Question about Freezers
Would like to fix a new seal on a hotpoint fridge door
  • 999 Answers
All depends on the model:
Look under the seal. If it is held in place by a metal strip and many screws just loosen the screws enough to slip the old one ou and the new one in. If it slips into a channel it will just pull off and the new one is pressed in. If there are no viable screws then it was foamed in at the factory and has to be carefully worked out without damaging the foam seal for thr inside door panel and a new one tucked back in.
Eric
Posted on Jun 20, 2009
My Hotpoint freezer FZ150 red light keeps flashing. I turn freezer off then on again and its ok for a bit, then it flashes red again,
the flashing maybe door is not sealing check gaskets on door for folds or tears or door not aligned right
Feb 26, 2017 | Hotpoint Freezers
Looking for a replacement seal measures 1040mm x 600mm
probably the best idea is to contact a local fridge/ freezer person that replaces seals on the doors of fridges and freezers (yellow pages for a start-fridge repairers)
they have an assortment of seal profiles on board and they make the seal to suit the door on site
The cost is about 75% of new price
ask the service agent spares for a seal, because although the freezer may be old , seals didn't change all that much and you may still get a seal from them
From the size I am guessing that it is a chest freezer probably an electrolux/email product and you may be lucky if it is
Mar 31, 2016 | Freezers
My hotpoint ff187 fridge/freezer is making a beeping sound and has flashing lights. We have tried everything from turning off this button and that, then trying the power off and backwards again. There is...
clean the door rubbers and sides this sometimes fixes the problem as the seals are not closing properly and the fridge freezer thinks you have left the door open.
Feb 09, 2018 | Hotpoint Freezers
Freezer seal isn't gripping properly
in that case. you may have to consult your problem to the store where you bought that freezer. so they have to fix your problem
Jun 21, 2010 | Freezers
Is it worth replacing a door gasket on a 25 year old freezer. It is a Kenmore 6. Upright. It does not seal tight anymore.
Is the door gasket torn?? if not try cleaning the rubber surface that makes contact with the metal portion of the fridge and clean the metal area also, because inside the rubber gasket is a magnet that helps the gasket seal properly.I've seen door gaskets range in price from $50.00-$100.00 so if thats the only problem it sure beats buying a new fridge for a whole lot more money.
Aug 25, 2009 | Freezers
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
Freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Jul 06, 2009 | Freezers
Ice collecting under bottom of Freezer drawer/ seal round door intact/ food staying frozen/ Ice is cleared periodically but then builds up again
Your defrost drain hole is clogged. Look for the drain hole in the bottom rear of the freezer section. Turn off the fridge. Heat the drain hole with a hair dryer and clear the ice. Pour a quarter cup of bleach into the hole.
Jul 04, 2009 | Hotpoint Freezers
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
How to replace the door seal on a frigidare upright freezer
most fridge door seals are attached to the door by screws. If you flap the seal up from the bottom you should see some screws. if you go to the site below it gives your guidance on replacing the seals on fridges, as all fridge seals are pretty generic you should find it useful
http://www.wikihow.com/Replace-a-Refrigerator-Door-Seal
I hope this helps
Dec 08, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
97 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
