Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side
My GE side by side doesn't get very cold and the freezer has some frost buidup the unit is 5 years old
  • 999 Answers
Something has gone bad in the defrost circuit.(Heating element was notorious for this) but could be a timer or thermostat. Frost buildup will cause inefficient cooling as will dirty condenser coils.
Eric
Posted on Jun 20, 2009
Where is the defrost heating element
Freezer side at the bottom and maybe middle of evap coil. Need to remove screws to access
Jan 20, 2013 | GE J Series 18.2 cu. ft. Top Freezer...
My 5 year old GE GSH22JSRSS Stainless Steel Side by Side Refrigerator recently stopped cooling. I noticed a build up of frost on the freezer, so unplugged the fridge and let the ice melt away. After this,...
The problem you describe is that your defrost circuit has failed. The fridge should stop the compressor periodically and turn on the defrost heater to melt the frost buildup. Since the frost in building up on your coils, the fan can't blow the cold air into the fridge compartment. It defrost is controlled by a module that turns on the heater. Most of these failures have to do with the defrost heating element burning out. It can be replaced by someone who has some mechanical ability.
The coil and heater is located in the back of the freezer compartment behind the panel in the back. You can obtain parts from appliance repair outlet or online like appliancepartspros.com or repairclinic.com.
Dec 07, 2010 | GE GSH22JSRSS Stainless Steel Side by Side...
GE Side by Side Heating Up and Frost on Panel in Freezer
sounds like your defrost heater termanator switch,or defrost timer is bad-mike
Jan 22, 2010 | Refrigerators
Model gss25wg. 5 years old. Worked fine when we got it home. Now
Try to remove rear wall of freezer to check frost pattern. An even but light patter of frost on full coil is normal. Coils full of frost with aluminum almost fully hidden generally means defrost problem. Heavier frost on the bottom coils and gradually tapering off as you go up until the top coils have no frost usually means a leak of freon or a bad compressor.
Aug 22, 2009 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
My GE Eterna side by side is emitting cold air from the freezer but not the fridge. Just noticed today. Not totally warm though. Appliance is 5 years old
most likely you have a def system failure. look in teh freezer compartment at teh back wall and you'll probably see frost build up the cover. the most common culprit for ge refrigs is bad def heaters. its very easy to tell by removing the rear cover melting the frost out wiht a hair dryer. then you will see either 1 or 2 glass rods with springs in them those are your heates if 1 or both of the heaters are burnt looking then you need to repl them. good luck peyton
Jan 22, 2009 | Refrigerators
GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Dec 12, 2008 | Refrigerators
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
GE Side By side doesn't cool and freexer frosts up
Most common problem on GE's is the defrost heater(s) has gone bad. They are a glass tube and when they go bad the tube will have a burnt or black color to it. A good heater will be clear. I bet that is your problem. Seems to be the problem about 90% of the time on GE not defrosting.
Jun 29, 2008 | GE GSS20IEP Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
192 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
