Question about Peavey Pv 2600 Power Amplifier
Run a sub woofer to a peavey board
I havea peavey xr 700 c dual powered mixing console and 2 kustom ksc 15 seaker enclosures how dso i add an additional kpc 215 speaker enclosure as a sub woofer for bottom end.
    President:
  • 1,138 Answers
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Posted on Jun 23, 2009
Where can i find tech service manual for Peavey PR15 speaker?
The PR 15 is a two-way sound reinforcement system consisting of a heavy duty 15" woofer and a RX14™ titanium diaphragm, dynamic compression driver mounted on a 90° x 40° coverage constant-directivity horn. The lightweight-yet-rugged injection-molded plastic enclosure.
There is no need for any other service data and there is no service manual apart from user manual. It doesn't warrant one.
Apr 08, 2017 | Peavey Music
Does anyone know how i should hook up a pair of peavey sp118 Bxsubs with a pair of peavey pr15 tops and the behringer inuke nu6000 please help
You will require 4 heavy gauge 1/4" speaker cables in order to connect all 4 cabinets to the Behringer power amp. Usually two longer ones from the power amp to the sub woofer cabs. Then two short ones from the second "thru" jack to the upper 15" cabs. Remember the entire audio frequency range is going to all four speakers. Sometimes you will have problems balancing the low frequency levels between all four cabs depending on the loading of each. A more desirable way to do this is with a bi-amped arrangement. This way two seprate amps are used for the subs and 15" cabs and you control them independantly.
Dec 23, 2013 | Music
On my peavey pro 15 neo speakers i don't know which wire is for what. What is the black, red, blue and yellow wires for?
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
Aug 30, 2011 | Peavey PR15 400w PA Speakers
I have a peavey 1220 powered mixer and I'm trying to hook up to two sp15's top's and 2 18; peavey subs for my band and I can't get the bass seperated so it's out of my tops
Hi. The mixer puts out a full range mix, the solution is in your speaker setup.
Many subs have a built in crossover that splits the signal for the tops. Check your sub specs or manual. If your subs have this, run your output signal to them first and then link them to the tops from the special daisychain socket.
If they don't have one, you can install a passive crossover to your subs or buy an external crossover unit.
The last (and not very good) option is to fake a crossover with the desk's stereo EQ. Connect the subs to the left or right channel and the tops to the other and use the EQ to remove the bass from the tops and vice versa, pan everything dead center. Obviously this sacrifices your stereo sound and isn't brilliant.
Jun 29, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
I have the peavey xr 8600 and i wanna know how to connect an additional non powerd mixer to it ( i wanna use the peavey as an amp??
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
Mar 08, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I have 2 peavey sp 5 and a pwavey 2600 amp . i wanna know can i hook a peavey 118 passive sub to one of the sp5 and how would it sound?
You would send high as well as low to the sub and unless the sub had a built in crossover it COULD get muddy sounding. The specs SEEM to indicate the 118 DOES have a low frequency crossover so it SHOULD be OK... How would it sound? An 18 inch sub normally adds to the sound of a system... You MAY need to PAN over to send more power to the one side with the extra load on one side. Often people use two sub's... one for each side so it is balanced.
Jan 19, 2011 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey sound board 2 channels not working
check for cold solder joints from the input jacks and the fader. If any look suspicious (dull or grainy) re-solder.
Apr 29, 2009 | Peavey Pv 2600 Power Amplifier
Peavey Pv 2600 Power Amplifier Logo
389 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Peavey Music Expert? Answer questions, earn points and help others
