Question about Casio Exilim EXZ75 Digital Camera
When I turn the camera o a red stripe with white
When I turn the camera on a red stripe with white letters reads the card is locked
  • 199 Answers
Some cards have a lock tab on them. Make sure it is not in the lock position. If no go then take the card to a photo place and see if they can read it and download your photos. If that does not work then you can reformat the card (you will lose your photos). If you still are experiencing problems, try another card. If that does not work then it's off to the warranty repair or time to get a new camera. Repairs on these are only worth it if they are free or really cheap.
Posted on Jun 20, 2009
2 WIRES PULLED OUT OF THE PLUG ON BACK OF ALTERNATOR ONE WHITE WTH RED STRIPE ONE BLACK WTH WHITE STRIPE WHICH ONE IS IN THE CENTER
dont guess.
ouch, the FSM shows all connector pin outs in the rear.
you never said the year.
nor country diff, countries have different harness colors.??????
my 04' FSM shows.
2 wires. (not counting case and big wire)
the 2 plug. called A11 plug.
a11 pin 2 white red. charge lamp.
a11 pin1 black white,,, IG fuse.
but where are the, page 9a-16 shows that.
harness side,
key up, locking key up
1, 2 , X ( x is blank socket pin) left to right.
1 blk-wh
2 whit red,
or go to alldata dot com and look.
Sep 22, 2013 | Suzuki XL7 Cars & Trucks
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
When i turn on my s5700 there is a message (images recorded to internal memory) then on the screen is a white box with black letters (in) i have done what the manual said and formated but it has not made...
Okay "normally" when the memory card is installed the camera reverts back to the memory card from the internal memory. Two things might be happening here one the internal memory needs to be downloaded to the memory card then saved to the computer and the internal memory card formatted. then the memory card formatted to clear those pictures. And or there is a setting switch in menu or set up that you need to manually switch from internal memory to memory card.
I know when I read this over it made scents so you might need to read it a few times to get the idea of what I'm telling you needs to be done
Apr 19, 2011 | Fuji FinePix S5700 Digital Camera
When i turn on camera ..in red letters it says card locked. what do i need to do so it will work again?
Remove the memory card from the camera, look along the one edge and you will see a tiny switch, slide it towards the contacts to unlock the card. The switch that is in the furthest position from the contacts is in the locked position to prevent the pictures from being erased, now! if you find the card is already unlocked slide it back and forth to reset. If that fails the memory card will need to be replaced.
Mar 19, 2011 | Polaroid Cameras
My camera has a "cardlock" when I turn it on? How
There is only one type of card that I know of that has a locking feature. That is an SD memory card. It has a little white slider on the outside of it. In small letters it says "LOCK" . Push the slider in the opposite direction of the arrow i.e. to unlock it.
If this is the case, then the camera should be able to communicate and write to the card.
There is the possibility that the device in the camera which detects this slider is damaged. In that case the camera should be repaired.
There is an additional problem that can occur. That is the card can be corrupted. Open this link
http://www.normsoft.com/kb/idx/49/157/article/
I hope this helps,
Mark
Jan 19, 2011 | Polaroid t1031 Digital Camera
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Every time I turn on my camera it has a black background a a red line in the middle that has in white letters "the card is locked" what does that mean?
Turn your camera off. Open the memory card access door and remove the memory card. If it is like the SD and XD cards or IS one of those, check along one edge of the card and there should be a tiny (usually white in color) slide switch. Make sure that this switch is in the "unlocked" position and replace it back into the camera and try it. Sometimes the switch moves as you take it in and out. Off brand cards have loose switches that can move just by handling the camera. I had to jam one of mine into the unlocked position with a tiny piece of thick paper stuck into the switch slot. Be careful when putting the card back into the camera that you don't catch the switch on the camera slot and move it back into locked mode. If this has helped, please rate it accordingly. Thanks and good luck.
Jul 15, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Replacing front turn signal socket on 1990 dodge shadow
Okay. Hook black to black.
Green to green with white stripe.
Yellow to red with white stripe.
That should work. Nothing is going to blow up if it's wrong. It just won't work.
May 15, 2009 | 1990 Dodge Shadow
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Casio Exilim EXZ75 Digital Camera Logo
60 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
