Question about JVC TH-M505 System
Power turns on and off...smells like something is burning
The power will not stay on. the back smells like something is burning.
  • 199 Answers
Make sure your red speaker leads are not touching the case or the black leads. Check to see if anything metal fell into the unit through the vent like a staple or piece of wire. Pick it up side down and shake it. It is possible for a foreign body to get "welded" on a short so take the case off and do a visual inspection. Look for burned components. Unless you are electrically savvy, this would be a good time to take it to a repair tech or a friend. Good luck ;)
Posted on Jun 20, 2009
Why does my vax power 2 cylinder hoover make a noise and smell of burning rubber when I turn it on we have cleaned inside and out and all filters
That is the smell of perhaps burning insulation when there is excessive current going into motor. If something in unit is binding the motor will not spin fast enough, generate less back emf, use more current, overheat and burn out!!!!!!!!!!!
If it has a drive belt and that is rubbing up against something and not turning properly that will also cause the smell.
Do not use unit in this condition -you risk permanent damage.
Aug 31, 2015 | Hoover Vacuums
Printer smells
it may be ur power board.
discconnect it from power first and leave for 2hras
Jun 22, 2008 | Konica Minolta magicolor 2400 Laser...
I have a dura flame electric fireplace and I turned it one and it smells like something is burning. I tried to vacuum it and I turned it back one and it still smells like something is burning. it is a
when things are brand new that produce heat they will smell funny for awhile but give it a couple days and it will not if you see smoke then get excited and unplug.
Jan 28, 2015 | Duraflame L Electric Stove with Remote
Vax v-091 burning smell and clunking noise
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | VAX Appliances 2000 Canister Vacuum
Ran gas now starts then turns off and smells like burning rubber
Not sure I follow your story. If you really did run out of gas, you may have damaged the fuel pump in the tank. But it would not cause any smells.
Can you tell where the smell is coming from ?
Feb 19, 2014 | 1987 Oldsmobile Ciera
I started my washer last night then went to check on it and it was not on. I tried to turn it on but no power. I checked the breaker and it flipped the bresker so I turned it back on. When I push the power...
If the breaker tripped, something shorted to ground in your control panel. You resetting the breaker and pushing the power button then cause something to burn further. I would suggest turning off the breaker then taking the control panel off to see where the "burning smell and small amount of smoke" came from. Look to see if a wire was rubbing against metal somewhere.
Jul 31, 2017 | LG WM0642H Front Load
Tv turns off by itself, smelled something burned
the power panel itself tends to be an issue with theses sets
Feb 14, 2010 | RCA HD52W59 HDTV Projection Television
My rca 52" rear projection won't stay turned on. It shuts itself off and smells like something burning
Pull back Off and see what is causing burning smell, and CK capacitors on deflection board its the bottom board to the left has FBT flyback transfomer on it 3caps to check are cp150 2200uf 16v use 25v if it is puffed up on top then it is Bad other 2 caps are cp114-cp120 220uf 35v
Nov 14, 2009 | RCA HD52W56 52" Rear Projection HDTV
SAMSUNG HT-X50
Do you smell anything burning. This happened to me and I cut it back on. It stayed on for 30 secs or so and did the same thing. After doing this 2-3 times, I smelled a burning. Being a member of the Fire Dept, I didn't want to see my buddy's coming to the house, so I unplugged it. The next day, I took it apart and there was a burnt resistor or something under neath the fan. I took it back and they gave me a new receiver, but I'm expecting the same with this one.
May 16, 2008 | Samsung HT-X50 System
T.V. TURNS OFF
Sounds like somethings over heating if you smell something. The wise thing to do if you know nothing at all about the tv repair is to call someone unless you feel convident enough to open it and look around very carefully and see if you can describe whats over heating or burning as if you keep turning on the set and it keeps smelling it will burn something out thats not burned out now.
Mar 24, 2006 | Mitsubishi VS-60609 60" Rear Projection...
JVC TH-M505 System Logo
340 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
