Foot pedal and trolling motto don't alien synchronize
SOURCE: Wring for trolling motor
just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
SOURCE: new MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
SOURCE: Foot pedal on Motorguide is out of time with steering...
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
SOURCE: I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
