Question about Dehumidifiers
Our Dehumidifier pulls the water out of the air ok but just leaks the water out instead of it collecting in the bucket.
  • 334 Answers
Hey, there, hoping this will be an easy fix for ya. Have you made sure the drain line to the bucket is clean? Maybe try to push something up the drain, or use a shop vac if you have one. This would cause the drain pan to overflow and the water to go everywhere else but the bucket
Posted on Jun 20, 2009
Why does Frigidaire dehumidifier FAD704DWD send water outside unit?
Good Afternoon Friend,
I understand that your Frigidaire dehumidifier, model# FAD704DWD, is putting the water that it collects out onto the floor as oppose to the bucket. I suggest contacting the manufacturer for more information. They should be able to point you in the right direction for assistance. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire a/c fad704dwd 70 pint...
Tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 | Dehumidifiers
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
My Maytag dehumidifier runs but does not collect water in the tray. Instead, it appears to leak from the bottom and ice formed near one of the side portions. Please let me know what you think is the...
This one has a leak in the refrigerant system... it will need to be found, fixed, and recharged...which will cost more then a new one...in most cases.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 13, 2011 | Maytag Dehumidifiers
Water is not collecting properly in the bucket. I ran it for an entire day, and only about half an inch collected in the bucket while more than that amount of water leaked from the unit. There was a puddle...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Apr 30, 2011 | Soleus 8649045FB Dehumidifier
Dehumidifier will not pull water from air
heatman101
Nov 15, 2010 | DeLonghi DH100P Dehumidifier
Haier HDN305 dehumidifier does not pull moisture from air and does not collect water in bucket
heatman101
Jul 26, 2010 | Haier HDN305 Dehumidifier
I have a Goldstar Dehumidifier DH504ELY7 that doesn't pull moisture out of the room. the fan runs and I think I hear the compressor come on but the air coming out the back is cold and the bucket doesn't...
heatman101
Jun 11, 2010 | Goldstar DH504EL Dehumidifier
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
My kenmore dehumidifier won't pull the moisture out of the air, the motor is runing when turned on but the bucket never fills up. What is the problem?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 10, 2009 | Kenmore 53509 Dehumidifier
Dehumidifiers Logo
87 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
