 | HP Office Equipment & Supplies
Initializing
NVRAM Initialization:
1. Turn the printer off.
2. Press and hold down CANCEL (X) and Start Copy (button just below the X button) buttons at the same time while powering on printer. *Keep these buttons press while you power on the printer*
3. Continue to hold down buttons until the printer display reads PERMANENT STORAGE INIT.
4. Release the buttons when "PERMANENT STORAGE INIT" is displayed. Printer will return to Ready automatically.
Dec 12, 2012 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
My HP M2727nfs prints blank pages. Even demo page / reports are blank. NO errors on display. Paper gets warm, so fuser works. New cartridge doesn't help. Neither cold reset. What can this be?
This is a problem with either the formatter board or the dc controller, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years.
Al
Sep 14, 2010 | HP Laserjet M2727nf Multifunction Printer
My problem is a weird one. My family has had a Photosmart 3310 All-In-One printer for a while now (I'd say about 3-4 years), and it's worked fine until recently. Now, the light is on around the on button,...
Hi, I suggest you do a full system reset on the printer and see if that fixes anything. Please do the following. Come back and check with me if it doesn't work.
Performing a semi-full reset of the All-in-One
  1. Use the Power button to turn on the product.
  2. Unplug the power cord from the back of the product.
  3. Press and hold the # button and the 6 button.
  4. While holding the buttons down, plug the power cord into the back of the product.
  5. Continue to hold the buttons down until the control panel display goes blank.
  6. Release the buttons, and then use the Power button to turn on the product. The reset information appears on the control panel display.
Aug 12, 2010 | HP Photosmart 3310 Printer
When printer is turned on it reads 256MB and that is it. No menu buttons or anything else will work. Never get ready light.
First, try to unplug and wait 30 sec. then replug the printer into the wall to try to reset it. Then, read below to see if there is a solution if the '256mb' display problem persists. Control panel display is blank No display message Cause Solution The printer’s on/off button is in the standby position. Verify that the printer is on. Fans might run while the printer is in standby mode (off). The printer’s memory DIMMs are defective or installed incorrectly. Verify that the printer’s memory DIMMs are correctly installed and are not defective. The power cord is not firmly plugged into both the printer and the power receptacle. Turn off the printer and then disconnect and reconnect the power cord. Turn the printer back on. The line voltage is incorrect for the printer power configuration. Connect the printer to a proper voltage source, as specified on the Power Rating Label on the back of the printer. The power cord is damaged or excessively worn. Replace the power cord. The power source receptacle is not working correctly. Connect the printer to a different power receptacle. Printer is on, but nothing prints Cause Solution The printer’s Ready indicator light is not lit. Press STOP to return the printer to the Ready state.
Jul 14, 2010 | HP LaserJet 4700 Printer
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
I have an MP530 printer - error message 5C10 is
You could try resetting the printer:
1) On the panel, press and hold the <On/Off> button until the display goes blank (approx. 1 second). If the display does not go blank, unplug the power cord.
2) Wait approx. 10 seconds, plug in the power cord (if removed in previous step), press the <On/Off> button to power on the unit.
3) Wait for the printer to cycle through its startup routine before trying another print job.
I hope this helps!
Jan 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
My M2727nf does not always power up. Sometimes the display lights will work too.
This is due to a formatter failure.
Try an nvram
Try doing a hard or reset or nvram:
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp, if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Sep 24, 2009 | HP M2727NF Laserjet Printer
Dell 922 All-In-One InkJet Printer Logo
96 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
