Question about Toshiba Satellite A105 Notebook
LCD problem Screen flickers and will eventually white out. i used to be able to get it back by moving the lid around but no more. i need to get it back for a few minutes at least to get my data off. what can i do? Can i put the hard drive into another toshiba?
    Problem Solver:
  • 10 Answers
If the screen flickers and goes white, it could be your lcd screen (the board on the lcd) or the lcd cable. i would suggest replacing the cheapiest which would be the lcd cable. You could also use the laptop externally and use it that way. Or just get a HDD caddy and change the securities and youll be able to get your info on any other laptop.
Posted on Nov 02, 2007
As I open the lid of the laptop to view the screen (logging in etc) the display would flicker and eventually turn off at a certain point, say about 1/3 of the way. if I close the lid back to that point I...
sounds like it's off track a bit...i really can't say for sure... your best bet would be to just take it to a computer shop and let them deal with it (-_-)
Oct 10, 2010 | Dell XPS M1330 Notebook
Screen is flicking again and agin Model is ACER Travelmate 5730
If the screen flickers when the lid is moved, then it is most likely the LCD ribbon cable has a bad connection to the LCD controller board. If it flickers without lid movement, then it is probably the inverter module for the LCD, but if it flickers constantly and especially if there are white lines that stay constant accross the display, then it may be an overheating or failing GPU. Check the air vents on the unit and make sure that there is no blockage if the latter is the case.
Hope this Helps.
Gill
Sep 24, 2010 | Acer Computers & Internet
Im using HP 540 with windows 7 and my screen at the taskbar keeps on flickering.. pls help is this hardware or software problem.
it's not a software problem ... i think u can be able to see such sort of problems frequently while you are moving the lid... it may be the problem with with tour motherboard or lcd...u can check it by adjusting the lid angle ,if u can see the flickering it is the problem with your lcd...or else,if u are experiencing the problem,while the laptop is in idle state also...it is the problem with your motherboard... no need to worry dude.....this problem can be solved by refixing the connection between the lcd and motherboard...so contact your hp service center...
May 06, 2010 | HP Computers & Internet
White lines on screen and flickering
I think this is the problem of LCD.if it is then u should go to nearest service center .
Sep 25, 2009 | Acer Aspire 5920-6727 Notebook
Acer 5920g screen problems
it is probably a loose or crimped LCD cable, either on the main board or on the back of the LCD panel itself.
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Laptop screen constantly flickers and whites out
Your Bulb is DUE, you need to change it, Don't do it your self contains mercury. Your LCD is good IF you do not have bad PIXELS. This white and pink lines shows as pixel problem but it migth also short on LCD, if you placed something heavy on Laptop. You may remove and sent the LCD for repair or all laptop to tech.
You may also need to check inverter. I give service around the Country but it is up to you. My company name is JMC TECHS INC. Registered in Miami Florida. (Check SUNBIZ.com) jmctechinc@gmail if you like to contact me.
JMC
Aug 15, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Hp Laptop screen flicker
I am sure that the issue is related to the cable that connects to the LCD Display or the LCD Backlight.
There should be some connection shortage because of which the LCD flickers few times as stated by dan231.
I Recommend you to get the Notebook examined as soon as possible before something really goes wrong...
Dec 05, 2008 | HP Pavilion dv6000z Notebook
Hi, i noticed that when I unplugged my HP the screen stopped flickering. I then re-plugged in the power, when to the Nvidia control settings, to PowerMizer, and changed 'ac outlet' to Maximum Power Saving.
Not the world's greatest solution, but hey, working laptop now.
Cheers,
Andy.
Nov 21, 2007 | HP Pavilion zd8000 Notebook
LCD going onto seizures
Have you installed anything recently?
Aug 02, 2007 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A105 Notebook Logo
131 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
