Question about Epson EPL N2050+ Laser Printer
Feed jam in printer Epson EPL N2050 - Epson EPL N2050+ Laser Printer
    Champion:
  • 381 Answers
Hi..mostly the problem is inside the is theirs a lot of dust or ink stocks inside so you can make a clean of this...Good Luck,Good Day and Have a nice Day...^_^
Posted on Jun 20, 2009
Have continuous paper jams every time I attempt to print a document.
You have to have paper in the gears or in the feed or the tractor gears. Cheap paper is a usual problem, you can't use cheap paper. I would also do a maint menu on alignment and print feed and that should do it. If there is no paper jammed and you are using good paper (humidity can wreck havoc as well ) you might just need a new printer cause the feed is broke.
Jul 02, 2015 | Epson EPL 5700i Laser Printer
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Mar 18, 2015 | Epson laser Printer EPL-6200L Laser
I guess the pickup roller is stuck because I can't spin the green part of it. the printer has been noisy lately, with grinding noise and jamming paper often but today really got stuck completely. Can...
sorry bout the delay :(
the "grinding noise" only means that some parts/gears that is unfortunately inaccessible to users are either not lining-up or worst have loose teethes and ultimately causing the paper jams.
do you have any error from the LCD panel display? what number or code does it show?
refer to this guide:ftp://download.epson-europe.com/pub/download/289/epson28944eu.pdf#
if the issue is (obviously based on your description how the printer is performing) beyond what is shown in the guide above, go to the repair services section on this page:http://www.epson.co.uk/Printers-and-All-In-Ones/Laser/Epson-EPL-N2550/Drivers-Support#
that is one sturdy printer but sometimes paper jams initiates rollers and paper feeders mis-alignment that causes more paper jams and worsening the issue.
Jan 19, 2012 | Epson Epl-N2550dt Mono Laser Printer
I need driver for laser printer Epson EPL-5900L for windows 7 thanks
Epson do not support this printer in Windows7 my advise is try running the setup in compatablilty mode if you have the Pro/Ultimate version
Aug 06, 2010 | Epson EPL 5700L Laser Printer
Replaced fuser and toner units now only prints black pages
Printing on a laser printer has 3 steps:
1. electro-statically charging the "drum", at various tiny "pixels",
to identify where the toner-powder should be placed.
2. feeding toner-powder onto the charged drum.
3. making the fuser produce heat to "bake" the ink onto the printer.
So, a failing unit or failing electronics would "charge" *ALL* of the drum,
thus putting black ink EVERYWHERE onto the page.
Take the printer to a qualified technician.
Nov 13, 2009 | Epson EPL-N3000 Laser Printer
How change ip address of epson epl n2500
Hi, i know its been months already but i have a solution to your problem, we have same problem and i solved it already..First, you have to get the ip address of your printer,..Then, open command prompt..
At command prompt, Try this command;
telnet ip address (this is your ip address)
Then, as you can see, their is a lot of instructions there..
So, you must follow it..
Take note: It automatically saved the changes.
Second options:
Type the ip address of your printer at web browser, it looks like this:
http:/192.168.1.100/ (this must be your ip address)
Then, as you can see, there is a lot of choices there.
So, you have to choose the configuration to change your old ip address.
I hope it can help you..
Thanks
May 13, 2009 | Epson EPL N2050 Laser Printer
Epson EPL N2050+ Laser Printer Logo
189 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
