Home | Dell | Latitude D600 PC Notebook | Dell latitude D600 bat...
Dell Latitude D600 PC Notebook
Problem for Dell Latitude D600 PC Notebook
Dell latitude D600 battery charge light flashing
By daa1 on Nov 02, 2007
My Dell laptop's battery used to work properly and charge and show a green light flashing while charging. Now I can't get the battery to charge and when it is plugged in I am seeing the charge light flash orange quickly 4 times, followed 1 longer green light flash.
The computer appears to work fine while plugged, but won't work when it is not "plugged in".
Same Problem
May 16, 2009
-   my dell d600 keps flashing red 4 time fast then one slow green flash even when on charge-   raechelt86
Apr 27, 2009
-   I have a Dell Latitude D610and it is doing the same thing. The battery light was working normally until the battery ran completely out. Now the battery charges (to full power), and the computer works on both battery and outlet power - BUT the red warning light flashes when ever the computer is turned on - and even when it is turned off IF the power cord is plugged in.
We ran a diagnostic test on the battery and it said everything was normal. We ran the battery down again and also recharged it. Still the red warning light flashes incessantly.-   smonfor
Apr 21, 2009
-   i have inspiron 1525 laptop and when i work with the battery it is not working it shows 3 times orange and one blue and after some time that also goes off. when it is directly plugged in it is working.-   beena_veni20
Apr 17, 2009
-   I bought my Dell Latitude D600 used on ebay in January 2007. It had a bad battery in it when I received it. The seller sold it as is, but did not state this problem as part of the sell. Typically, this laptop runs hot. I have had trouble with it crashing as well as booting it the past couple days. Now, the battery light flashes green slowly. (No amber or red flash). It had never done that before. My computer wouldn't boot. I checked with the Dell battery replacement website and inserted the numbers on my battery. The result was "No replacement needed" which I did not understand. After reading this string, I took out the battery and left it out. Now, the battery doesn't flash while I rely completely on AC power. So, should I simply buy a new battery? Should I buy a cooling deck? Do these really prolong the life of a laptop? -   area15co
Apr 15, 2009
-   I have the exact same issue as in my battery indicator blinks with 4 consecutive redand one long green and continues.
I would like to know what it means. However my laptop works even if I unplug the power chord.
-   san802k
Best Solution
posted on Feb 14, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I removed my battery while the computer was running and it fixed it
Solution #2
posted on Nov 26, 2007
Helpful)
EUCT
Rank: Master
Rating: 93%, 77 votes
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
Was this helpful?
Yes
No
21 people thought this was helpful
Solution #3
posted on May 30, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The battery wasn't the problem for me, but the charger. I changed it and now it works!
BR
// Patrik
Solution #4
posted on Feb 25, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
***IT ALL DEPENDS WHEN YOU REMOVE AND REINSERT THE BATTERY***
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Solution #5
posted on Oct 06, 2008
Helpful)
drapper25
Rank: Apprentice
Rating: 90%, 12 votes
(Dell D600 battery light flash problem fixed) I had the 4 orange/red flash and 1 green flash dashboard battery indicator light dilemma and fixed the problem!! - By unplugging the AC power cord and allowing the battery to completely drain out. I even restarted the computer to drain out any residual energy the battery might have contained to ensure the beast was dead. After doing so I plugged the AC power cord back in, started the laptop and the light no longer flashed like a banshee. It is now recharging and doing fine. Thanks to the person who posted the solution earlier on this forum(whoever you are). Jon
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #6
posted on Dec 30, 2008
Helpful)
OldDave62
Rank: Guide
Rating: 84%, 7 votes
You have a bad cell or cells and it needs to eventually be replaced. Meanwhile, you have diminished battery capacity. When you're tired of it as am I, simply remove the battery and take your chances with a power failure and data loss or place a piece of black tape over it. It will soon give it up all together. Mine has always ran hot even with the battery recall from Dell awhile back.
I believe it's a characteristic of the 5100. No other laptop I have ever owned runs this hot on either the battery, hard drive or processor sides.
These are available for either $150 from Dell or $80 from other sources. Google it. Dave
Was this helpful?
Yes
No
Solution #7
posted on Jan 05, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
You could buy a new battery for anywhere between $40 and $80, as Beni S-P (Guru) suggests, but the tip provided by EUCT (Apprentice) did the trick for me and was FREE!
Solution #8
posted on Mar 09, 2008
Helpful)
btfire911
Rank: Apprentice
Rating: 83%, 6 votes
i also had this problem. notice i said had. This is what i did to fix it.
1. Let the battery run completely dead. (Make sure all your work is saved)
2. Fully charge battery (You may still have flashing lights but if you turn your computer on and enter BIOS you can see the charge level)
3. Once again run battery dead.
4. Remove battery and wait 5-10 minutes.
5. Replace battery and use in normal operation.
This worked for me.
Also a note on why it sometimes does not fix even with a new battery. It seems that the battery is holding a charge but the level indicator is not properly communicating with the computer, therefore getting an error code. If you purchased a new battery, this process should clear the error.
Hope all works out for everyone.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #9
posted on Nov 03, 2007
Somewhat Helpful)
Beni S-P
Rank: Guru  Dell Expert
Rating: 85%, 2318 votes
Just buy new battery sir
Was this helpful?
Yes
No
Solution #10
posted on Oct 10, 2009
Very Helpful)
Pankake
Rank: Apprentice
Rating: 100%, 1 votes
If you check the battery and lights 1, 3, and 5 flash 3 times then the problem also may be solved by removing the power plug and switching on the pc set the power options on battery to always on and discharge the battery, when the machine shuts it's self of restart it and keep restarting it (quite tedious this bit, I used a usb cup warmer to drain the battery faster) the boot progress bar should get about half way, keep restarting it eventualy the system will go to full boot, shove in the power plug and recharge your battery, don't forget to reset your battery setting in the control panel, n.b. when i did this i did try to access the bios about 2 resets before it eventually started but I do not think that had any bearing on the resolution, but do let us know.
Denys
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #11
posted on Jul 03, 2009
Very Helpful)
kevinseifert
Rank: Wiz
Rating: 89%, 16 votes
I have a Dell C600 Latitude. I had two batteries in the front bays. I had the 4 amber/ 1 green flashes on the battery light. I pulled out both batteries while plugged in to the ac adapter. Pushed the test button on each battery. One showed 3 bars. I plugged it back into the laptop and the battery light showed solid green. I pushed the test button on the second battery. The first, center, and last bars flashed. I put this battery back into the laptop and the 4/1 flash started again. I am assuming that this battery is bad.
Was this helpful?
Yes
No
Solution #12
posted on Jan 12, 2009
Very Helpful)
earlj
Rank: Apprentice
Rating: 100%, 8 votes
Amber-amber-amber-amber-green is a temporary battery failure code. It is usually caused by high temperature (either the battery or laptop are too hot) If this code persists, you most likely have either a bad battery, bad battery charge card (in the laptop) or bad brick (AC adapter)
Make sure you have a good connection at the power cord (where it plugs into the laptop) these things wear out over time and a short/bad connection could also throw the code.
I'd start by trying a new battery, you don't have to buy it from Dell (despite what they may lead you to believe) They all use 18650 cells with charge protection, most are the exact same as Dell's but with a generic label. There are plenty of reputable aftermarket battery manufacturers out there, some offer up to 2yr warranties (Dell's are 1yr) and may offer higher mAh ratings (for longer run times)
If you've recently replaced your battery you may need to recalibrate the system. Dell has some model specific programs to do this, but the easiest way I've found is to charge the battery overnight (don't worry if it doesn't read 100% the first time) and run the computer until the battery goes completely dead (turn off critical hibernate/standby settings) this usually needs to be done at least two times.
I used a video compression/conversion program to tax the CPU at 100% to make things go quicker and set the system to run in "maximum performance" mode to keep the CPU at top speed.
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #13
posted on Jan 24, 2009
Helpful)
SueJones
Rank: Apprentice
Rating: 92%, 3 votes
The battery is defective and is will be replaced by Dell. Go to http://www.dellbatteryprogram.com/ and put in the model number from your battery and if it is one of the defective batteries, Dell will replace it.
Was this helpful?
Yes
No
Solution #14
posted on Sep 07, 2009
Helpful)
cornmint
Rank: Master
Rating: 74%, 8 votes
You need a replacement battery.
Try to visit http://www.cheap-laptop-battery.co.uk/laptop-batteries/dell-latitude-d600-series.htm?PHPSESSID=5491a8a675470a9f0983627d848c9a15
Comments:
Was this helpful?
Yes
No
Solution #15
posted on Mar 01, 2009
Helpful)
knightknk
Rank: Apprentice
Rating: 80%, 5 votes
I have 4 batteries for my D600, the original one, you know how old that is, works fine, 5 lights on test, my brand new battery used to work but now does the 4/1 flash while charging and the laptop crashes when I unplug the power. All the other batteries are fine, I flipped them over and noticed that the bad one was made in China and the good ones were made in Japan. Check your origin and let me know if you have tyhe same problem, another problem is, I dont remember where I bought it, so I cant return it. I got 2 more on ebay at a great price. robert@smithcruises.com
Was this helpful?
Yes
No
Solution #16
posted on Dec 19, 2008
Helpful)
leigon
Rank: Apprentice
Rating: 88%, 2 votes
your batteries are dying, this remove the battery while your computer is charging solution just stops the lights from flashing. The battery is holding little if any charge and needs to be replaced. Dell's replacement policy for batteries is only up to a year. Future advice is that one should not leave ones laptop pluged in to the ac adapter all the time, one needs to let the laptop run out of power every now and then to keep the life of the battery longer. Wish I had better news.
Was this helpful?
Yes
No
Solution #17
posted on Apr 01, 2009
Helpful)
seeandy
Rank: Master
Rating: 90%, 15 votes
Was this helpful?
Yes
No
Solution #18
posted on Jul 21, 2009
Somewhat Helpful)
ifufel
Rank: Master
Rating: 76%, 20 votes
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
17
Was this helpful?
Yes
No
Solution #19
posted on Jun 08, 2009
Somewhat Helpful)
RCRC
Rank: Apprentice
Rating: 75%, 1 votes
Check to make sure the that battery is seated properly. When mine was flashing 4 times amber then one green, I removed then reseated the battery, and it went to solid green (charging).
Was this helpful?
Yes
No
Solution #20
posted on Apr 16, 2009
Somewhat Helpful)
lilee221
Rank: Guide
Rating: 75%, 2 votes
If your battery can't work well, maybe you need a new battery and battery charger for your laptop:
Dell Latitude D600 battery in usa , Dell Latitude D600 battery in uk , Universal Laptop AC Power Adapter
Was this helpful?
Yes
No
Solution #21
posted on Feb 12, 2009
Somewhat Helpful)
dstevens_it
Rank: Apprentice
my suggestion is that the battery is dead to test press the indicator button on the battery and hold for 3 seconds at first it will show level then lights will go off then if any number of lights come back on this idicated via the following 1 if all lights are of battery is good if all lights are on the battery is dead and wont old a charge, any lights in between indicate approx life remaining
Was this helpful?
Yes
No
Solution #22
posted on Dec 31, 2008
Somewhat Helpful)
bradda19
Rank: Apprentice
Hi! I had the same problem with my Dell battery for Inspiron 6000. It happened when I left my laptop on the bed and went to answer the door and didn't go back to it for a few hours. It seem to get overheated. I hope that I have solved the problem by completely discharging my battery aand then putting the battery in the fridge overnight. It seems to be charging normally this morning. No amber flashing lights! Hope this helps you.
Was this helpful?
Yes
No
Solution #23
posted on Nov 03, 2008
Somewhat Helpful)
jufman
Rank: Apprentice
Rating: 75%, 3 votes
hay try changing the power cable from the wall to the ac box.
Was this helpful?
Yes
No
Solution #24
posted on Jun 27, 2008
Somewhat Helpful)
abey_matt
Rank: Apprentice
Most likely reason the battery (even a new one) is not charging is cos the power connector socket on the laptop has become loose from its solder on the motherboard. Take it to a tech who can open the cover and do a careful re-solder of that power connector.
Was this helpful?
Yes
No
Solution #25
posted on Jun 26, 2008
Somewhat Helpful)
budycole1
Rank: Apprentice
If your Dell Laptop does not charge, and you have noticed that u have a good battery, try power up ur Laptop with the battery in place and with AC power. then after complete boot up put ur Laptop on STANDBY you will notice that the green charging indicator is on and stable, thus ur Laptop starts charging.
Was this helpful?
Yes
No
Solution #26
posted on Jan 17, 2008
Somewhat Helpful)
Kr1spy
Rank: Apprentice
If removing and reinserting the battery does not work, you'll need to purchase a new one as Beni S-P suggests.
Was this helpful?
Yes
No
Solution #27
posted on Sep 29, 2009
Not Rated)
mike151
Rank: Apprentice
Rating: 0%, 0 votes
Hi World, I hope this helps the hundreds of people that i found on the net with the same problem I had. One day, orange battery light was flashing on Dell latitude d600. Power management in control panel showed battery not present, (it was installed) I swapped the battery & power supply to another computer & it worked fine. Spent 2 days taking apart computer & battery pack & could find nothing wrong. I gave up & returned computer down stairs destined to be permanently plugged in. The humidity down there had been high at this time of year so I had started the dehumidifier a few days earlier. After emptying the dehumidifier 6 times, (about 12 gallons) in 3 days and the laptop exposed to the same drying, I just slapped the battery back in on a whim & it started charging!
As I type this it is charging.. I hope this works for as many frustrated people (as I was) as possible. Good Luck Mike W. from Cleveland
Was this helpful?
Yes
No
Solution #28
posted on Apr 28, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same 4:1 red green flashing but the battery is working as normal i.e. it charges and allows me 2-3 working hours. The battery does not give an error in an identical laptop and the battery from the other laptop does not give an error in this one (so I swapped them)
Solution #29
posted on Mar 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
orange LED and green LED flashing 4:1, I think it is basically telling you that the battery is totally "dead" - has 0 charges. But somehow it is not charging.
I had this problem, and I went to buy a new battery, and the battery works on my computer but my computer doesn't charge it. So I always had to go to my friend's computer to charge it... don't know why.
Popular Solutions for Dell Latitude D600 PC Notebook
Questions and Unsolved Problems for Dell Latitude D600 PC Notebook
Do you recommend Dell Latitude D600 PC Notebook?
Answer
Answer
trying to get on texas holdem stops half way
Answer
I have a Dell Latitude D500, The problem however, is that a times, the laptop will not turn on... (More)
Answer
turn laptop on and the volume and rew or play does not light up when you press or when boot up.
Answer
Notebook Pavilion dv2000 black screen will not boot up
85 Other Users Have The Same Problem - Continued
Comment by mike_blomber, posted on Apr 14, 2009
my computer did the same thing for about a week the 1 green then 4 orange then it jjust died replaced the battery wouldnt start up at all bought a new power cord as soon as i plug it into the computer it kills the green light then nothing new happens wont turn on whatsoever i have about 3000 pictures music games from the past three years is there a way to fix it or at least get my files off??
Comment by nemoemo12, posted on Apr 10, 2009
Same As Everyone Else
Comment by rjblittle, posted on Apr 10, 2009
i have posted a problem like this
i have posted a problem like this about the battery
Comment by anne78, posted on Apr 08, 2009
Same thing happened to me...but after taking the battery out and putting back in...the lights stopped flashing and moments later the computer died. I was not able to charge anymore by plugging in...I have 2 power supplies and each time I would plug in the green light on those went away. After talking to Dell support it was determined something had shorted out in the computer and in order to get my info (hadn't backed it up in a while..sigh) I bougt the same computer refurbished online and swapped the hard drive.
Comment by Guest, posted on Apr 07, 2009
same
Comment by whit56, posted on Apr 04, 2009
my computer wont even fully turn on anymore it keeps telling me ac adapter unknown. i have my computer fixed before and it just keeps doin the same thing. can i get some help? please
Comment by Guest, posted on Apr 03, 2009
same
Comment by Guest, posted on Apr 01, 2009
same
Comment by Guest, posted on Mar 24, 2009
I've got the same problem with my Latitude D610 and the lower right hand (bottom) portion of the lapto is REALLY hot. I can't leave it on my lap anymore.
Comment by Guest, posted on Mar 21, 2009
same thing just outta the blue
Comment by rlowe3, posted on Mar 20, 2009
I have the exact same problem. If you remove the battery, the unit runs fine. However, if you remove the power cord, it dies instantly. I have replaced the battery once. My question is, is this a motherboard, charging system or a battery problem?
Comment by booholter, posted on Mar 17, 2009
charge light flashes and battery will not charge
Comment by Guest, posted on Mar 16, 2009
same thing - hoping I can flush to squeeze a little more life out of the batt
Comment by rcolonia, posted on Mar 14, 2009
Battery is not charging, the battery light is blinking 3 times orange, one time green. If I disconnect the charger, the battery runs out. When I reconnect the charger, QuickSet shows the message: "The AC power adapter type cannot be determined. This will prevent optimal system performance.", but this is the same adapter that used to work fine.
Comment by Guest, posted on Mar 10, 2009
When I try to charge my batteries, the computer first charges the main one and depletes the modular battery completely. Both batteries will be mostly charged (main ~80%, modular ~60%), but when I plug it in, the computer drains the modular battery while charging the main. After looking into this, I found a Dell page explaining that the blinking code meant a temporary malfunction, like an overheated battery. Sure enough, leaving the battery out for a while lets it charge again, but I have no idea why it drained in the first place.
Comment by Guest, posted on Feb 27, 2009
just brought new dell battery and now have this problem with the red flashing light! says its charging but soo as you remove power cable laptop crashes! dell inspiron 6400
Comment by sandiebower, posted on Feb 13, 2009
After many good years working properly suddenly the battery light (on the right hinge) is flashing amber. It flashes really fast four times then goes solid green for a longer period. It does this both when plugged up to AC and when running on battery power. Before this problem, It used to stay solid green until the battery was close to being depleted then it would turn amber.
Comment by Guest, posted on Feb 12, 2009
I have the exact same problem as this and occured out of no where just randomly
Comment by j4ckyboy, posted on Feb 06, 2009
mine is doing the exacky same thing flashing orange 4 times followed by a prolonged green light it happens weather it is plugged in or not.
Comment by simaA, posted on Feb 03, 2009
got the same problem except that mine is always orange and flahes continously. Laptop seem to work ok, slower than before though...
Comment by Ed johnson, posted on Jan 31, 2009
I have a D420 with same issue. I've had the laptop for 2 years, it just started this week.
Comment by Peachyykin, posted on Jan 13, 2009
I have the exact same problem! I was using my computer last night (I have a Dell 6000) and when I got the low battery warning, I plugged it in. Usually when I do this the orange light goes away. However, it started flashing 4 times orange, 1 long green and will not stop. I let it charge overnight and it works fine when plugged in. But that's not the reason we buy laptops is it? I will try the discharge and fridge idea to see what happens. But does anyone know WHY this happened? Linda
Comment by Guest, posted on Jan 09, 2009
Same problem (with 600m). I got the battery low signal, turned it off, plugged it in to recharge, now I get the 4 short amber flashes, then a longer green. The battery still seems to be charging - in fact it now says 100%, but the flashing signal continues. One more bit of information - I can press the battery test button on the bottom of this battery, and it flashes the left/middle/right 3 of the 5 green LEDs. If I hold down the test button, it eventually goes to 5 green, but it doesn't make any difference to the amber flashing, and it just repeats the same pattern on the next try. I think it indicates a defective battery cell. Nice of Dell to document this!
Comment by Nicolae_L, posted on Jan 03, 2009
It seems that i have the same problem. I have a latitude d610 model with a sony battery. i didn't unplug it yet because i don't want to see what it happens. this happend about one hour ago.. it flashed 4 times green and one long time green .. but after ~15 minutes it stopped doing that.. now .. after working and keeping it permanently plugged in for ~45 minutes it started flashing again ...
Comment by lamchop912, posted on Jan 01, 2009
I've had my computer for 6 1/2 years and have replaced the battery once. I'm not quite sure why this has started happening, but it won't stop... I'm thinking it's just a warning that the computer needs a new battery. =/
Comment by charitybaer, posted on Jan 01, 2009
Comment by bradda19, posted on Jan 01, 2009
I had the same problem after I left my laptop on the bed still running and I think it overheated. The lights drove me mad although my computer still worked. In the end I fully dischargrd the battery and put it in the fridge overnight and the following morning charged it again and hey presto problem solved! It's been ok ever since.
Comment by tochimatharu, posted on Dec 27, 2008
Lattitude D620 battery flashes 4 times orange and then 1 time green. Seems to work fine when running on battery alone but does not seem to last very long. Is it dying a slow death?
Comment by eoransky13, posted on Dec 27, 2008
Battery ran down to 0% recently. Battery is recharging to 99% but indicator is blinking 4 times amber and then 1 green. Any thoughts?
Comment by Guest, posted on Dec 19, 2008
same thing
Comment by zeetaher, posted on Dec 14, 2008
same problem d610
Started of as being a problem charging the laptop. Randomly the notebook would charge, it became harder and harder to get it to charge, eventually went out of town and when I came back, its showing 4 orange flashes and 1 green flash.
Comment by Emma No1, posted on Dec 07, 2008
Same problem - I have D505 and this just started 10 minutes ago - any ideas how to fix?
Comment by Guest, posted on Dec 05, 2008
d610 mine appears to charge but has the same 4 red 1 green just started 12/3/08
Comment by Guest, posted on Dec 03, 2008
My Dell D600's battery light does the same as others have described here - 4 red/orange flashes and then one longer green.
However, mine still charges despite this and operates for about an hour on battery. I tried another battery from a spare PC at the office, and exactly the same thing happens, which makes me suspect the PC has 'the issue' here, and not the battery...???
Comment by parnett, posted on Nov 20, 2008
I don't use the battery. My computer is plugged in at my office but shut down. I only use it about once a week. The battery light has been flashing 5 times red, one time green. What is the problem? Thank you.
Comment by Guest, posted on Nov 09, 2008
4 red lights 1 longer green light. I think that it is broke but i would like to disable the lights any ideas
Comment by smahl, posted on Nov 05, 2008
My Dell laptop's battery used to work properly and charge and show a green light flashing while charging. The battery shows 99% charged and when it is plugged in I am seeing the charge light flash orange quickly 4 times, followed 1 longer green light flash. The laptop won't run if it is unplugged.
I have the same problem - My Dell laptop's battery used to work properly and charge and show a green light flashing while charging. Now when it is plugged in I am seeing the charge light flash orange quickly 4 times, followed 1 longer green light flash. The battery is showing 99% charged but when I unplug the power, the laptop does not run.
Comment by daveknauff, posted on Oct 30, 2008
My battery light flashes all the time whether it's charging or not. I'm typing this running on battery, so the battery is not completely shot. But it is the same symptom: it flashes 4 times red, one time green.
Comment by Guest, posted on Sep 08, 2008
I have the exact problem - flashes red several times followed by one longer green flash. This has been going on for about a week now. I haven't used it on battery so I don't know how long it would last.
Comment by boyettsix, posted on Sep 01, 2008
My Latitude D600 wont charge the battery. It works well with the adapter and the battery. It just wont charge the battery! It is at 70% and I'm going to try and run it all the way down to 0 and see if that helps. ANY SUGGESTIONS ANYBODY??
Comment by Guest, posted on Aug 26, 2008
I fixed the flashing red light problem on my Dell Inspiron 600m by letting the battery completely discharge. I tried all the other ways mentioned in these posts and they didn't work. Note: to totally discharge the battery, you will need to disconnec the ac power cord and go into your power settings and change the default from "standby" to "shut down". Hope this helps. It drove me nuts for a week!
Comment by smidjal, posted on Aug 22, 2008
exactly the same problem... maybe battery failure? needs replacement or maybe clicked accidentally some button on the keyboard or on the screen?
Comment by Guest, posted on Jul 18, 2008
Will only work when plugged in.
Same light flashing sequence & colors.
Comment by sandeepgshet, posted on Jul 10, 2008
The computer appears to work fine while plugged, but will work for 5 to 10 mintues when it is not "plugged in".
Comment by shiva9, posted on Jun 23, 2008
I am facing the same problem with my Dell E1505. The battery meter shows, 98% and charging. I could able to swithc on only with AC adapter plugged in. Please let me know the solution. is my battery needs to be replaced?
Comment by Guest, posted on Jun 23, 2008
I have the same problem with my Dell E1505. Please let me know what to do?. The battery meter shows 98% and charging.
Comment by Guest, posted on Jun 10, 2008
Same as above
Yep, same here 4 orange flashes i green.
Comment by zephyr0310, posted on Jun 10, 2008
laptop battery wont charge, charge light flashing four times red and one time green. What is wrong?
Comment by Elpac, posted on May 29, 2008
Interestingly, I use the second battery that goes in the DVD slot so I'm able to use battery power, but for a much shorter period of time then before. Same green, 4 amber flash at all times - battery and plug. I tried using another users spare battery (again for the DVD slot), but the flashing continues....
Comment by Guest, posted on May 28, 2008
same problem
Comment by Guest, posted on Apr 30, 2008
My laptop always charged and worked well, I had no problem at all. Now that i push the battery plug in the laptop, the charging status shows me orange lights flashing and it would not charge.
Comment by Guest, posted on Apr 27, 2008
Same as above.
Comment by Guest, posted on Apr 17, 2008
battery test lights flash 1-3-5
Comment by Guest, posted on Apr 08, 2008
same as original desc.
Comment by Guest, posted on Apr 02, 2008
same as above
Comment by kirigs, posted on Mar 20, 2008
My dell laptop d600 will power well with adaptor but will not charge the battery. I have tried several batteries that are charging elsewhere. What could be the problem ?
Pman
Comment by Guest, posted on Mar 15, 2008
orange light flashing in the battery indicator
Comment by Guest, posted on Mar 14, 2008
i have an inspiron 600m. the battery charge light flashes from orange to green and the battery flashes three ambers when i check to see how much power still left
Comment by Guest, posted on Mar 11, 2008
my dell d600 battery does not charge. charging light flashes 4 times orange and once green.
Comment by Oscarin2056, posted on Mar 10, 2008
I have a problem wiht a battery dell Latitude D600. when I pu it charged it flash tree times in red a once in gress. What I can do for It?
Comment by bingogal, posted on Feb 22, 2008
my dell latitude cpx is doing the same 4 amber lights and 1 green 1 please help
Comment by Guest, posted on Feb 15, 2008
the charging light flashes orange and then green
Comment by Guest, posted on Feb 04, 2008
same problem
Comment by Guest, posted on Jan 27, 2008
I am not facing any problems but it is the flashing orange and green light 4:1which is bothering me. Do I need to change the battery
MB australia
Comment by daa2, posted on Jan 22, 2008
I bought a new battery, thanks for your input!
If I leave my dell latitude 600 plugged in after the battery is fully charged, is this "bad" for my battery?
How can I tell when it is fully charged? I think it flashes a green light while charging...
Thanks for your patience. I know these must seem like stupid questions!
Comment by Guest, posted on Jan 09, 2008
My dell laptop's battery used to work properly and charge and show a green light flashing while charging. Now I can't get the battery to charge and when it is plugged in I am seeing the charge light flash orange quickly 4 times, followed 1 longer green light flash.
Comment by colo7, posted on Jan 04, 2008
same
Comment by deb345, posted on Dec 30, 2007
I have the same problem. I understand the number of orange flashes should be a trouble shooting code but can't find that.
I've got 3 orange flashes followed by a green, and the battery won't charge.
Comment by cesarHUNT, posted on Dec 18, 2007
well i rebooted my latitued D600 and i dont even get a battery icon and only works when is plug in
Comment by Guest, posted on Dec 17, 2007
I have the same 4 orgen flashes and then ine green. please i nedd help on this.I have tryed new charge cords and no change. two new batts and no differance either.
Comment by Guest, posted on Dec 16, 2007
My battery indicator light flashes 3x red and 1x green. The battery will charge, and the computer will work on battery power only. The flashing light pattern occurs whether or not the computer is plugged in.
Comment by Guest, posted on Dec 11, 2007
I have a Dell Latitude D600 and the battery used to charge and show a green light flashing while charging. Now I can't get the battery to charge and when it is plugged in I am seeing the charge light flash orange quickly 2-6 times, followed 1 longer green light flash.
Comment by zomba, posted on Dec 06, 2007
i have a dell d620 its not charging. when connected to the power source a green light is followed by 4 flashing orange lights. i don't know what this means or what i need to do.
Comment by Guest, posted on Nov 20, 2007
I'm using the Dell Latitude D510 but the battery light always flash in red color when charging or using.
How can I stop it?
Thanks
Comment by wishbone17, posted on Nov 19, 2007
Does anyone knows "battery recalibration" for d600?
Comment by mrains, posted on Nov 15, 2007
The battery charge light flashes 4 times orange and 1 time green rapidly.
Comment by Guest, posted on Nov 12, 2007
orange light is flashing
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Latitude D600 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
