Question about Emerson MW8107WA Microwave Oven
Door Window steams up on Microwave
Emerson 1000 Watt Power 1.1 cubic space. Having problems with the door window steaming up. Is this a know problem? Microwave is brand new, just purchased from Kohl's.
  • Emerson Master
  • 9,098 Answers
Is the internal cooling fan running? You should feel air flow from the grille in the front or back (as the case may be).
If it's just steaming up the inner face of the door, that's fairly normal, but if the steam is appearing inside the layers of the door, that is not normal.
Since it's new and you've got a warranty, I would call Emerson.
Posted on Nov 05, 2007
Steam in between door glass on fridgidaire microwave
you must open the microwave and see if there are SOME parts burning or smell some component see the photo attached.
Oct 24, 2013 | Emerson MW8107WA Microwave Oven
My Emerson microwave is only a few months old. I clean it with each use. My problem is there is a rotten odor when I open the door. Is this the grill unit? Can't take apart to clean. Help.
It should have a warranty, consider pursuing that route.......if possible I would talk to Walmart to see if they will give credit for it being returned so you can get a different brand..........
Nov 05, 2012 | Emerson 1100 Watt Black & Stainless Steel...
Emerson microwave 1000 watt - how to tighten door on hinges
The tool is a special so nobody can tamper with the door, you need a repairman that is equipped with this item or see if you can get one from manufacture. The microwave leakage radiation is of concern especially in near range of the unit and should be corrected quickly.
Mar 27, 2012 | Emerson Microwave Ovens
There is steam inside the microwave when my food is heating up. Is this dangerous?
If the steam is not leaking out of the microwave it is no problem. Steam is normal when you heat moist items. If it is leaking out you need to replace the door seal, but steam will not start a fire.
Feb 16, 2012 | GE Microwave Ovens
The plastic cover on the window of the door is peeling. iIs there any danger in this? Other than that the microwave is working perfectly. Does this cover or the microwave have to be replaced?
The plastic cover on the door stops food particles and steam entering the inside part that is not easily cleaned.
That's all.
It is like thick selotape.
Jan 03, 2011 | Emerson 025806092806 Microwave Oven
The plastic film inside the window on the door is pulling away from the glass. Does this consttute any danger. Does it or the micrwave have to be replaced? Other than that the microwave works perfectly.
The film stops food particles and steam from entering the part of the door that is difficult to keep clean. That is all it does.
No danger just difficult to clean.
I have a brand new Bosch microwave model HMV8051U It was installed for 1 day and the interior glass on the door shattered. What would cause this to happen?
It could be door alignment, damaged or chipped when installed, scratched and moisture got in the scratch and turned to steam under pressure or hit with something spinning around in the machine.
Almost anything.
Take it back and get it replaced.
Jan 03, 2011 | Bosch 800 HMB80 1000 Watts Microwave Oven
Emerson 1000 watt microwave
This appliance still under warranty, I would suggest to call the manufacturer and ask them for the nearest authorized service center.
Make sure you have the receipt where and when you bough it.
Good Luck.
Mar 12, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson 1000 Watt Microwave
There is a good possibility that microwave energy is leaking near the magnetron tube, or some other high voltage electrical problem is occurring. I would recommend having it tested by qualified microwave repair technician. A few things you can do....
-Make sure the door seal is clean and no corrosion.
-Check the interior for rust spots or holes and make sure it's clean inside.
Jan 16, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8107WA Microwave Oven Logo
1,153 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
