Question about Canon MV600i Mini DV Digital Camcorder
I would like to connect my Video Camera to the Telly to play the recoded tapes my Camera is a Canon MV600i where do I fit the connecting cable on the camera as I have lost my manual??
  • 999 Answers
Is there a AV OUT on the side/front? The yellow is the video and the White/Red are for the audio.
Eric
Posted on Jun 20, 2009
Transfer DV video from my Canon MV600i to the my Toshiba Computor
Purchase a firewire card for your pc and a 4 pin to 4 pin firewire cable.Install card,start edit program....click capture video make sure sam is on 'Play mode'
Feb 01, 2013 | Canon MV600i Mini DV Digital Camcorder
I have a Canon 7.4V video camera and want to connect my camera to the computer. How do I do that?
Instructions:
  1. Connect an i.LINK (firewire) cable (also known as IEEE 1394) to the i.LINK port on the digital camcorder.
  2. Connect the other end of the i.LINK cable to the computer. NOTE: The computer i.LINK ports and capture cards may have either 4-pin or 6-pin connections. If your computer only has a 6-pin i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
  3. Turn on the digital camcorder by moving the POWER switch to the VTR position.
  4. Cue the camcorder tape to the beginning of the video footage.
  5. Turn on the computer. Your computer should recognize your camcorder and automatically install the needed driver.
  6. Start the video capture software on the computer.
  7. Begin playing the recorded video in the camcorder.
  8. Begin importing the video with the capture software. It should now be possible to copy the video using the video capture software if the computer hardware and software are configured correctly.
Hope this has helped you.
www.austintelstarservices.com
Sep 04, 2010 | Canon Video Cameras
Pink lines when i play back my tapes on my canon zr500
Hopefull your not going through the tv and then to your dvd recorder
transfer should go straight from your camera to the dvd recorder.
you may also want to but a head cleaner for a mini dv camcorder,run it twice and try recoding again.If that doesnt work,you may have a problem with the heads inside of the camera.If thats the case,it would need to go to canon or an authorized service center.
Feb 01, 2010 | Canon ZR500 Mini DV Digital Camcorder
Downloading Canon ES8600 Hi8 movie to Macintosh
Just connect the camera to you Mac by using Firewire.
Apr 07, 2009 | Canon ES8600 Camcorder
Canon uc-1 video 8mm camcorder
Yes it can be fixed, but Canon is not the easiest to work on. Is the connector loose at all? The audio head may be dirty. This is not on the spinning heads. If you look inside and locate the pinch roller (rubber roller), there should be a silver head that looks like a cassette tape head. Try cleaning that using a cotton swab and alcohol. See if that resolves the problem.
Keep us posted.
Dan
Jul 23, 2008 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
Transferring hi8 tape to Everio hard drive
I play the hi8 video back to the T V lcd 32 screen
Because you video in not in digtal format
From the Telly i set up the try pot install the camcorder jvc 30
everio zoom in to size start the camera camcorder
for video start the hi8 video in the telly pres the recorder
on camcorder and record. This is the way the piratcy is done in the Cinamas
corra
Jan 03, 2008 | JVC Everio GZ-MG130 Camcorder
Canon MV600i - Only recording sound, no picture displayed or recorded
Have you cleaned your drum lately. purchase a soft head cleaning tape and run it through there for 20 secs if that doesnt work then you need to send it in for repair.
Dec 24, 2007 | Canon MV30i Mini DV Digital Camcorder
Connecting zr85 to vcr to record vhs tape to dv or sd card
I also have a Canon ZR-- left of the lens and the built-in microphones, there is a small panel that opens to reveal several ports. The middle yellow one is the AV In/Out. You can plug in the cable that came with your camera. One end looks like a microphone plug, the other has 3 RCA type plugs- red, white and yellow. These get plugged into your VCR's OUT plugs on the back of the VCR. Place a tape in the camcorder, open the LCD panel and push the REC PAUSE button. On the VCR, press the Play button. When the tape reaches the point you want to begin recording, press the camcorder's Play/Pause button. When you want to stop recording, press the Stop button on the camcorder.
This is also detailed on page 82 of your manual, manuals are available online at Canon.com. Your specific manual is at: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=174&modelid=9739#DownloadDetailAct
Hope this helps.
Nov 20, 2007 | Canon ZR85 Mini DV Digital Camcorder
Connection
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer. DV connections (IEEE1394 connections) Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board. You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer. Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer. If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software. You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site. Making the connection Connect the camcorder to the computer as shown in the figure below. The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used. Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal. Precautions (1) There are cases where the connection may not work correctly, depending on your system specifications/settings. (2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions. (2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer. (2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable. (3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Canon MV600i Mini DV Digital Camcorder Logo
128 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
