Question about Zanussi ZWF1440 Front Load Washer
How to replace DOOR SEAl for zanussi zwf1421w
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
Apr 30, 2010 | Zanussi ZBQ365 Electric Single Oven
IS IT EASY TO REPLACE THE DOOR SEAL/GASKET ON ZWF1430W
it is very very difficult to replace the door seal on a zanussi washing machine, its best fitted by an engineer
Feb 03, 2010 | Zanussi ZWF1430W Front Load Washer
My Zanussi ZWF1421W has stopped taking the fabric conditioner through in the wash cycle - it remains in the drawer....
Zanussi ZWF1421W
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jul 30, 2009 | Washing Machines
Zanussi zwf1421w washing machine makes a rumbling/rattling noise when spinning.
Motor is kicking on and off making that noise....so far for us this has been a motor issue 9.5 times out of 10
CLICK THE LINK DIRECTLY.http://www.youtube.com/watch?v=EqeGv3B-3xw
May 05, 2009 | Zanussi ZWF1420W Front Load Washer
How do I replace the door seal on my ZWF1421W washing machine
Unplug the machine first! Open the door and look around th edge of the seal. You will see a plastic clip, where the two ends engage (like crocodile teeth), prise it out toward you with a flatbladed screwdriver. Unpeel the seal frm around the door. Hold the top of the seal inside where it is attached to the drum and lift it slightly, then just pull it off. You will see it is held on with a big circular spring. Getting the new seal on is a pain. It must lip onto the plastic outer drum and will take patience to feed it on, not to say sore fingers! Once on, fold it intowards the drum and then you have to stretch the spring back onto the seal...more sore fingers. Maybe someone can hold it while you feed it aound (make sure also you have fitted the seal the right way up!). Finally, attach the outer lip onto the lip of the machine and reattach the outer plastic clip. Good luck!!!!!!!!
Feb 18, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
ZWF1421W Zanussi Wasing Machine
Unscrew filter body and gently, using a pair of mole grips, wiggle and pull the filter body.
If this doesnt work the best option is to replace the whole filter assembly. You do not need a new pump though!!.
PS Cleaning the filter on a regular basis will help prevent this!!!!!
Nov 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi Washing Machine
At bottom left of machine there is a small metal flap where you can drain off water. Next to that is a grey pipe you can keep pulling and pushing i have done this quite a few time and it has let out sludgey stuff put washing machine is now spinning and draining. Good Luck.
Aug 29, 2007 | Zanussi ZWF1420W Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
1,582 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
