Question about Epson Stylus CX9400 Photo Printer
Printing problem with Epson CX9400
Hi, I have epson CX9400 printer. It is not printing colours correctly. Even black printing get orange tone and every second line orange. I tried all the maintenance option given on printer. Please let me know if you have any other suggestion.Regards,
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
I have a CX9400Fax and occassionally print is mixed/missing lines. You must do a Cleaning cycle usually at least 4-6 times or until it prints a clear pattern. It will use LOTS of ink during the cleaning cycle. The printer normally uses a lot of ink, my solution was to purchase a CISS system along with a Waste Ink Container. IMO the best CISS is sold by the company below. I did have to call for tech support once and they returned my call in 30 minutes, problem solved and never came back. I purchase refill ink and it seems that I do a lot less cleaning cycles.
http://www.inkproducts.com/ink-store/
Posted on Jun 25, 2009
Problem with colour printing. Orange and green
Wow, that's a really old EPSON printer. The life expectancy of a EPSON printer is just three years, after that, the printer wouldn't work because of the clogged permanent printing head. The authorized service center is unable to repair it because the spares are no longer supplied.
Throw it to a recycling center.
Nov 03, 2009 | Epson Stylus Color 740 InkJet Printer
Epson cx3200 wrong colour
It is possible that when the printer senses not enough black ink it will swap to using the colour tanks to try and make a BLACK.
It is also possible that you have mistakenly adjusted a setting in the epson printer program to use the colour tanks to print black and white photographs.
Either of those would certainly cause the problem you describe
Check ALL your printer settings both the windows ones AND your epson ones
If you found this information useful pleas click below
Aug 12, 2009 | Epson Office Equipment & Supplies
ESPON Stylus Photo R200 Ink Status Problem
The epson like many other brands actually uses a small amount of the coloured ink in order to give the black print a more polished look.
You must use your printers properties page to set printing mode to Greyscale if you don't want it to use the colours.
To do this go into your control panel, open the printers icon, and select your printer, right-click on it and select Properties from the grey menu.
You will have to look through the pages and find the setting or check box for Grayscale. When you find it, select it, then click ok at the bottom of the page. This will stop the printer from using coloured inks to tone the black print.
Hope this helps FixYa,
Chris
Apr 30, 2009 | Epson Stylus Photo R200 InkJet Printer
I just want to print a word document in black ink, but...........
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. ( Also Epson gets to sell you more cartridges)
Apr 03, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Horrible ink issues..
Unless you are printing a lot in that color, my Epson Stylus photo color R300 uses black at about twice the rate as the color ones. Most packages or ink, I find, also come with two black and one of every color. All my color ones seem to emply at approximately the same time as the others.
Mar 08, 2009 | Epson Stylus CX9400 Photo Printer
Epson R265 printing colours incorrectly
For the black and white issue, check the settings and make sure that it isn't set on "sepia". As for the color issue, it is quite possible that you are out of ink. Printers may use more of one color than another depending on what you're printing. Change your color cartridge.
Jul 02, 2017 | Epson Stylus R265 InkJet Photo Printer
Hi, I have an Epson DX4200 I run out of the three colours ink cartridges, but just put in a black cartridge and is not printing. As far as know, it should print black if my black ink is full, even if the...
I have an Epson color printer ,but not the same model. If any of the colors of ink or out it will not allow one to print anything until the cartrage is replaced. It is built that way to stop the ink for totally running out . I just read this in this months comsumers reports magizine. Sorry.
Dec 11, 2008 | Epson Office Equipment & Supplies
New out of box!!
If you already have tried reseating all of the inks and and inks are still not recognized, Please contact Epson tech support for a replacement ink or if they find out after some diagnostics that it is the printer that is having an issue they would be replacing your printer.
Jun 22, 2008 | Epson Stylus CX9400 Photo Printer
Epson STYLUS CX3900 Black colour not printing
Are you using gen. epson cart? If not then try that first.
Sounds like you have a block black print head there are many posts on that subject.
Nov 04, 2007 | Epson STYLUS CX3900 All-In-One InkJet...
Epson Stylus CX9400 Photo Printer Logo
535 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
