Question about HP Deskjet 3845 InkJet Printer
Printed material looks smeared, smudges on paper, gets worse if change print quality choice to "normal," "best."
  • 199 Answers
This sounds like a bad ink cartridge or refill job. Often you can get a new printer, better than the old one, with cartridges, for the same price as the new cartridges.
Posted on Jun 20, 2009
Vertical smudges across entire page getting worse with every print
If it is a laser printer, it almost sounds like either a fuser issue or a voltage issue. Is the smudge properly bonded to the page or does it smear off. If it is not bonded then the fuser is the problem. If it is fused then likely you either have a bad photoconductor or a power issue. Make sure that the printer is plugged into the wall and not on the same circuit as high draw items like heaters or AC units.
Mar 06, 2015 | Epson ACULASER CX11NF All-In-One Printer
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
The document printed from samsung scx 4200 printer has smudges and dots.
When you say smudges, can you wipe the toner from the page with your fingers; or is it just smearing when it prints; but, the toner is affixed to the paper?
1) If you can smear it with your fingers; replace the fuser. It's not heating the toner properly
2) If it is smearing, but sticking; replace the DRUM.
Nov 07, 2010 | Samsung SCX 4200 All-In-One Laser Printer
The print looks like it's out of register - the printing leaves a shadow around the words - like smudges
this sound sliek there is a fuser issue. you will want to run a cleanign for this unit if the software provides it or try running the prints at different quality.
this could be a drum issue as well but usually when this happens it means the fuser is not achieving the correct tempurature to properly adhear the toner to the paper causing a smear
Feb 12, 2010 | HP LaserJet 5550DN Printer
Photos print wet and smudged
all the dx /cx range do this when printed on the high quality settings you just have to let ink dry about half hour or use a lower seting when you print on gloss paper hope this helps
Dec 07, 2008 | Epson CX8400 All-In-One InkJet Printer
The ink seems to smear or drag down the page.
What normally causes that condition is a worn or dirty wiper blade. That blade is located between the print head and the drum. Is will not clean properly between prints.
There is a possibility that the maintenance kit could be the problem depending on how it was stored.
That is a roller impregnated with silicon lubricant, if it is stored standing on end, the lubricant will seep to one side and the opposite side will be pretty dry causing smears and streaks.
Also, have you gone into the tools mode and run the cycle to remove smears and smudges? That can help resolve your problem.
With the problem getting somewhat less as you run, I would take a good look at the maintenance kit just to see how it is cleaning. Look at the large roller and see if there are any sopts.
Nov 19, 2008 | Xerox Phaser 8500/DN Printer
Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
HP Deskjet 3845 InkJet Printer Logo
121 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
