Printer light red Samsung CLP300
Printer light turns red constantly
check no paper jams, inks ok
    Champion:
  • 220 Answers
Go to samsung website,download smartpanel to your pc,will tell whats wrong.
Posted on Jun 22, 2009
Fix samsung clp300 printer
I played around with mine for a few weeks and could not find a simple fix. The printer was GREAT, until it wasn't. Repair cost was more than replacement, so it was time for a new printer. I sold my extra ink carts on CL. Sorry this isn't much help....
Jan 23, 2015 | Samsung CLP 300 Laser Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Red light flashing constantly; nothing comes up on screen telling me what is wrong- still prints out. Don't know if out of certain ink. what could be wrong?
Red light flashes only when either there is a paper jam or a cartridge is out of ink. Have you tried turning it off and on - after 20 seconds.
Hope this helps.
Jan 25, 2011 | Epson Office Equipment & Supplies
Samsung CLP300 - All LED lights red and getting very hot when on
drl1069.dyndns.org/Public/CLP-300.pdf Ok above is your service and repair manual, inside is all troubleshooting procedures used by the engineers to troubleshoot and repair these units.
May 11, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP300 jams when normally printing, but will print test
If you are using a 6cm paper to print that is smaller than a A4 size paper.
do a check when you print did you select the correct paper size. as wrong paper size is print will course paper jam too.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
My red lights are both flashing and printer will not responed
Both red lights flashing? One should be for paper jam and the other for low/insufficient ink. I presume this is a deskjet/injet printer. The combination of these two lights flashing usually indicates a more serious issue rather than just low ink or paper jam. It is indicative of incompatibility of ink cartridge. After a while some cartridges just could become incompatible with the machine. All things being equal (i.e. no paper jam issue) a replacement of your ink cartridge will resolve this issue. Just get brand new ink cartridge/cartridges. It is usually ok to replace only the one that has become incompatible. But the issue is you need to troubleshoot to determine. You may not have the resources to do this, so better to replace both or replace one-by-one.
Sep 15, 2009 | Epson Stylus Photo R260 InkJet Printer
Two red lights blinking
The flashing red light next to a page and bin indicates paper or a CD/DVD has jammed in the printer.
The flashing red light next to the drop indicates that the ink is low - if it is solid on then the ink is out.
Both of these lights flashing rapidly together means taht the print head carriage is obstructed by jammed paper or some other material and cannot return to the home position. Turn off the printer then open the paper support and the printer cover. Then remove any paper or other obstructions from the paper path by hand / tweezers. Then, turn the printer back on and the fault should clear. If the lights are stioll flashing then check the paper path again and see if the print head carriage assembly is jammed by gently moving it very slightly along the carriage. Don't force this or do this too hard or too far as you can cause some damage to the drive
Sep 11, 2009 | Epson Stylus Photo R200 InkJet Printer
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
Phantom paper jam . Samsung clp300. Flashing red light
you clean your printer drum unit wast ink poder drum open and wast ink
Jul 21, 2009 | Samsung CLP 300 Laser Printer
CLP300 not picking up thicker paper
this printer only supports up to 120gsm paper,any thing thicker will get jamming errors
Jun 12, 2009 | Samsung CLP 300 Laser Printer
107 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
