Hi Tom,
First of all, thank you for posting your question here at Fixya.com.
The symptoms you've described "No disc Error" is a fault when the optical lens failed to read the disc on its assembly. Yes, one caused of this symptoms is a dirty optical lens due to fine foreign object build-up on the optical lens itself like dust and static electricity build-up.
I would advice you to clean the lens using the
CD disc lens cleaner. Play it at least two times to the unit to clean the dirt and static electricity build up. Most of this symptoms resolve by lens cleaning alone.
However, after playing the disc lens cleaner on the unit and still the symptoms persist, this is an indication that the optical lens is faulty. You have to replaced it with new one. Click it
here for the replacement.
Before you replaced the optical lens, observe the disc if will spin or not upon playing, if yes then the problem is the optical lens, if not, the fault is on the disc assembly, you have to replaced the entire disc assembly. Contact this
LINK to inquire for the parts.
Hope I helped you.
Have a nice day!
Good luck and take care!
Rating and feedback are highly appreciated.
Kind Regards,
Mjsazon
