Question about Dometic Refrigerators
Inop on ac electric
My camper was jolted with 240v recently (only wants 125v 30a). Besides the microwave not working the dometic 2807 refridge doesn't come on with ac applied. It works fine on gas. Is there an overvoltage circuit breaker/fuse that might have popped? Any other thoughts? Thanks for your help
I have a 1998 starcraft constallation none of my 110v plugs work but my 20amp plug for air conditioner works ?
Posted on Jul 16, 2009
  • 999 Answers
There should be fuses/breakers in the converter box. It sounds like the DC circuit is ok but the AC portion is still out. Eric
Posted on Jun 20, 2009
Coleman Mach 48000 series roof top A/C in my camper & recently it's been dripping heavily inside the camper. We looked at the top & inside for a clogged line & can't find anything, suggestions?
I had the same problem but it wasn't a clogged drain line, it was the gasket between the roof of the camper and the AC unit. The gasket had shrunk and pulled apart allowing rain water in. To make sure you don't have a clogged drain line when using the AC do you notice water dripping off the camper anywhere besides inside? You should have some drips somewhere on the outside.
Jul 18, 2017 | RVs
Dometic AC B59516.711 15,000 BTU, while on generator power the AC works during day while it hot but once the sunsets and it cools down, compressor kicks on it drags the gen down and shuts it off.
something else besides the ac is stopping ( overloading) the genset
if it works well during the day, the compressor has to be working so the ac is not the problem
a 4000 watt gen set has a duty cycle load of around 3000 watts full time so any additional power requirement besides the ac will overload it
electric stoves , microwave ovens , hot water elements , anything that consumes power after dark will when combined with the ac will overload and shut down the gen-set
Jun 26, 2017 | Electrical Supplies
Ac is turned off at themostat and breaker but keeps clicking
Was any of the electrical besides the A/C on the RV recently worked on?
Nov 06, 2011 | Dometic Rooftop RV Air Conditioner
I have a 1994 Carri-Lite 633RKS camper with electrical problems
The clicking your hearing from the AC is probably just the 12 volt side of the circuit to run the AC, but it does indicate that the controls/thermostat is doing it's job, but doesn't sound like hydro is getting to AC as well as microwave. I can't imagine those being on the same circuit as far as breaker panel goes, but who knows what might have been done before you got it, unless bought new. Do you by any chance own a plug in circuit/receptacle tester, or anything like that to test for power? In the meantime, make sure AC is in off mode, then go to breaker panel & push breakers for microwave & AC, all the way off hard, then try to reset it & tell me what happens.
Sep 04, 2009 | Coleman Heating & Cooling
Dometic rv air conditioner over 100 deg. trips breaker.
The problem is that when u add up the electrical draw from all of these appliances running full bore, your draw exceeds your available amperage. Now you are doing the math and saying no...... Let me tell you why. It is rare to find a situation where a 100 amp service actually porovides 100 amps. You almost always have voltage dropo. And when you are adding extension cords to the mix the drop is even more. That said, When you are using the AC try to minimize the use of other appliances, especially the microwave which is a big draw too.
Jun 25, 2009 | Dometic Rooftop RV Air Conditioner
I connected our Dometic 2620 to propane line, no problem, but when I plugged it into power - nothing. No lights, no gas activity, nothing. Any hints?
Check your AC breakers, mine was on the same circuit with a GFI outlet that had tripped, took a bit of looking to find it, Good luck.
Jun 13, 2009 | Dometic RM2620 Refrigerator
Furnace won't turn on, off, with or without remote
We hotwired the thermostat wires and the furnace started. That told us that the problem was with the thermostat. We took our remote control to another camper like ours and our remote worked their furnace. That told us that the problem was in the ceiling control for the furnace/ac. But the man who owned the other camper told us that he had a problem, too, and was told to unplug all the electric including the battery, wait 2 minutes, and hook up again. This might reprogram the circuitboard, and voila! It worked.
Feb 08, 2009 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
182 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
