Question about Sanyo DP32746 32 in. LCD Television
Sanyo lcd model dp26648 has sound but no picture. Change the backlight inverter and also the main board. Screen is just white with no raster. The raster appears at times but the screen turnes back white. Need help with the ASAP.
  • ivan_rolle Jun 20, 2009
    Thanks for replying so quickly, some one else told me that it might be just a connection problem. I will check all the connection.
  • 3,230 Answers
It's possible the logic board got damaged, but most of the time this is only a case of connector badly inserted.
It usually happen after moving the TV (or if you just unpacked it). This usually require to open the TV and push on all the "things" that seem to connect to the LCD screen, follow any screen data cable or ribbon and ensure they are also well connected to the board.
The white on an LCD come from the relaxed state of the liquid crystals. In that state all the light is permitted to pass trough.
Because this is a end data path, no diagnostic monitoring detect this problem and power LED don't flash error code.
In that condition the audio is usually OK, another thing that point to probably no failure of any chip.
If you want to perform this yourself, be cautious, a TV have very high voltage inside it. You should also discharge any static you can have before performing such operation.
Good Luck!!
Thanks
Posted on Jun 20, 2009
Sony lcd tv model LDM 3000 blinks 6 times and no raster or sound
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Apr 17, 2018 | Sony Televison & Video
What part is needed to restore picture for Sanyo TV model #DP26648. Has sound, no picture
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Nov 08, 2016 | Sanyo Televison & Video
Sanyo FVD48P4 sound but no picture
Well. You're a technician I assume. You've done all that you know, and made it somewhat dump. Contact the authorized service center. This forum is not intented for making revenue for an other. OK?
Jul 11, 2016 | Sanyo Televison & Video
My flat screen has no picture but has sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jun 22, 2015 | Sanyo Televison & Video
Sanyo tv no picture hearing sound. picture goes out gradually. lines on screen. then black but still hearing sound
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 05, 2015 | Sanyo Televison & Video
What could cause a 27" Sanyo flat panel dp26648 to lose picture, but keep sound?
There are two reasons why your Sanyo DP26648 would has sound but no image and both are equally likely in our experience.
First, you may have a problem in the section of the power board that supplies the backlight module (called inverter) with 24V.
We've seen that several times and the problem is usually minimal - only electrolytic capacitors gone bad - and other times not so minimal.
We have a repair service for that power board and we may have some boards available too...check out at
http://www.coppelltvrepair.com/search?Q=DP26648+&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Apr 04, 2012 | Sanyo DP26648 LCD TV
Shows only white raster
Hi Check your t-con board. That is the board that transmits the signal from your signal board to your screen.
You can get parts at www.interliquidparts.com
Dec 10, 2011 | Sanyo DP26648 LCD TV
My new 55in sanyo lcd tv has sound but no picture. The tv is one week old. Is the problem the backlight or something else?
Tv only a week old take it back were u bought it,trade it in for another tv.Tv have a picture than flashes only a few sec. than died have sound left only?Yes,than those tv 2 long LCD inverter boards are dead.These tv 2 long LCD inverter boards are only to help the tv to have a backlight for tv LCD screen panel only to produced pictures.
Jul 14, 2011 | Sanyo DP46849 46 in. HDTV
Sanyo DP46848 has sound but no picture.
Tv turn now,have a flashes of picture a few sec.than dies have sound left only?Yes,than ur tv have a 2 long boards are dead that call LCD inverter boards.These 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
Dec 07, 2010 | Sanyo DP46848 LCD TV
Sanyo DP32746 32 in. LCD Television Logo
144 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
