Do you lay paper upright when faxing
Using canon fax -8155
    President:
  • 3,085 Answers
Make a copy, then you'll know.
If it comes out blank, turn the paper over.
Posted on Jun 20, 2009
Shows receive in memory, check paper size
Either the paper size in the fax machine is wrong or there is not enough paper left to print the fax. Add paler and the machine will print the faxes held in memory.
Oct 10, 2014 | Canon Office Equipment & Supplies
What value to set in set ink cnt?
At MaybeNow online guides are always there to provide technical support to troubleshoot Canon FAX-B840 Plain Paper Bubblejet Problems which is free of cost. You can also get Canon FAX-B840 Plain Paper Bubblejet, Fax Machines Help from archived solutions related to repair, maintenance, upgrades and installation problems.
Dec 30, 2010 | Canon FAX-B840 Plain Paper Bubblejet
FAX MACHINE CANON L100 ,RX ONLY BLACK PAPER?
Change toner,it may be damage.So you can change.
Dec 14, 2009 | Canon FAX-L1000 Plain Paper Laser
Hi my fax displays the message CHECK 5100
my fax Canon JX201 displays the message CHECK 5100
Jun 26, 2009 | Canon FAX-JX200
Do i lay paper with print upwards when faxing
That totally depends upon which model ur using just try to pull up the slot where u put ur paper for faxing it will open then just check where the scanner lies and ur print face shall be towards scanner you send top to bottom or bottom to top it doesn't matter.
Jun 20, 2009 | Office Equipment & Supplies
Every Fax we send has stripes going down it making it hard for the receiver to read our faxes. It doesn't happen when we receive fax, print or make copies.
You say it makes copies without the stripes. Do you use the automatic document feeder (ADF) when you make copies, or open the top and lay the paper on the platen? If you get stripes when using the ADF, the ADF scanner area needs to be cleaned. It's the smaller glass area to the left of the main platen glass. Use a damp cloth and remove any dirt or debris.
Jun 15, 2009 | Canon PIXMA MX310 All-In-One Printer
Fax will shows a Paper jam but no paper found in machine.
Are the all sensor flappers whole?Or it may be an PCB problem
Jan 26, 2009 | Canon LaserClass 9000L Plain Paper Fax
Mulitpass mp390
1) Push Fax button
2) Use number buttons to put in telephone number of where you want fax to go to.
3) Lay item to be scanned (faxed) face down on glass and press Start button (Black or Color)
4) Repeat step 3 for each item to be faxed.
5) When ready to send fax (done scanning) press Set button
Nov 26, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
"DARK PAPER USED" Message
I found a copy of the manual, and on page 202 the "Dark Paper Used" message can be caused by three things:
1. Paper used is colored or stained -- replace with clean white paper.
2. Paper was pulled from machine before the fax was ejected completely.
3. The received document support is not installed correctly. Page 3 in the manual shows this support as the rear-most, and it looks like it should be installed with the upright portion angling toward the rear at about a 30 degree angle.
Sep 02, 2008 | Canon FAX-B160 Plain Paper Bubblejet
Constant messages "Check Paper Size"
Try this first..... Some faxes can be configured for different paper sizes for timing of the preinting process. This would be either tabs on the back of the paper drawer of a soft setting found in the owners manual.
Apr 17, 2007 | Canon FAX-L350 Plain Paper Laser
k24674
jasbo
jasbo
Marvin
Marvin
