Question about Garden
My 2005 cub cadet lt1042 will suddenly lose all elctrical power and die. I've checked all wiring harnesses etc finding nothing. Sometimes the power comes back on its own sometimes after pushing it back to the barn any ideas?
  • 218 Answers
Hi..my name is Keith..and it sounds like you have moisture in a safety switch..or the safety switch is just faulty or it is misadjusted..both the reverse safety switch and the seat safety switch will cut cut all power off..and the only other thing i can think of..is maybe a bad or faulty ignition switch..i hope this will help
Posted on Jun 30, 2009
I have a LT1042 cub cadet The wire got ripped off the PTO but mot at the PTO but wherever they go from there.
Chuck, you will have to find where it is broken at and see if you can get it spliced back together. if it has been ripped out of the clutch under the mower it will be an expensive repair. you can follow the wires and you will see where it is broken. sometimes the come unplugged under where they go through the frame.
Apr 14, 2018 | Cub Cadet Garden
How to change a pto clutch on cub cadet lt1042
remove engine hood and side shrounds front grill the you have the pto exposed loosen up belt by unhooking the deck then get you a good impact gun 3/4 inch find the socket that one put on impact wrench remove the bolt and only does this job with impact wrench unhook the wireing harness from clutch it should slid off if not tap with a hammer to get it off make sure there no more bolts holding it on reinstall in reverse
Aug 31, 2014 | Cub Cadet Garden
I need part no. for manufacture date 2005 cub cadet lt 1045 modle ps-sv600 0009 pto clutch
I have a 2005 Cub Cadet LT1042, Spec. No. PS-SV590-0003, but my parts manual also lists part numbers for the LT1045. The clutch part no. given for your model is 717-04174.
Hope this is helpful.
Paul
May 10, 2013 | Oregon Scientific Electric PTO Clutch for...
Cub cadet lt1045
Did you check voltage on the battery, and did you leave it running at a high idle? (low idle can consume battery voltage instead of charging it.
On many tractors the lights do not run unless the motor is running so don't let that throw you off.
Things to check
Make sure no fuses popped.
Makes sure you have gas
Try jumping it to see if it starts If not, it sounds like you may have a short, or may have a safety switch that is acting up. look for loose, broken, damaged wires.
Check to see if any wires are hot when the battery is fully charged. Try that and repost what you do or don't find.
May 07, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Pto will not engage on lt1042
check for power and ground going to the clutch if so look under the machine i have seen a few break the wires near the clutch
Jul 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet LT-1042 blades spin when motor is turned on, pto lever does not turn on or off blades
sound like you have some wires shorted out follow the wires from the clutch back to the switch
Apr 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Garden Logo
148 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
