Do i lay paper with print upwards when faxing
I want to know how to send a fax
  • 1,555 Answers
That totally depends upon which model ur using just try to pull up the slot where u put ur paper for faxing it will open then just check where the scanner lies and ur print face shall be towards scanner you send top to bottom or bottom to top it doesn't matter.
Posted on Jun 20, 2009
How do I set up on my printer to connect fax
Dear
Pl. connect the CO(telephone line) to the socket marked as LINE.
from the key board there is FAX switch select it.
To send a fax load the document face upward, if ADF is used or face downward at platen glass, press SPK or OHD or phone as marked on the key board get the audible dial tone, dial the required fax no. get the fax tone press START. If the display shows sending then alright. If display show !-SENDING,2-RECEIVING, then press the corresponding digit.
Thanks,.
Feb 18, 2015 | Samsung Xpress SL-C460FW Laser...
How do I load a document in my fax Machine
If you are laying your original on a glass, like in a flatbed scanner, you lay it face down.
If your fax works like my printer, the printed surface is on the bottom tray face down. It It gets sucked into the printer under the roller, around the back of the roller and comes out in the upper tray over the roller and face up. You laid the paper face down.
I hope this might help resolve your question.
Oct 15, 2014 | Premium New Brother LC61 Series Combo Pack...
No problem, but don't know if the print goes face side up por down into the printer when faxing
Where you put the paper must be a little icon like a page with lines, if you see this put the paper face up. I am surprise you did not check with a fax recipient to see if they got it (Blank paper or the fax)
Mar 18, 2011 | Office Equipment & Supplies
FAX IN CANON PIXMA MX320... HOW TO USE IT????
On the top part of the top lip cover of the printer you will find a slot for paper. that is the fax section. Insert the documents you want to fax. Remember to place the documents with print on it facing upwards.
Now, as the documents is placed on the slot and ready, press the FAX button once, then enter the phone number who to send to. Then press the black or color start button.
Wait for the printer to dial and wait for the message "transmitted" appears in the display to confirm that the documents was successfully send.
Sep 10, 2010 | Canon PIXMA MX310 All-In-One Printer
MFC-490cw Color Inkjet Multi-Function Printer: how to send a fax...
Most of these will send a fax without even using the PC. Just connect a phone line, place the document in the proper position, usuallu print side up on newer models, and push the fax button, it should prompt you for the number. Once dialed,, the paper will feed into the scanner portion of the multi, and you will see it on the menu bar saying sending page 1, 2 etc, after if is done sending, it will dial and connect, yu should hear the typical noise a fax makes. then it will say fax sent or end or something similar, that's it, try sending one to a friend to make sure it's working. Now some simpler machines require you to open the scanner portion and lay the paper down in the glass manually, mine does it both ways. In that case just skip the feeding part, and dial wait for it to scan and send.
May 16, 2010 | Brother MFC 490cw Color Inkjet...
Which way does the paper go into the feed when faxing?
Load the originals, with the print side up, into the document feeder tray. If you are sending a single-page fax, such as a photograph, you can also load the original on the glass. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Can't stop the transmision report - continues to print page after page
Make sure the transmitter knows how to send a FAX, i personally wasted a lot of time and paper because the sender doesn't know that the FAX machine had an automatic document feeder and that all pages has to be put in position before sending, and not page by page while sending.
Also see in the FAX manual if it can avoid printing the transmission report. Most Panasonic Faxes can do that.
May 05, 2008 | Canon FAXPHONE L80 Laser
Paper jam and fax in memory
Just unplug the power cable in your machine and put it back again.The paper jam will clear but...also the fax memory will be clear at the same time.just tel the other line to re-send thier fax again.
Oct 04, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
51 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
