Question about MSI 845GE Max-L (MS-6580-060) Motherboard
No boot my computer msi 533 845ge max i update bios in windows not in dos mode, computer become hang and i restart computer no boot
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Hi...if you want to find the problem.open the unit then remove the memory then make a clean all pin connectors using paper eraser then put it back again..good luck and have a nice day..^_^
Posted on Jun 20, 2009
I have a Dell Laptop 17RSE 7720 that I cannot Flash the Bios on. I have not tried to do it using Dos. I get Error 216 or 105.
nice a full model stated, rare here. NO OS< windows 10?
Windows, 10 ,removed the DOS mimic DLL files so now we must use freedos if DOS is needed, so I ask OS used above.
No reasons stated, the Intel processor venerability issue? what ?
or hacking BIOS , the possibles are ENDLESS. DYK
did you use F12 sandbox install
or did you make USB with freedos on it.
why not go to dell first and not fixya we are not dell.
ok?
do not flash BIOS until you learn the risks, did you?>
do not do that, unless you:
1: must, (have real compelling reasons to brick a good working perfect pc, (repeat 3 times for effect). oops....a daisy.
2; make 100 % sure the flash binary you get matches the exact service tag model PC you own , i bet you did not ask Dell to tell you that exact file that matches what you own.
I think but am not sure(dell has decompression locks on the file)
but I think they have more one ROM binary inside thee 10MB file.
but be nice if they said that, (their lil secret)
DID you used F12 mode? to update?
and from what version to what version.?????
3: Dell does not have what I call EZ_flash, that is using BIOS to flash itself. (super safe way, if power is good) Dell runs scripts at next boot to load bios binaries, in sand box , F12 way.
the EXE file there:
I always look first, I trust no one, on any binaries.
the exe passes virustotal and malwarebytes.
But the exe is locked, out. (decompression)
I think I know why (UEFI rules again)
5: is your PC set up with UEFI BIOS?
and safe boot? off
bitlocker suspended?
why not talk here at dell on same topic.
why leave DELL>?
https://www.dell.com/community/Laptops-General/Inspiron-7720-Bios-Flash-from-A14-to-A17-error/m-p/4663974
One more problem. UEFI is H3LL
most makers OEM now block regression paths of bios.
so are you regessing ? trying to load, older BIOS version
you cant in most cases. did you? no before after stated. versions.
also learn that many PC, they upgraded UEFI like 10 times
and some you must do step by step, never v1 to v10 ok?
or it fails.
now some faCTS ON LAPTOPS.
Dell does not use Ez-flash, sadly is the best there is, not used.
this method has no possible way to multitask and fail.
the second most safe is running DOS(freedos is free) HP does.
The third most safe way is windows sand box. way. F12 per dell
and 4th flashing under windows live, is totally wrong.
never flash on any preemptive multitasking OS, live. do not.
may tired, many died (bricked forever)
this version>?
Version Version 1.11.1, 1.11.1 Category BIOS Release date 03 Jul 2018 Last Updated 03 Jul 2018 https://www.dell.com/support/article/us/en/19/sln129956/dell-bios-updates?lang=en
The normal Dell way under w10 , it creates install scripts in a file on your
hdd (not bitlocker'd) and then reboots w10 to sand box.
then w10 runs in special mode,(no it is not DOS) and this mode
safely installed the flash binaries.
if this fails or the HDD is missing (lol) or has linux loaded, you didnt say, then you can do this.
The below from Dell uses the word DOS in lazy way.
its not DOS, ok> DOS is MS product, or DRI, DR.DOS
Freedos is a modern version of DOS that runs on new hardware the real DOS (MS) can never do. ok?
I am told dell uses the w10 sand box method (w7/8/10)
I see dell ended this switch, -writeromfile
you can not extract the rom file.
this makes FREEDOS disk boot on the USB.
did you do this?
=-------------------------------------off dell ------------------------------
QUOTE: "
BIOS Update Executable for Windows/DOS
Download
1. Click Download File to download the file.
2. When the File Download window appears, click Save to save the file to your hard drive.
Run the BIOS update utility from Windows environment
1. Browse to the location where you downloaded the file and double-click the new file.
2. Windows System will auto restart and update BIOS while system startup screen.
3. After BIOS update finished, system will auto reboot to take effect.
Run the BIOS update utility from DOS environment if Legacy Boot Mode(Non-Windows users)
1. Copy the downloaded file to a bootable DOS USB key.
2. Power on the system, then Press F12 key and Select "USB Storage Device" and Boot to DOS prompt.
3. Run the file by typing copied file name where the executable is located.
4. DOS System will auto restart and update BIOS while system startup screen.
5. After BIOS update finished, system will auto reboot to take effect.
Run the BIOS update utility from DOS environment if UEFI boot mode with Load Legacy Option disabled (Non-Windows users)
2. Power on the system, then go to BIOS Setup by pressing F2 and go to "General-Boot Sequence - Boot List Option".
3. Change "UEFI" to "Legacy" of Boot List Option.
4. Click "Apply","Exit" to save changes and reboot system.
5. Press F12, then Select "USB Storage Device" and Boot to DOS prompt.
6. Run the file by typing copied file name where the executable is located.
7. DOS system will auto restart and update BIOS while system startup screen.
8. After BIOS update finished, system will auto reboot.
9. Go to BIOS Setup by pressing F2 and go to "General > Boot Sequence > Boot List Option".
10. Change "Legacy" to "UEFI" Boot Option.
11. Go to "Exit > Exit Save Changes" and reboot system.
Note 1: You will need to provide a bootable DOS USB key. This executable file does not create the DOS system files.
Note 2: Please make sure you suspend BitLocker encryption before updating BIOS on a BitLocker enabled system.
If you don't enable BitLocker on your system you can ignore i
Jul 31, 2018 | Dell Computers & Internet
Power failed during MSI P67A-C43 B3 bios update
Download the latest BIOS update from your computer manufacturer's website onto a USB flash drive. Refer to your user manual to obtain the manufacturer's website address. If the downloaded BIOS file is a zip archive, unzip the contents onto your USB flash drive. Jumper settings may need to be reconfigured on some motherboards to enter BIOS recovery mode. Most Intel-based motherboards have a jumper setting or switch near the on-board CMOS battery. The procedure for setting the jumpers will vary depending on your motherboard make and model, so refer to the motherboard documentation for specific instructions. Power on the computer and press "F2" to access the Setup Mode menu. If you are unable to access the setup menu, you will not be able to proceed with this repair. Take your computer to a repair shop, as the motherboard may need to be replaced. Use the arrow key to select "Boot Priority" or a similarly named field. Press the "Enter" key. Scroll down until "First boot priority" or "First boot drive" is selected and press "Enter." Select the USB flash drive as the first boot priority device. Press the "F10" key to save this setting and exit from the setup menu. Connect the USB flash drive to an open USB port on your computer. Then let your computer fully reboot. The USB flash drive should be detected and the BIOS should update automatically. When the update is complete, you may be prompted to restart your computer, or it may reboot automatically. If you are able to use your computer without any further problems of overheating or failure to recognize drives, your failed BIOS update has been resolved.
Apr 05, 2013 | MSI P67A-C43 B3 Desktop Motherboard -...
How to Replace Bios? Boot & Reformat Attempts Hang (on every HDD) - I guess BIOS is Corrupted
You can go to the manufacturer web site and go to support then to drivers and downloads there should be a BIOS flash software utility at their site. Click Here to go there. Select your model and make sure it is the correct one. I would also go for the automatic driver update, this will find and seek any drivers for your laptop that are needed, missing, or upgrade them.
If that does not provide the info you need their is also a support number as well as live chat at the link above. I hope this assisted you in some way. John
May 02, 2012 | MSI Computers & Internet
How do i chnage bios on dell dimension 4700
start computer with tapping f2 key, you will be directed to bios screen
and there you will get an option to default bios
Aug 11, 2011 | Dell Dimension 4700 PC Desktop
BIOS IS DAMAGE;HOW TO RESET?
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart or
http://download.cnet.com/msi-kt4v-bios-windows/3000-2098_4-10162333.html
Update BIOS in your MSI KT4V motherboard for Windows 95/98/Me/NT/2000/XP.
or
Update BIOS in your MSI K7T Turbo2 motherboard for Windows 95/98/Me/NT/2000/XP.
http://download.cnet.com/msi-k7t-turbo2-bios/3000-2098_4-10162343.html
http://download.cnet.com/msi-kt3-ultra2-bios/3000-2098_4-10162341.html
hope this helps
Jul 23, 2011 | MSI NF750-G55 Motherboard
I have an Acer TravelMate 4500 512Mb Ram an 80GB HDD, which doesn't run the operating system boot after bios boot. when I swich on it comes up a bios boot and after that the laptop screen's becomes...
1. Remove or Unplug any recently added hardware.
2. Remove and replace the battery.
3. Press and hold the power button for 7-10 secs to power ON the computer.
4. Try booting to windows Operating System in Safe Mode. (Press F8 key as soon as you restart).
5. Check if the Hard Disk is detected and listed with its capacity of 80GB in BIOS. (Press F2 as soon as you restart).
6. Reset BIOS to default values.
7. If computer boots to windows in Safe Mode, then perform a system restore to an earlier date.
8. Install any updates available for BIOS.
9. If Hard disk is listed in BIOS, perform system recovery using the recovery partition or the recovery discs.
10. If Hard disk is not listed in BIOS, contact any nearest service center to get the computer serviced.
Jul 23, 2011 | Computers & Internet
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
T6524 bios update needed
This isnt necessarily a bios problem mate , its just windows got corrupted during the power surge. Use the link below to do a repair install. Note , repair installs do not erase your personal files or setings or software !
http://michaelstevenstech.com/XPrepairinstall.htm#RI
Hope this helps you
If you found this solution helpful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | E-Machines T6524 PC Desktop
New MSI K9MM-V motherboard
dear daven
you can try, disable any integrated prripheral, like., USB port, com any related port
after that you can use your cd booting
to load into dos program
and before it try to download a new bios here
http://drivers.softpedia.com/get/BIOS/Msi/MSI-K9MM-V-BIOS-15.shtml
after that you can updated your bios
award.exe biosname /cp /cc /py
oke
thx
cropp
Mar 18, 2008 | Computers & Internet
Xp hangs .we rebooted the xp machine but it agin got hanged .when we login and click any icon like IE .it hangs
Reboot computer in safe mode by pressing f8 key at boot. Select safe mode. Run your spyware removal program to clean of spyware. Then run your antivirus to check for and clean viruses. After complete restart computer normally. If it boots to desktop and can access the internet, update your virus scan and run another scan & clean. If this does not work boot computer with your xp cd, select r for repair console. At the dos prompt type fixboot then hit enter, and y. Then type exit to reboot. If that does not work reboot with cd same steps as before except type chkdsk c: /r  and ht enter. After done exit to restart.
Hope this helps... please comment if further assistance is needed
Oct 26, 2007 | Computers & Internet
MSI 845GE Max-L (MS-6580-060) Motherboard Logo
161 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
