Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
Electrolux refrigerator Water is a room temperature.
    Sergeant:
  • 340 Answers
What is the temp in the frig their is a canister that hold maybe 2 gal of water if temp ok give it a chance to chill the water its not going to be any colder than the temp in the frig
Posted on Jun 20, 2009
3 Suggested Answers
SOURCE: I have a brand
We have had two different Electrolux French door refrigerators, over the past 2 years and the water never becomes cold. We were told this is because the the storage tank in this particular refrigerator is so small. You just have to drink your water with ice. Unfortunately, we have had recurrent problems with the ice maker as well! Sorry - but these refrigerators are very problematic and I would not recommend them to anyone!!!!!!
Posted on Jan 10, 2011
  • 10865 Answers
SOURCE: Room temperature water after 2 hours of installation
It takes about 24 hours for the ice maker to become fully operational, same for the water dispenser. Leave it for 24 hours and I believe you will be plesantly surprised.
Posted on Jun 13, 2009
How do I adjust freezer temperature on Electrolux refrigerator?
Hello friend, thanks for your inquiry!
I see that you would like to know how to adjust the temperature within your Electrolux refrigerator, EI23CS55GS1. To adjust the temperature you would use the control panel on the front of the freezer door. There should be a "-"or "+" near the freezer temperature control and that is how you would adjust the temperature within your refrigerator. Be sure to check and make sure that the control lock is not on or you will not be able to adjust the temperature. Any adjustments made within the refrigerator need at least 24 hours to stabilize. I hope this is has been helpful. -Matt
Oct 18, 2014 | Electrolux Refrigerators
I have a ffus2613lp. Yesterday the alarm started going off with the doors closed. The inside temperature raised to room temperature. I pulled it out, cleaned everything, including compressor/coils. ...
Good Afternoon Friend,
I understand the Hi Temperature alarm was going off on your Frigidaire refrigerator, model# FFUS2613LP, and the temperature was room temperature. I also see that you pulled out your appliance and cleaned everything, including the compressor and coils. You turned your refrigerator back on and it froze a cup of water before you went to bed. However, when you woke this morning, your refrigerator was back at room temperature. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it keeps warming to room temperature. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Refrigerators
The letters OP appearing on the control panel of my electrolux refrigerator, what is wrong?
Either the freezer sensor is open in freezer display -or- the fresh food sensor is open in refrigerator display.
The repair is to check wiring between thermistor and board. If the wiring is OK, then replace the defective thermistor (temperature sensor).
Apr 22, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Samsung bi-metal defrost thermostat
If the coil is good, it could be that the defrost timer is not allowing enough of a defrost cycle resulting in ice buildup after various cycles. The ice is never being complete melted and it just keeps building up.
Mar 13, 2017 | Samsung Refrigerators
Electrolux ei26ss55gs6,makes ice ,then will not
Might besetting and adjustment problem .lower the temperature in the fridge
Dec 06, 2013 | Electrolux EW23CS65SS Stainless Steel Side...
The temperature is going high and is runing all the time
Hi mh_petrovici - When doors are opened too often or too long, warm air enters the refrigerator causing it to run more or when the room or outside temperature is hot, it is normal for the refrigerator to work longer under conditions. Temperature control may be set too cold (normally found in refrigerator section), set control to warmer setting until refrigerator temperature is satisfactory. Allow 24 hours for temperature to stabilize completely. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Check and see if the condenser is dirty. A dirty condenser blocks air that dissipates the heat that the condenser removes from the unit. Clean the condenser every 6 months and more if you have animals in the house.
Nov 23, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Can you adjust the temperature on the water dispenser?
The water for the dispenser comes from a reservoir in the fresh food section behind the crisper drawers. So the only way to make the water colder is to turn down the temperature in the fresh food side of your refrigerator. The water dispenser is designed to dispense chilled water, not ice water. hope this helps.
Jan 04, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
I have a brand new French door electrolux refrigerator. It was just delivered today. The water dispenser doesn't give cold water - just room temperature. It's only been plugged in for 8 hrs but I...
Sep 12, 2010 | Refrigerators
Jun 13, 2009 | Refrigerators
The freezer side is NOT freezing, but the refrigerator side seems to be cooling normally. I tried emptying the freezer compartment and setting the thermostat at maximum cold, but nothing seems to help....
Dear customer,
               We recommend you to do the follwoing checks
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the refrigerator or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak
Click on the highlighted words to know the steps necessary. Thank you..
May 07, 2009 | Electrolux Refrigerators
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
210 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
