Question about Gateway M-1625 Notebook
Cant fix boot mgr using SYS. DSK
Data and config error. computer tries to fix but cant save C;BootBCD.Back0002 (automatically). Can I repair boot mgr. using cmd promt in save mode. Computer was restore to factory image, I must have previously erred on bios. (feeble attempts). Now repair problem with part. , before restart repair fixed. should I try and use restore disc. purchased again, instead of using Sys. Disk when I use the F1 key?
Thanks
    Scholar:
  • 74 Answers
I would try using the original restore disk that came with the laptop. It should contain all the needed drivers, files, operating system, and applications specific for your laptop.
Hope this helps.
Posted on Jun 20, 2009
Acer aspire 5534
press f8 when you start your computer and choose to boot into safe mode with gui. If this boot is successful, then the issue is a software issue (OS corrupted) and you can either try a windows repair using your CD, or try a fresh installation. If the issue persists, then you have a hardware issue. If you are getting this error before anything shows up (e.g. press fxx (some function key) for boot menu and/or press fxx to enter bios or some message regarding boot loader), it could be a motherboard issue. If it happens after these messages, this is most probably a hard drive issue. In case of a hardware issue, visit your nearest computer repair shop and the guy should be able to fix it for you.
In case it turns out to be a software issue, you can save your data by booting using a linux live usb (you can easily find out about this by searching a bit over the internet).
In case, this is a motherboard issue, you can save your data by attaching your hard disk to another computer as an external drive (the repair shop guy will know hot to do this).
In case, this is a hard drive issue, it is not possible to save your data any more using the conventional techniques and unless the data is really really really important (national security important) the effort it takes is not worth it.
Nov 19, 2013 | Computers & Internet
Boot mgr is missing dell inspiron oxpcg3
4 short beeps could be something as simple as a keyboard error. the boot mgr error you need to do the windows startup repair option to fix it. you can get to that by pressing F8 at start up
Aug 10, 2012 | Dell Inspiron 560 Desktop Computer (Intel...
Windows 7 professional 32 bit. boot mgr compressed
This problem stemmed from two possible problems:
1. You compressed your Windows folder to save space, not knowing that if you compress it, you lose your ability to boot. (more likely)
2. Hard disk error (almost impossible to come up with an error like that in this case)
You have three possible solutions,
1. Using a Linux live CD, you can boot into Linux, and modify your Windows installation, to uncompress boot mgr (actually, uncompress the entire Windows folder) (I recommend not doing this one, unless you know what you are doing!)
2. Using your Windows disc, you can boot from that disc, and select "repair your computer" (after the language options, and under the big "Install Now" select your operating system, and click next (if your OS isn't here, don't worry, just click next) select Startup Repair, and wait Note: Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs. If repairs are not successful, you'll see a summary of the problem and links to contact information for support. Your computer manufacturer might include additional assistance information.
3. Reinstall Windows
Oct 28, 2011 | Microsoft Windows Vista Home Premium with...
Stack overflow at line 598
Stacks are reserved memory that programs use to process hardware events. A stack overflow occurs when there is not enough space in memory to run the hardware interrupt routines. To resolve these behaviors, you can modify the "STACKS=" line in the Config.sys file, eliminate terminate-and-stay-resident program (TSRs), and eliminate hardware conflicts.
When Windows delivers an error message that is related to an internal stack overflow, there is not enough space in memory either set aside or available to handle the calls that are made to the computer hardware. There are several things to consider when you troubleshoot this behavior:
  1. The Config.sys startup file may not be properly configured for the Windows installation. Use the following values: STACKS=64,512 ;(this is the maximum allowed)
    FILES=60
    BUFFERS=40 If you are using the dual-boot capabilities in Windows, the Config.sys and Autoexec.bat files may not contain the correct configuration to run Windows. When you are dual-booting between Windows 3.x and Windows, these files may not have been renamed back to Config.dos and Autoexec.dos.
    Examine the Config.sys file to determine if files such as Himem.sys or Emm386.exe are loaded from a folder other than the Windows folder. If so, boot Windows by using the Safe Mode Command Prompt Only option. Rename the Config.sys file to Config.dos and the Autoexec.bat file to Autoexec.dos, and then restart your computer.
  2. Some TSRs may be interfering with Windows. Disable any non-boot device drivers in the Config.sys and Autoexec.bat files. If you install from Windows 3.x and you receive a stack overflow error message, check the Win.ini and System.ini files for non-Windows-based programs or drivers that are loading.
  3. There may be an incompatible hardware configuration. Check the port and IRQ settings of the network adapter, sound card, and modem. Make sure that there are no COM2/COM4 or COM1/COM3 conflicts and that no devices are sharing IRQs. Disable or remove conflicting devices.
  4. The computer may need a BIOS upgrade. Check the BIOS version and contact the manufacturer of your computer for information about a BIOS upgrade.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 28, 2010 | Microsoft Computers & Internet
BOOT MGR Missing
I get a - acpiec.sys unexpected error (1024) at (5064) in d:\xpsprtm\base\boot\setup.c. - when attemping to reinstall winXP my Dell XP software for my Dell 9100 the drive has been cleaned and only on partition all the drive test passed is their a hidden partition that I can not get to but I am not showing any partitions except one I created ?
Apr 09, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Advent 4211c will not turn on atall it says windows boot manager...windows failed to start and i do not have a windows installatin disk. how can i sort this problem out if atall .this is the only thing...
This is a boot config problem.
The fix will require that you have the Windows XP cd. Maybe you can borrow one from a friend in order to fix this. Once you have the cd, navigate to the following link for step by step instructons.
http://www.webtree.ca/windowsxp/repair_xp.htm#How%20to%20Repair%20the%20Boot%20Sector:
Sep 24, 2009 | Advent 4211c Notebook
I was installing Turbo Tax 2008 and Windows XP crashed
Madam/Sir --
I none of the mode is working you need to boot from the cd to do any further steps.
inorder to boot from the cd you need to go to the bios and change the boot sequence to boot order.
It varies system to system once to you boot from the cd try to log on to recovery console and do a manual system restore by following the below steps - :
Step 1:
Boot with the windows XP CD
At "Welcome to setup screen" Press R
Select the appropriate path for windows and press enter
If it asks you for the administrator password, normaly there is not password but if you have a password type the administrator password and
press enter or just hit enter
We will now see the Prompt c:\windows>
Step 2:
cd system32\config
ren system system.old
ren software software.old
ren SAM SAM.old
ren security security.old
ren default default.old
Then type cd Type cd system~1\_resto~1 and press Enter
If you get "access denied" (Error) then
Restart the computer by type Exit and get back to recovery console
type cd \ and it will display C:\>
type cd system~1\_resto~1 and press Enter
Step 3:
Type dir
It will list you restore points
(e.g. RP1, RP2, RP3, RP4, etc...)
Select the one from the list except the last one
Say RP4
· type cd RP3 (or RP2 or RP1 or RPn) and enter
· type cd snapshot and enter
· type copy _registry_user_.default c:\windows\system32\config\default and enter
· type copy _registry_machine_security c:\windows\system32\config\security and
enter
· type copy _registry_machine_software c:\windows\system32\config\software and
enter
· type copy _registry_machine_system c:\windows\system32\config\system and enter
· type copy _registry_machine_sam c:\windows\system32\config\sam and enter
· type exit and enter
The computer restarts and the system will be
Successfully restored
Mar 20, 2009 | Microsoft Windows XP Home Edition
Can't Access Config.Sys Files
You might have to repair or reload windows
Mar 16, 2009 | Sony VAIO VGN-BX760NS2 Notebook
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Reaccuring boot problem in vista
HII
i got one answer in web
please check out this
if this not help you
we can move furthur http://www.kqzyfj.com/click-3245371-10520244
Nov 24, 2008 | Microsoft Windows Vista Ultimate Edition
Open Questions:
Gateway M-1625 Notebook Logo
220 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
