Question about Nikon MC-EU1 LCD Remote Control
I have a hard wired sony remote marine rm-xm10. Please tell me what sony radios and cd changers are plug and play with this remote. Radio and changer were stolen and it would be next to impossible to rewire boat with a new remote help Thanks Dennis
  • 13,433 Answers
here is the user manual for the unit:
http://users.turkuai.fi/users/niohtone/xm10.PDF
You will need a pdf reader to open the file, if you don't have one or you can't open the document get one from here: http://get.adobe.com/reader/
The remote requires a unit with sony Bus - system. Just for example I looked up one radio
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=1&storeId=10151&langId=-1&productId=8198552921665801140
Looking at the units spesifications it says
Capability
  • CD : Yes (CD-R/RW)
  • Component Compatible : Sony BUS Control with CD-Text
-- Notice the sony bus contol.
Any sony with BUS system should work.
Let me know if you have any questions or if you need anything else let me know.
Thanks,
Ekse
Posted on Jun 20, 2009
My radio works but when i put on the cd changer it plays but no sound
Are you using an amplifier? If you are, it sounds like you are using the power antenna remote turn on (usually blue) instead of the amplifier remote turn on (usually blue/white). Leaving tuner mode when using the power antenna remote turn on turns the amplifier off.
Feb 21, 2013 | Car Audio & Video
My radio doesn't have a cd but there is a button marked cd. Is it possible there is wiring in thefor the cd changer
Your radio probably will run a changer, but finding a changer will be kind of hard these days as no one makes changers anymore. :Your best bet will be to look on ebay or pawnshops. You will have to make sure it is a changer made by the same manufacturer though, as changers between different companies are rarely compatible. If it is a stock radio, you will have to make sure it is from the same make of car you have.
Nov 13, 2011 | Car Audio & Video
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
Preplace the charger by another device
Yes it is possible with any cd changer that have RCA jacks behind the radio,
that is your case, you are goin gto install a audio sensing device, when the ipod is on the cd changer will stop,
when the ipod is off the cd changer will play 10 seconds later
this interface is only rca jacks easy to plug behind the radio and you can use any audio source, ipod mp3 sat radio
you can also buy a ipod cable
audio sensing device, it is made for sony, but will work with any rca jacks source, also cd changer must be present all the time, don't remove it
Nov 09, 2009 | Panasonic CX-DP88 8-Disc CD Changer
Cant get jvc car stereo to work a sony cd changer
Does your sony cd changer have a separate controller and rf modulator interface? It's a wire from the cd changer with a little box close to the end and an antenna plug at the tip? If you do just plug it into the back of your radio where the antenna goes in, then plug the car antenna jack into the other side of the little box and turn your radio to the marked setting on the box. IF NOT , you can not interface the din plug from a sony into a jvc radio because the sony radio that has a md controller built in will control all of the functions of the matching cd change.
I hope this helps...
Oct 15, 2008 | JVC Car Audio & Video
Sony Marine Radio
check the wiring is installed correctly make sure you have a good earth & if it is a detachable face make sure the face is on correctly after trying this hold reset button for 15secs
May 16, 2008 | Jeep Radios: Genuine 6 Disc Cd Changer
Sony cd changer
IF IT'S A FIAT BRAVA ORIGINAL CAR RADIO WITH A SONY CHANGER IT WILL HAVE AN INTERFACE BEHIND THE RADIO WHICH MAY NEED RESETTING IF YOU DISCONNECT THE INTERFACE POWER FOR 2 MINS AND RECONNECT IT FAILING THAT THE SONY 6 DISC WILL BE JAMMED, WHICH IS COMMON
Nov 19, 2007 | USA Spec SCD-A88 6-Disc CD Changer
In car audio
Hook the remote leads from your amplifiers to the blue/white wire at the back of the Sony head unit.
Dec 30, 2006 | Sony XR-4890 CD Changer
In car audio
hi sounds like you have the amps switching on via the aerial remote and not the amp remote. easy way to test this is to switch the AF or traffic function on your radio. if this cures the problem then you have the amp remote and aerial remote connected around the wrong way regards Mark www.carradiospares.co.uk
Nikon MC-EU1 LCD Remote Control Logo
53 people viewed this question
Top Nikon Televison & Video Experts
Marvin
Marvin
Are you a Nikon Televison and Video Expert? Answer questions, earn points and help others
