Question about SDI iHome iH5 Docking Station, FM Transmitter for Apple iPod (047532889017)
How do I set the clock on the ip9br ihome ?
I don't know how to adjestive the time on the ip9br ihome ?
IHome won't play Ipad it charges but says the accessory is not supported by ipad
the best iPad accessories Best iPad Accessories July 2017 The Gadget Flow you can get are on Gadget Flow especially for home kit compatible that you are looking for.
Feb 09, 2013 | iHome Clock Clock Radio for iPhone iPod...
My iHome iP43's volume stopped working when i replaced the dead +zero brand batteries with unused energizer brand batteries...what happened
Sorry! we have different skill levels and don't always include the specific problem you have encountered. It means we read your question but may not know the answer.
Aug 27, 2012 | iHome IP43 Desktop Clock Radio - Apple...
A few drops of fruit juice got under the volume wheel and dried. Now the volume wheel won't turn easily. How do I get the volume wheel off to clean underneath?
Electrical contactsupply cleaner is best. You canto try drops of rubbing alcohol, which will clean the wheel and evaporate quickly. While you add the drop/s, turn the wheel.
Jun 04, 2012 | iHome Clock Clock Radio for iPhone iPod...
The volume dial on my iHome is sticky and is difficult to turn. How do I unstick it?
I don't yet have the solution but I'll tell you this, it is not easy to get to. I'm an electrical engineer and had to unsolder parts to get the wheels off. I have it apart right now. I'm still looking for an appropriate lube for a plastic-to-plastic interface. Silicone didn't work too well. I'm thinking about trying powder graphite or plumbers grease. This is a bad problem and not an easy one to fix.
Nov 11, 2011 | iHome Clock Clock Radio for iPhone iPod...
My ip9 ihome will play music from my ipod touch but it will not charge it. What can I do to fix it?
there is no way to charge it and play it at the same time, unfortunately, iPod touch is not supported for that format, only the latest nano and below.
Jul 08, 2011 | iHome Clock Clock Radio for iPhone iPod...
My iHome keeps resetting the date, alarms, presets... everything! I fix it to how I had it, then two days later it resets itself again to January first, 2008..
Check that the power supply cable isn't broken. It could turn itself on and off by itself. If it has a battery backup use that.
Jun 05, 2011 | iHome Clock Clock Radio for iPhone iPod...
My ip90 wont turn on even in outlets that work ???????
Call the # in the back of the manual - 1-877-446-6301. They are aware of a faulty batch & will replace the unit. They will send you a UPS label to return it for free & they will replace it in a couple of days. Nice to have good customer service.
Feb 24, 2011 | iHome Clock Clock Radio for iPhone iPod...
Ihome ip9 will not turn on even with power chord attached. I have tried following what the manual says and unplugging it and that has not worked either. Any help will be appreciated
you might wanna try checking that the outlet actually works. try the outlet with something you know for sure works, like a lamp or something. if it works, then try the ip9 in a different outlet.
Mar 22, 2010 | iHome Clock Clock Radio for iPhone iPod...
SDI iHome iH5 Docking Station, FM Transmitter for Apple iPod (047532889017) Logo
261 people viewed this question
Top SDI Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SDI Audio Player and Recorder Expert? Answer questions, earn points and help others
