Question about Little Giant 5-MSP Water Wizard Submersible Pump, 1200 GPH
The power cord on my little giant pump is torn at the base of the power cord. How do I fix it ?
3 Suggested Answers
  • 156 Answers
SOURCE: sump pump
The big cylindrical thing at the end of the wire hanging is the switch. I believe it is a mercury switch. Try hitting this a little and see if it stops. Sometimes they get stuck. If this doesn't help, then replace that piece. Hope this helps.
Posted on Jul 06, 2009
  • 990 Answers
SOURCE: How to Replace Little Giant Water Wizard Utility Pump Power Cord
Yes, If it goes together it will come apart. If it is the one I'm thinking of if you take the base apart there will be through bolts that run through the whole pump, remove these I want to think there are some that are short and these hold the base to the motor but they may be behind the impeller. Be warey as I'm not sure. But once the through bolts are out you should be able to carefully remove the top. Some have very frail gaskets here so be gentel. Once you have the top free there will be a compression nut holding the cord before pulling cord through use a light sand paper to clean the cord so the part you pull through will be fresh enough to seal. Don't lube the cord this will keep it from sealing. Pull it hrough and make your repair and put it back together the way it came apart. Use a sharpie to mark the top and housing as you take it apart. When finished loop some cord through pump handel and tie it off so this takes the weight in the future to keep from having the same problem again. good luck
Posted on Aug 25, 2009
Little giant 566134
If the pump starts after cooling down, and then starts again, it has a thermal overload in the motor, so you should pull it out and see if for some reason the impellers are stuck.... could be an easy fix.
Jan 09, 2014 | Little Giant FP3 566134 Pond Pump, 4968...
My Little giant wgp-65-pw has tripped my gfi repeatedly. any idea why? No shorts in the cord are apparent
if a pump connected to a gfci outlet trips , then the gfci has detected a high resistance "shortage" inside pump and has disconnected power , this "shortage" can be nearly in detectable from human standards(shock) , but gfci picks it up
most likely pump seal has failed and water has gotten inside pump !! it only takes one drop to do this !!
Dec 24, 2012 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
How to replace power cord on little giant pump
You have to buy a new cable ,remove the cover plate ,mark the wires before removal. (Colour) etc.Peel back the new wires and fit them exactly the same way as they came off,or get a professional to do the job.
Feb 14, 2012 | Little Giant Submersible Fountain Pump
My new Little Giant 8-CBA Pump is hooked up underwater and plugged in. Not a sound. Electricity is working. And it's the same pump we have had for the last 7 years.
You say it's new? On some pumps they will secure the float switch when shipping. Be sure you followed directions and removed anything that may interfere with the switch.
Apr 21, 2011 | Little Giant 8 Cba, 4/10 Hp, 45 Gpm...
I cleaned the screen, and the impeller is working however the little giant pump WGP is still not pumping water.
You may need to take the bottom of the pump apart and check to see if any thing has gotten through the screen and clogged the impeller.
Nov 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
May 29, 2009 | Little Giant Pool Cover Pump Water Wizard...
Little Giant 5-MSP Water Wizard Submersible Pump, 1200 GPH Logo
62 people viewed this question
Top Little Giant Garden Experts
Jim Goldsmith
Jim Goldsmith
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
