Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
HOW DO i FIX bISSELL pROHEAT BELT
How to fix the belt a
    Master:
  • Bissell Master
  • 894 Answers
Hi, it's Cindy from Crucial Vacuum.
Your Bissell 9200 Proheat 2x vacuum's brushroll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. Another cause could be there is debris stuck on the roller and/or bearings. To gain access to your belts, follow the steps listed below:
1. Step on the release pedal and recline the handle down.
2. Remove the Tank-In-Tank and SmartMix Tank.
3. Using a flat head screwdriver to gently pry the access door, remove belt access door located near the floor cleaning switch nearest to the handle.
4. On the bottom of the machine, use a Phillips head screwdriver to remove the red retainer plate.
5. Remove the black brush arm holding the brush in place.
6. Locate and adjust the two belts.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-steamer-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Posted on Apr 24, 2014
SOURCE:
reddevil6
  • 1673 Answers
SOURCE: belt on this vacuum
Take off the bottom plate covering the brush roll, take out the brush roll, check it to make sure the ends turn freely, the belt goes around the end of the brush roll, then stretch it to go over the motor shaft.
Posted on Mar 22, 2008
SOURCE: bissell proheat self propelled series
I'm having the same issue and it was the pump. The metal drive gear sheared off of the plastic pump shaft. I JB Welded it back together, now I just need a schematic to reassemble the cleaner.
Posted on Sep 27, 2008
jyackle5
  • 8197 Answers
SOURCE: belt manual
Here is the manual. on page 17 tells you how to change.
http://dl.owneriq.net/2/23cae7f7-686f-47c1-8efe-3a106fffcd50.pdf
Good Luck and Please Rate FixYa!
Posted on Jan 11, 2009
Vac Belts
  • 701 Answers
SOURCE: My Bissell Proheat is not spraying water. What is ...
It is very simple and inexpensive to fix. All you need to do is replace the pump belt. Here is the belt you need:
Bissell Proheat Pump Belt
Posted on May 25, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell ProHeat, Brush won't turn, belt fine.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dh
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
The bar that the belt sits on wont spin and smells like its burning when you turn it on. Is the motor out?
No, it is not the motor, it is a bad belt or something is jammed causing the belt to slip...
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Sep 26, 2010 | Bissell 1699 ProHeat Clear View Upright...
My Bissell Proheat is not spraying water. What is causing this? and will it be expensive to fix?
May 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
How do I change the belt on the Bissell Proheat
heatman101
vm
Mar 14, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
heatman101
dh
Jul 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Replace The Access Belt
heatman101
sgh
May 22, 2009 | Bissell 1699 ProHeat Clear View Upright...
Change belt on 7920
heatman101
cvzncbn
Mar 29, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Cannot figure out how to install brush belt on a bissell proheat
heatman101
twywt
Jan 16, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell ProHeat Steam Cleaner
heatman101
ahdg
Aug 24, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
