Question about GE AJCH10ACB Built-In Room Air Cool Unit
The unit outside makes a noise like there is power but the fan does not blow
2 Suggested Answers
airwizard
SOURCE: The outside unit is making a squealing noise. It's
sounds like its more than likely the fan motor. the bearings in the motor are notoriuos for making a squeeling noise. there arent any other parts that would make this noise. unless youre a special case. i doubt it. if youre mechanically inclined there are ways of checking the motor. If you have an amp meter you can check the amp draw on the fan motor. if it reads higher than on the label of the motor then the motor needs to be replaced. if the amp draw is good the you can try to drop some oil in the motors lube port.
I’m happy to help further over the phone at https://www.6ya.com/expert/gerald_e28369afbd63f6b7
Posted on Jun 24, 2009
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Jul 06, 2014 | Goodman CLQ36AR49 Air Conditioner
I have a goodman air conditioner. When I turn it on air blows through the vents but it's not very powerful or cold. The unit outside makes a humming noise but the fan is not spinning. It's not...
You may have a bad condenser fan motor or a bad capacitor for that motor. If the compressor is running in the outside unit but the fan is not then it is most likely one of those two components that has failed. Consider calling a service tech to test it and see where the problem is.
Jun 16, 2011 | Heating & Cooling
Our ac just suddenly stopped working. the fan inside the house is blowing out air, just not cool air. i checked the ac unit outside and the fan blades are not moving, but can hear something in there making...
probably from the symptoms you describe the condenser fan motor has failed.If the fan is not running and the copressor is you need to shut the power off to the unit until it is repaired, the compressor can susstain damage from the lack of fan, and it is the most expensive component in the system to replace...
Aug 15, 2009 | Heating & Cooling
My fan isn't working
well there not enough data here to make a fairly good solution. but if all the fans are running! and no cool air then it is the compressor.
Jul 14, 2009 | Heating & Cooling
A/c unit not working. Have thermistat set on 65 and temp. in house is around 85. check the breaker box for the house and it have not tripped
You must make sure that there is power to both the inside unit and outside unit. Is the room air blower blowing? If not you have either a plugged filter, iced up coil, the access door is not quite closed or there is no power to the unit. Is the outside unit fan turning? If not, you either have no call from the thermostat, the fan is broken or the unit has no power to it. I would turn off the breaker to the inside unit and switch the breaker near the outside unit to off and let them sit idle for 5 minutes. Switch both breakers back on and chect to see if the outside unit turns on. Then check the indoor unit and see if this starts blowing. Let us know what you find.
Jul 23, 2008 | Heating & Cooling
Outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Jun 15, 2008 | Weather King 10AJA4201AH Air Conditioner
Outside unit not working
If the heating and cooling is working O.K. and maintaining the proper temperatures it is possible that your outside unit is in its off cycle. If the inside unit is running and the outside unit is not with an elevated temperature inside check the power supply to the outside unit. Most units have a disconnect located near them. Check the disconnect and make sure it is set to the on position. Listen for a hum noise at the outside unit which could indicate that the control power is being supplied to the contactor.
Jun 15, 2008 | Samsung AS18A6RB Air Conditioner
Central ac blowing hot air outside fan not moving but making a noise
This is nothing but an either or -or ! First, make the thermostat calls for cool, there are suppose to be 2- noise outside, the fan motor and the compressor (and if a old system,a humming noise which is the contactor coil which picks up the main 240-volts).. hurry up and take a stick or something and turn the fan blades, if it picks up speed and run, then its the capicator. If not then the fan motor is bad.! (BOTTOM LINE)!
Jun 09, 2008 | Heating & Cooling
GE AJCH10ACB Built-In Room Air Cool Unit Logo
124 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
