Question about Samsung Blackjack SGH-I607 Smartphone
My Samsun Blackjack is stuck on the AT&T screen on startup and will not proceed. I've tried pulling the battery out and restarting several times but the same results.
Try taking out the sim also? you may take sim and battery out for about 30 minutes
Posted on Jun 20, 2009
Toshiba Satellite A305-S6837 is in a "DO -LOOP" with the following:
Use the Windows Install disc and load on top of previous version. Do not do a clean install, this will delete all previous settings and data.
Jan 06, 2013 | Toshiba Satellite A305-S6837 (4400 mAh)
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
Laptop is run and start but no display
Monitor Toggle
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Force Restart
Force Power Down
Hope this helps
Oct 22, 2012 | Toshiba Satellite A500-ST5608 Laptop DC...
My Sony Dream Machine won't save the correct time. When I set the date, it defaults back to 2009, and even when I get the correct time set, the clock won't advance. It's been 8:52 PM for...
My wife's unit has the same issue - tried the firmware update (from Sony's website) and their suggested fix with no luck. Still works as a digital picture frame, but wrong date and stuck time kind of disappoint.
FYI - Suggested fix for stuck date/time:
Unplug unit.
Remove backup battery.
Leave for 30 seconds.
Plug back in and then put battery back.
Set date and time.
Didn't work for me, but maybe you'll have better luck.
Sep 07, 2011 | Sony Dream Machine FMAM radio with...
How do I change the number of times my samsun blackjack phone rings before it goes to voicemail
Go to settings, phone, voice calls, forwarding, unavalible or no answer. In there you can select the number of seconds. Each ring is equal to 5 seconds.
Jan 12, 2010 | Samsung BlackJack II Smartphone
My black jack II is completely frozen. It wont load anything. I cant even send or recieve text messages or go anywhere from the main screen. I have taken the battery out several times but it hasnt helped....
Yes my friend, there is a reboot reset function on the Blackjack 2 SGH-i617.
reminder: "This following steps will delete all files on the phone memory"
*you just have to remove the sim card & memory card.
*Phone should be Off.
*(on the spinning wheel) press & hold the upper side so that you'll be *pressing the UP navigation key. Then while holding that button down, *you need to press & hold the power button.
It will go to the format screen then press #1, it will ask you if you want to delete the files, press the letter "Y" on the keypad then the phone will reboot.
Dec 19, 2009 | Samsung BlackJack II Smartphone
Samsung blackjack on at&t set-up It keeps freezing on the at&t screen. I have pulled the battery and restarted still does not work any thoughts
My BJII does this from time to time. Sometimes I've had to pull the battery and restart several times, but eventually it will boot up. Some people suggest pulling the battery and leaving it out for 45 minutes so the phone will reset. I just do it for a minute or two. If you've tried multiple battery pulls and left the battery out for a long time and it still freezes, you'll probably need to do a hard reset--press the "up" (top) part of the D pad and power on. Note that you'll totally reset your phone like this, so all your customizations will be gone, but at least the phone should work.
Jun 21, 2009 | Samsung Blackjack SGH-I607 Smartphone
Stuck on startup screen.
pull the case apart and pull the battery out for about thirty seconds. put it back in and back together and it should work.
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Stuck on the restart your computer screen.
You may have installed something in the startup items folder that your mac isn't liking.
When you turn the iBook on, press the shift key as soon as you hear the startup tone. hold it down until you see the gray apple screen. This will get you into safe mode, hopefully then you'll be able to fix whatever you did from there. If you are still at a loss, get in touch.
Dec 11, 2008 | Apple iBook G4 Mac Notebook
Samsun s630 lens is stuck out, won't turn on
guessing it was dropped, have a side look at the lens, its probably not straight. pull it straight gently and try again
Apr 19, 2008 | Samsung Digimax S630 Digital Camera
Samsung Blackjack SGH-I607 Smartphone Logo
514 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
