Installing windows xp on my SATA h.d. and setup program cant find
Trying to install windows xp on my new 500 GB/Go SATA h.d. and setup program is not finding the drive, all connections are good. The Drive Works, I actually had the drive setup for storage... I can access the sata through my existing IDE h.d and now I would like to make it my Boot drive and setup is not finding it....What could be the solution to this problem?
    Problem Solver:
  • 14 Answers
Lookup your Motherboards Brand and Model. Google to find the Brands website, as most brands have a download section. Look for a file in downloads for YOUR MODEL motherboard with a name along the lines of SATA RAID DRIVER, download it and follow the manufacturers instructions for using it. Most will want you to copy all the files inside the SATA RAID DRIVER zip file onto a floppy and when windows xp setup is loading at the bottom one of the first things it says is "Press F6 and insert the SATA RAID Driver floppy diskette you just made. Then you are allowed to select the required driver for your motherboards SATA chip. Allowing windows to know what settings to use to communicate and see your drive. Hope this helps.
Posted on Jan 09, 2010
    President:
  • 828 Answers
I experience about your problem, first i tell you that maybe the windows system before of that PC is vista, right! Now you are going to install the windows xp on it... i'm sure your hard drive will to another computer using windows but if you install it in your own, the setup program cannot find it. Why!
Because maybe you are using SATA 500GB 3.0, and then your PC is branded, right!
Last tip, try to use a DISKWIZARD, let the DISKWIZARD run your windows xp system, it i will help you...
Good luck...
Posted on Jun 20, 2009
    Sergeant:
  • 193 Answers
Try changing the jumper setting to Master or CS (Cable select) and make you internal hard drive Slave. See if that works.
Can't setup OS in SATA HDD in Intel d945gccr
Hi.
XP will not install until you go into the BIOS and find the menu page (probably by moving across the top level of tabs) where the SATA hard drives are configured. On that page you will see the ports and at least one, maybe all, will be Enabled. Close to that will be the port mode, usually setable individually for each port. Choices may include IDE (or PATA) Emulation, SATA, AHCI. Set your port to IDE emulation. Now look at the bottom for the key to Save and Exit - often the F10 key, press that key and select OK, the computer will restart and you should now be able to install Windows XP without any problems.
To get into the BIOS you have to press the Del or Esc key when you first turn the computer on.
Regards.
Feb 04, 2013 | Intel D945GCCR Motherboard
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
Laptop cannot find new sata disk
Can you provide me the details of the laptop. Also; are to trying to install Windows XP OS on your notebook.
If you are trying to install Windows XP on your notebook; then we need to disable the SATA on the notebook by using the external USB based floppy drive or using the nlite application burning the XP OS disc with a set of SATA drivers to install and recognize the hard drive.
Mar 03, 2010 | Computers & Internet
No hard disk found......
You must first press f6 to load the SATA drivers for the hard drive before you go forward with the install.
Good Luck,
NOLA Tech
Feb 06, 2010 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Hitachi Desk star 500GB SATA drive
you can check the jumper, is it on the right place?
besides, some motherboard is indeed do not support hard drive with large size on it...
Jun 08, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
SATA drive not detected
If you will be loading xp on the new drive,You will just need to press F6 during the setup when ask if you want to install 3rd party driver,and follow the instruction and put the SATA driver disk in when ask.(Even during xp setup It will say SCSI device until all the drivers for it are loaded)
May 20, 2009 | Asrock P4V88 (P4V88 RAID) Motherboard
Cannot install any Windows OS system
My first course of action would be to isolate the problem. So what i would do is un hook one of the 500 gb Sata drives. Then try to install on one. Once you get it up and running hook the second one up and let windows find it. Also another note of thumb is make sure you have not over exceeded your ram slot capabilities. Find the techical manual on the manufactures web site. Each ram slot has a max amount and speed. If you exceed these it can cause windows programs to halt. I do think that if you isolate down to one sata drive install your os then add your second Sata you should be good to go. If you are still having problems feel free to contact me. TechWizard
Sep 21, 2007 | Tyan Tomcat K8E Motherboard
Computers & Internet Logo
747 people viewed this question
Alun Cox
David Payne
David Payne
