Question about Vizio VW42LF 42 in. LCD HDTV
No picture but there is still power
When i plug in the tv, the backlight comes on but the screen stays off. the tv wasnt dropped or anything.
  • ttcdoc Jun 20, 2009
    there is no picture using tv or dvd inputs, no sound at all, no logo, no response from any buttons but the power button, and thatonly turns on. have to unplug to turn off
    the model # is actually VW42L-HDTV10A just realized it wasnt vw42LF
  • 10,594 Answers
HI,
Please reply following questions to diagnose problem in TV..
1- When TV powers up, do you see any Logo Screen or Display there?
2- Do you get Sound in speakers and can change volume level?
3- Does TV give same blank screen on all inputs like Cable, DVD input?
4- Can you change Channels on TV with remote or buttons on TV?
Let me know symptom details to locate problem section in TV.
Thanks.
Posted on Jun 20, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Jun 20, 2009
    Thanks for response.
    Symptom shows that system control on main board is bad and main board will be replaced.
    Your question shows it is Vizio VW42LF TV, if it is correct TV model then click Shop Jimmy to see an image and price info for the same.
    If model number is different, let me know to locate appropriate part.
    Thanks.
    Thanks for model update,
    get back to you shortly.
    Thanks for wait..
    Click Shop Jimmy for main board info of Vizio VW42LHDTV10A model.
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
Lg tv power light comes on but screen stays blank
If you can't see a faint picture with the flashlight then the T-con board is gone. If you can see a faint picture, then the led driver or ballasts for the back lights quit. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 05, 2016 | LG Televison & Video
Screen goes blank aftert 10 mins sound stays on though, wont come on again till been switched off for ages, and then picture still only 10 mins then sounds stays on again
when the TV goes dark, shine a flash light on the screen- hold it very close.
if you see a little bit of the image, your backlight has failed. That would mean you would need to replace the LCD panel.
Apr 13, 2011 | LG RU-27LZ50C 27 in. HD-Ready LCD...
My Westinghouse SK-32H540S pictures shuts off after 10 seconds. the sound stays on but no picture. is it the troubleshoot? i tried unpluging everything and repluging it and still the same thing happens...
This problems are the tv 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards provide the tv LCD screen pannel a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Mar 24, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
Mar 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
I dropped my laptop, white pixels turn pink
The CCFL lamp has been partially damaged and could fail completely any time. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
var selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1 = null,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2 = null,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3 = null; function checkReviewsMarked() { if (selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3 !== null) { $('btnctl00_SideColumn_ctrl_rater').disabled = ''; $('btnctl00_SideColumn_ctrl_rater').className = 'c_sub_small sub_enabled'; } } function checkAndSend(obj) { if (selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3 !== null) { setRate(selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3, function() { window.location.href = window.location.href; }); } }
Jul 09, 2009 | Dell Latitude D600 Notebook
LG 47" LCD FLAT SCREEN
IF IT WASNT DIGITAL HD I WOULD HAVE SUSPECTED HIGH VOLTAGE POWER SUPPLY BUT THAT DOES NOT EXIST HERE.
Well, not completely true; the fluorescent backlight is still a high voltage device, even if only hundreds of volts instead of kilovolts, and either the lamp(s) or the power supply for it (them) is causing the dropout of your picture. When it does it next time, look at the screen from various angles, I think you will see that video content is still there.
Jun 05, 2008 | LG 47LC7DF 47 in. LCD HDTV
Vizio VW42LF 42 in. LCD HDTV Logo
157 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
