Question about Dryers
Need help! If there is time left on the timer and I open the dryer door, the dryer tumbler stops as it should. BUT, my dryer heating element stays on and never turns off unless I unplug the dryer or turn the timer to off. (I guess it's the element...the dryer cabinet is VERY hot to the touch and the ''orange glow'' at the back inside of the dryer still glows after the dryer door is open...again, unless the timer is turned to off or the dryer is unplugged.) Is the problem my dryer element or timer...and how do I make the repair?
    President:
  • 1,136 Answers
HNi, Your heating element has shorted out against the metal. Get me a model# and I can get you through this.
Vic
Posted on Jun 20, 2009
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Need help! If there is
Either the centrifugal switch on the drive motor is stuck in the ON position or the heating element is broken and shorted out on the heater canister.
You did not post a model number.
Therefore I can not assist in accessing these parts.
All dryers are made differently.
Appliance model numbers are a must.
Posted on Aug 14, 2010
Dryer Timer doesn't move in Easy Care Mode
do you have heat?does it stay hot while in coll down?if so your heating element is grounded,open the door,look up and remove the two screws holding the top panel in place,pick top panel up just a little and move it to the left that should remove the top panel, put it on cool down or no heat and run it,if the heat stays on this is your problem the element is sagging and touching the metal cover around the element,the way the timer works is on timed dry it counts down like a clock until it turns off when on more or less or auto same thing the dryer starts,the heat comes on and when it hits temp. the heat shuts off when the heat is off the timer will advance to off when the heat starts again the timer stops,if the element isn't grounded then you still could have a bad element there are two elements in your dryer if one is broke the timer won't advance or some have only one element so if the timer doesn't advance you probably have no heat or a bad cycling thermostat or a bad sensor up front where the lint filter is.you'll have to check them with a meter.first thing to check is the heater located behind the drum.
Jan 15, 2018 | GE Dryers
Need help! If there is time left on the timer and I open the dryer door, the dryer tumbler stops as it should. BUT, my dryer heating element stays on and never turns off unless I unplug the dryer or turn...
Aug 14, 2010 | Dryers
Dryer continues to heat when door is open
The model number you put up is for a gas dryer, but you said element, so I'm assuming it is actually electric.
If this is in fact an electric dryer, you most likely have a heating element that has shorted to the case. There is a small chance that something else in that circuit has shorted to ground but I doubt it.
If this actually is a gas dryer, please discontinue use immediately and get a licensed tech over there to look at it.
Good Luck
May 16, 2010 | KitchenAid KGYS850LT Gas Dryer
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Whirlpool Electric Dryer Model LER8858EQ1 TYPE NO. 180-0
Based on the information that you provided, if you open the door in mid-cycle and the motor shuts off, but the element stays on, this will stop the air flow through the dryer and the element. The element temperature will rise drastically because it is not being cooled. Subsequently, to prevent a fire, the thermal fuse will open, shutting the element, and in some cases the motor, down.
A heating element gets its power from the timer, through the cycling thermostat(s),and to 1 side of the element.
When the motor starts, power is passed through the centrifugal switch in the motor, through the hi-limit thermostat and the thermal fuse to the other side of the element.
There is no ground wiring involved in the heat side of the dryer.
1. An element can stay on because it has broken and fell against the metal tube where it picks up a ground. Solution is to replace the element.
2. The centrifugal switch mounted on or in the motor can fail to open when the motor stops and allow current to flow through it
until the points in the timer open up, breaking the circuit.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Whirlpool LER5636P Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Heating element stays on after door is opened
possibly something grounding the element to the housing. what brand of dryer do you have? GE/Hotpoint dryers are good at allowing things like underwires from a bra to get into the element area and ground out the element. or possibly the element has broken and the broken end has fallen against the housing. hope this helps
Oct 29, 2007 | Dryers
Dryers Logo
158 people viewed this question
Top Dryers Experts
Marvin
Marvin
