Question about Brother HL 5150D Laser Printer
Brother HL 5150D printer has all lights flashing
After a power cut my Brother HL 5150D printer has all three yellow lights and the red flight flashing ... what can I do? ... who can repair it?
  • rich435 Jun 20, 2009
    Many thanks ... printer now working fine!
  • 1,555 Answers
Switch off your printer. Remove power cable from printer. Open upper cover remove cartridge and then re-install. Wait for 5 minutes. Connect power cable again and restart your printer. It will work fine.
Posted on Jun 20, 2009
Brother 5150d
1. Press the cover release button and open the front cover of the printer
(so you can see the toner cartridge)
2. Press and hold down the Go button until all 4 LEDs are lit. Once all 4
LEDs are lit, release the Go button.
3.Close the front cover.
4. Make sure that the Drum LED is now off
Mar 19, 2012 | Brother HL 5150D Laser Printer
I've replaced the toner and drum. Now the drum light keeps flashing. How do I reset it?
Try this
After replacing the drum unit, keep the front cover open (make sure the power is on).Press and hold the “GO” button until all four LED’s are lit.Once the four LED’s light up, close the front cover.Make sure the drum LED is off.The counter is reset!
Aug 11, 2010 | Brother HL 5150D Laser Printer
Error light flashes on printing process
This issue may be either with the Printer or with the Computer.
Re power cycle the Printer once and reinstall the Printer Drivers and Application.
Jul 13, 2010 | Brother HL 5150D Laser Printer
My hl 5150D will not print. when isend document
1/ Check waste toner may need empty. 2/ You maybe out of toner. remove toner and give it a good shake will get a few more prints usually. Need more info from you. Have you check paper paths. Have you rebooted both printer and computer. Remember you must remove power supply on both for ten seconds for true reboot.. Good luck
Oct 10, 2009 | Brother HL 5150D Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
Brother HL 5150D not printing unless I keep pressing Go
its not the problem of toner cartridge.its the problem of gears which pulls the paper they r worn out or may be cracked internally.exactly what happens when you u give the print for the first time the printer gets command and the gears starts spinning and the paper gets pulled because it gets a pressure internally and after 2 pages that pressure gets low and it stops pulling the paper.some times changing the paper thickness solves the problem temporvarily .i mean use the thick quality paper instead of thin.
Jan 08, 2009 | Brother HL 5150D Laser Printer
New drum and the copies are extremly light
Drum may be defective must be repalced.
When replacing drum, be sure to reset the drum counter for HL 5150D:
-Open the toner compartment door, and hold the go button for 5 seconds.
Nov 30, 2008 | Brother HL 5150D Laser Printer
All the light are red
1)either the toner is empty or not fitted properly. 2)either there is a minor paper jam or any small piece of paper is blocking the gears to move. 3)or the printer door is slightly opened or not fitted properly.
Aug 13, 2008 | Brother HL 5150D Laser Printer
Brother laserjet printer HL 5150D
because this unit you bought from UK ,first step I would like you to do is make sure this unit what kind power curency they using ia 220V, or 110V.
Oct 26, 2007 | Brother HL 5150D Laser Printer
Brother HL 5150D Laser Printer Logo
628 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
