Question about Char-Broil CharBroil Master Flame Gas Barbecue Grill
Flame Shooting out the front
I have the Charbroil 463268606 4 burner grill. Only recently have i been experiencing a flame coming from the second burner "out the front", between the grill and the front panel. Any ideas how to fix this? is it a leak that is repairable?
  • miners66 Jun 20, 2009
    Which part would you replace, the gas delivery pipe or the burner assembly?
  • cesar collazos May 11, 2018
    Poked out spider webs in burner pipes and she burns like new again.
  • 199 Answers
You clearly have a gas leak. Inspect the suspect area for loose connections like the gas delivery pipe to the burner assembly. Try to reconnect them. If there is a hole in it you can use some muffler repair adhesive but I would just get a new part. Often the company will send you free parts as a good gesture to assure encourage repeat business. Check out the links below. The second one offers free shipping.
www.charbroil.com/CharBroilWarranty
www.clagrills.com/grillparts/charbroil/charbroil-grill-parts-home.htm
Posted on Jun 20, 2009
  • James Ely Jun 20, 2009
    Sometimes the burner is clogged and the back pressure forces the gas out of the holes where the air is drawn in to mix with the gas. Try removing the burner, poke out the holes that provide the burner flame, knock out all the loose stuff you can, clean it in hot water with grease cutting soap or in your dishwasher, let it dry and reinstall. I hope this helps
  • Muttley00 Sep 04, 2011
    I would light my grill and the first burner would light, but in about 10 seconds it would backup and flames would also come out the front. The entrance to the burner was clogged with some kind of white webbing maybe from a spider, cleaned it out and works great!
Mr. Ely is right. I took off my burners and looked in the hole. Spider webs!!! Makes sense, the gas shoot back out of the burner. I just poked out the spider webs and dumped out the loose stuff. Works great now.
Posted on Sep 02, 2012
Flames coming out of front of two burner on Charbroil Commercial grill
you have a gas leak on the control knobs soap test to see where the leak is. use washing up liquid and water to check for leaks .
Jul 24, 2016 | Grilling
I had my charbroil grill for 2 yrs and I now when I turn on the propane tank and ignite, I hear hissing followed by it lighting then flames proceed to come out the front middle burners. Do I need a new...
Before buying anything, look into the burners for spider webs. The webs block gas from getting to the burner and will fire back. This is dangerous. Look carefully where the gas nozzle enters the burner tube.
Gary
Sep 04, 2011 | Char-Broil CharBroil Master Flame Gas...
Model 463420608. 1 of 4 burners allows flames to come out the front of grill around knob. Any ideas?
gas leak loose control knob screws heed screwing in also check burner is not block causing light back
Aug 25, 2011 | Char-Broil CharBroil 4637318 Grill
First burner ignites quickly, second and third take up to 3 minutes IF they fire at all. burners are not clogged.
If the first burner's flame characteristic's look right, the remaining burners need to be removed and the venturi valves and burner orifices checked for obstructions and cleaned if necessary.That's generally the cause of delay ignition.
Hope this helped and Happy Grilling!
Mar 20, 2011 | Char-Broil CharBroil Master Flame Gas...
Why do flames shoot out the venturi tubes and out the front of the bbq control panel after 1 minute of being trned on????
blocked burner , or split burner , gas lighting back to injectors wrong air mix, leak on control panel ,
Jun 10, 2010 | Char-Broil CharBroil Master Flame Gas...
Where can I buy Charboil BBQ spares in the UK, in particular a burner for a Charbroil 200?
The email address sales@charbroil.co.uk does not work. I get a mail delivery failure. I have searched many times for a UK supplier and cannot find one.
Apr 11, 2010 | Char-Broil CharBroil Master Flame Gas...
I have a charbroil, advantage series grill. It isn't lighting.
How rusted are the burners? It is possible there is rusted metal blocking the gas ports. I don't have enough information from you regarding the problem...do you hear the gas flowing when you turn the burner open and the gas bottle is open?
Go to your user's manual, there should be an illustrated parts list. From there you can order new burners...you can also do this at Char-Broil's website.
Burner replacement is easy: take the grills out, then remove the flame tamers (the tent looking thing that sits over the burner to prevent flame-ups), the burners are screwed in to the grill at the back, remove the screws then grab the burner, pull towards the back of the grill and then up...this will disengage it from the gas valve in the front of the grill. Putting in a new one is the exact revers of this procedure...just make sure when you put the new ones in you make sure the burner's gas intake is connected to the valve at the front of the grill. Once done, you should be good to go.
Sep 07, 2009 | Grilling
My Char Broil gas grills flame is taller than it should be( not blue at all anymore) and make the food smokey?
You need to clean the burners/pathways, its not getting enough oxygen and the flame is starved.
Sep 05, 2009 | Char-Broil CharBroil Master Flame Gas...
Grilling Logo
5,083 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Jim Thurston
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
