Question about Toshiba CF36G55 36" TV
How to adjust the vertical size and position on a Toshiba CF36G55
How do you adjust the vertical size and position on a 36" Toshiba CF36G55? Does this set have a setup menu accessible from the remote? Two other sets in this series are the CF27G50 and CF32G50. It's a great set and aside from a small cold solder joint problem and bad buttons on the remote it has performed fantastically. My local TV repair shop even said it was a great set.
4 Suggested Answers
andyroid85
  • 7 Answers
SOURCE: Toshiba 32a32 chassis tac 245 powers up for 1 secopnd then red power light flashes.
just fixed one with that problem it was the vertical output ic Q301
that was shorted. try wicking it out. it is a LA7833S.
Postings say to be sure to use the Toshiba part
Posted on Aug 28, 2008
Tritronic
  • 5 Answers
SOURCE: TV Toshiba CF32G50
I think you have a vertical problem. Turn up screen voltage to see if there is a tin horizontal line across screen. If so replace vertical output IC and the 100uf/35v capacitor in the vertical circuit.
Posted on Nov 13, 2008
  • 111 Answers
SOURCE: No image on a toshiba Cf27g50
If it is a vertical line, change the horizontal output transistor + capacitors. If it is a horizontal line, replace vertical output transistor + capacitors. Both cost around $10-20.
Posted on May 21, 2009
How do I adjust the Vertical size or position?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 23, 2016 | Zenith SY2765S TV
Tip
SERVICE MODE AND ADJUSTMENTS
Accessing Self Diagnostic Menu
1. While LCD TV set is on standby mode, press the following
sequence on the Remote Commander key. (RM-GD020)
For more check the following link. Use the search tab on the top right corner on the page to find your product.
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 18, 2015 | Sony Kdl-32cx520 32" Full Hd Multi-system...
Toshiba cf2662b the picture is "squished" Hoe do I adjust the vertical size and linearity? Thanks.
Most likely your tube is burning out. If there are any adjustments at all to fix this it will be in the menu under picture setting.
Mar 02, 2014 | Televison & Video
Picture adjustment
if your vertical section of your mother board has a vertical adjustment trimmer, adjust it to reach your desired vertical size..if doesn\'t have, increase the resistance of the resisitor only connecting from cold ground to the negative of the e.cap and the positive pin of e.cap connecting to the line 1 of the vertical focusing coil. the common value of the resistor you would focuse is 1ohm, try add with .5 or 1 ohm depending with vertical size result.
Jan 03, 2014 | Televison & Video
Laptop screen not centered
Did you replace it with an identical part? Should work fine if you did. I would contact Toshiba tech services for guidance on this matter. Have you tried it with an external monitor?
Sep 18, 2017 | Toshiba Satellite Computers & Internet
I want to adjust my screen , its is streching vertically Please help
Look for "buttons" on the bottom-front or bottom-edge of the monitor.
One button will activate the OSD ("On Screen Display). Through the OSD, you can change the "vertical size" and "vertical position" of the display.
Feb 03, 2010 | HP L1955 19" LCD Monitor
Picture off center on Toshiba 46" rear projection HDTV
On some models there is a picture position setting. One for horizontal and one for vertical. Don't mess with convergence, that probably won't help. Older models use knobs; new ones use the menu. Either way, you are looking for position adjustment.
Older sets, for each there should be size, hold, and position. Same for menus but it may have a picture that looks like one square offset on top of another.
Good luck. and if you need more help, please state the model #
Ken
Jan 01, 2009 | Toshiba 42H81 42" Rear Projection...
Picture is cut off on the bottom of my Hitachi 57F500
Verical position is hard to adjust and is in service menu. A service manual will get you there, but you might get lucky with the vertical size adjustment. If you open the front of the TV, the vertical size is adjusted with a knob on the deflection board. Remove the speaker grille and take off the access panel. You will see two knobs, one horizontal and one vertical. Be careful, those red wires have 30,000 volts on then, don't touch anything but those knobs. If its just an adjustment, the v-size knob will fix. Set it so ESPN ticker is just above the bottom of the screen. *Service mode - the manual tells little but entering is done by "press and hold the input button, press the power button, release both after you hear HV come up" .. the v-pos parameter is in there, but this manual doesn't say where or how to adjust, procede at your own risk. If you get into trouble, pull the power so you don't save any settings. I believe you just navigate through the menus to find the parameter and use arrows to adjust. Enter may save. Sorry the service manual I have tells nothing much.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
Display adjustment
hi there, bottom adjustmet means a vertical section control adjustment. a vertical size, vertical position control adjustment. do some check up on users control manual adjustment. ty
Dec 29, 2007 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
Televison & Video Logo
119 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
