Question about Ducane 30400040 Stainless Steel Grill
I have a ducane stainless steel ducane 30400042. Weber has sent me new burner bars since the old ones rusted but you do I install them?
  • 9 Answers
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Posted on Jun 26, 2009
How to replace burners
Replacing the burners on any Ducane Gas Grill is not an easy task. As the control panel has to be dismantled to accomplish it. With that in mind, I have included a link to the Owner's Manual. The section Annual Maintenance starting on page 21, will be a big help to yo in removing the old burners and installing the new ones.
http://help.weber.com/manuals/ducane/2008%20Manuals%20pdf/20529916_030308.pdf
Hope this helps you and Happy Grilling!! Thanks for choosing FixYa.
Aug 02, 2011 | Ducane 30400040 Stainless Steel Grill
The burners do not light consistenly. I can see the igniter spark and the fuel supply is good. If the igniter does work the main burners may not light until I creat a draft then the burner takes off.
It sounds as if, the burners need to be removed and thoroughly cleaned. As do the Venturi valves on the open end of each burner. Spiders like to build nests in the Venturi openings and clog them up. It's a prat of Routine Maintenance, takes a little time to perform, but is not difficult to do. It does require removing the burner knobs and the control panel cover (which was a poor design by Ducane/Weber)
To help make this a little easier for you, I have included a link to a Ducane Stainless Steel Model Grill that will show you how to remove the burners. Pay particular attention to the Annual Maintenance section starting on page 21. You can download and print this manual for future reference.
Hope this helps you. Please let me know and Happy Grilling!!
May 25, 2011 | Ducane 30400040 Stainless Steel Grill
Install replacement burners
You've got a job ahead of you! Duncane is the only grill on the market that I know of, that requires the removal of the Control Panel to remove and/or install new burners.
Here is a link to the Owners Manual. What you need to know starts on page 21 (Annual Maintenance). Good luck.
You can download and print the manual for future reference.
Hope this helps you. Please let me know. Thanks.
May 05, 2011 | Ducane 30400040 Stainless Steel Grill
Need to replace stainless steal buners. 17" long
You have to remove the front panel to remove the old burners and install the new ones.
Mar 20, 2011 | Ducane 30400040 Stainless Steel Grill
How do I remove the old burners to replace with new?
Should be as easy as removing the screws at the ends of the tubes and sliding the tubes away from you and putting the new ones in like you took out the old ones.
Apr 10, 2010 | Ducane 30400040 Stainless Steel Grill
My 30400040 is rusting to pieces and is only 3
the casing sould have a long warranty but the burners and the cook surfaces do not
you must keep them oiled with veggie oil after cleaning to prevent corrosion
i keep a pump bottle with oil for this reason
Jun 25, 2009 | Ducane 30400040 Stainless Steel Grill
Steps in replacing 5 burners on Ducane burner mod 30400042
First calll Weber to get your replacement burners for free. There is a five year warranty on this model which is a little over 4 years old. I know this because I just received them from Weber for free.
Jun 20, 2009 | Ducane 30400042 (LP)
Need to replace burner tubes on a Ducane grill. How do you do this? How do you get the old one off? I don't have a manual anymore.
First call Weber to receive the Warrenty burners for free. Have model and serial numbers ready. They can be found on one of the doors. Here is what I did for my Ducane model 30400042.
Jun 07, 2009 | Ducane 30400042 (LP)
I need to know how to remove the stainless steel burners and replace them.
Call Weber to receive free warrenty burners. Have model and serial number found inside one of the doors on your grill. I just received them in the mail about a week ago and just replaced my burners today. Here is what I did.
Apr 16, 2009 | Ducane 30400042 (LP)
Ducane 30400040 Stainless Steel Grill Logo
454 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
